ANT-315-SP
Data Sheet
by
Product Description
The Splatch uses a grounded-line technique to
achieve outstanding performance from a tiny
surface-mount element. This unique antenna is
designed for hand or reflow-mounting directly to a
product’s circuit board. Its low cost makes it ideal
for volume applications. Unlike many compact
antennas, the Splatch exhibits good proximity
performance, making it an appropriate choice for
handheld applications such as remote controls,
pagers and alert devices.
27.94 mm
(1.10")
13.7 mm
(0.54")
1.5 mm
(0.06")
Features
1.27 mm
(0.05")
Recommended Footprint
Very low cost
Ultra-compact package
Direct PCB attachment
Ideal for concealed / internal mounting
Perfect for compact portable devices
Suitable for hand or reflow-assembly
Resistant to proximity effects
5.1 mm
(0.20")
2.54 mm
(0.10")
2.03 mm
(0.08")
Recommended Mounting
Electrical Specifications
Center Frequency:
Recom. Freq. Range:
Bandwidth:
Wavelength:
VSWR:
Impedance:
Connection:
Oper. Temp. Range:
5.1 mm
(0.20")
38.86 mm
(1.53 in)
315MHz
312–317MHz
5MHz
¼-wave
≤ 1.9 typ. at center
50-ohms
Surface-mount
–40°C to +130°C
6.32 mm
(0.25 in)
15.48 mm
(0.57 in)
No ground plane or traces
under the antenna
PCB pads for the Splatch
Vias to ground plane
Ground plane on bottom
layer for counterpoise
50-ohm microstrip line
Electrical specifications and plots measured on 3.8 cm x 8.4 cm
(1.50” x 3.30”) reference ground plane.
98.55 mm
(3.88 in)
Ordering Information
83.57 mm
(3.29 in)
ANT-315-SP (supplied in tubes of 20 pieces)
ANT-315-SP-T (Tape and reel of 500 pieces)
0.51 mm
(0.02 in)
37.85 mm
(1.49 in)
0.51 mm
(0.02 in)
Please see AN-00502 for more details on PCB layout.
–1–
Revised 1/3/2017
Counterpoise
Quarter-wave or monopole antennas require an associated ground plane counterpoise for proper operation.
The size and location of the ground plane relative to the antenna will affect the overall performance of the
antenna in the final design. When used in conjunction with a ground plane smaller than that used to tune the
antenna, the center frequency typically will shift higher in frequency and the bandwidth will decrease. The
proximity of other circuit elements and packaging near the antenna will also affect the final performance. For
further discussion and guidance on the importance of the ground plane counterpoise, please refer to Linx
Application Note AN-00501: Understanding Antenna Specifications and Operation.
VSWR Graph
VSWR
3:1
1.558
Reflected Power
25%
11%
2:1
1:1
277.5MHz
315MHz
0%
352.5MHz
What is VSWR?
The Voltage Standing Wave Ratio (VSWR) is a measurement of how well an antenna is matched to a source
impedance, typically 50-ohms. It is calculated by measuring the voltage wave that is headed toward the load
versus the voltage wave that is reflected back from the load. A perfect match has a VSWR of 1:1. The higher
the first number, the worse the match, and the more inefficient the system. Since a perfect match cannot
ever be obtained, some benchmark for performance needs to be set. In the case of antenna VSWR, this
is usually 2:1. At this point, 88.9% of the energy sent to the antenna by the transmitter is radiated into free
space and 11.1% is either reflected back into the source or lost as heat on the structure of the antenna. In
the other direction, 88.9% of the energy recovered by the antenna is transferred into the receiver. As a side
note, since the “:1” is always implied, many data sheets will remove it and just display the first number.
How to Read a VSWR Graph
VSWR is usually displayed graphically versus frequency. The lowest point on the graph is the antenna’s
operational center frequency. In most cases, this is different than the designed center frequency due to
fabrication tolerances. The VSWR at that point denotes how close to 50-ohms the antenna gets. Linx
specifies the recommended bandwidth as the range where the typical antenna VSWR is less than 2:1.
Copyright © 2017 Linx Technologies
159 Ort Lane, Merlin, OR 97532
Phone: +1 541 471 6256
Fax: +1 541 471 6251
www.linxtechnologies.com
–2–
ANT-315-SP Data Sheet
by
很抱歉,暂时无法提供与“ANT-315-SP”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+62.93160
- 200+25.11000
- 500+24.27840
- 1000+23.85720
