ANT-ELE-S01-005
ANT-ELE-S01-005
    LINXTECHNOLOGIES(灵思)
    ANT-ELE-S01-005
ANT-ELE-S01-005 数据手册
ANT-ELE-S01-005 Data Sheet by Product Description These low-cost, high-performance elements are designed for use with MAG Series magnetic bases. Together with the base, these elements form a reliable and cost effective solution to a diverse range of applications requiring a semi-permanent antenna. The antennas are designed for durability to resist the effects of outdoor environments since they will commonly be used on vehicles or in other exposed applications. 16.00 mm (0.63") Ø5.00 mm (0.20") Ø2.50 mm (0.01") 173.99 mm (6.85") Ø2.50 mm (0.01") Features • • • • • • • • Ideal for both stationary and mobile applications Excellent performance Low cost Omnidirectional performance Outstanding VSWR Securely attaches to all MAG Series bases Fully weatherized construction Attractive and durable black finish 295.40 (11.63") 31.25 mm (1.23") Electrical Specifications Freq. Range: Peak Gain: VSWR: Impedance: Connection: Oper. Temp. Range: 48.70 mm (1.92") 824–960MHz 3.8dBi ≤1.5 typ. at center 50-ohms M5 x 0.8 threaded base –40°C to +80°C 25.40 mm (1.00") Ø9.00 mm (0.35") M5 x 0.8 Electrical specifications and plots measured on ANT-MAG-B50 Ordering Information ANT-ELE-S01-005 This element requires a MAG1 Series base (sold separately) –1– Revised 12/9/13 VSWR Graph VSWR Reflected Power 1.346 3:1 25% 2:1 11% 1:1 810MHz 0% 1010MHz 910MHz What is VSWR? The Voltage Standing Wave Ratio (VSWR) is a measurement of how well an antenna is matched to a source impedance, typically 50-ohms. It is calculated by measuring the voltage wave that is headed toward the load versus the voltage wave that is reflected back from the load. A perfect match will have a VSWR of 1:1. The higher the first number, the worse the match, and the more inefficient the system. Since a perfect match cannot ever be obtained, some benchmark for performance needs to be set. In the case of antenna VSWR, this is usually 2:1. At this point, 88.9% of the energy sent to the antenna by the transmitter is radiated into free space and 11.1% is either reflected back into the source or lost as heat on the structure of the antenna. In the other direction, 88.9% of the energy recovered by the antenna is transferred into the receiver. As a side note, since the “:1” is always implied, many data sheets will remove it and just display the first number. How to Read a VSWR Graph VSWR is usually displayed graphically versus frequency. The lowest point on the graph is the antenna’s operational center frequency. In most cases, this will be different than the designed center frequency due to fabrication tolerances. The VSWR at that point denotes how close to 50-ohms the antenna gets. Linx specifies the recommended bandwidth as the range where the typical antenna VSWR is less than 2:1. 159 Ort Lane, Merlin, OR, US 97532 Phone: +1 541 471 6256 Fax: +1 541 471 6251 www.linxtechnologies.com –2– Data Sheet ANT-ELE-S01-005 by
ANT-ELE-S01-005 价格&库存
很抱歉,暂时无法提供与“ANT-ELE-S01-005”相匹配的价格&库存,您可以联系我们找货
