Dromus Dual-band Wi-Fi Antenna
Part No. SRF2W012
1.
flexiiANT ®
Product Specification
Features
2.
Antenna for 2.4 – 2.5 GHz and 4.9 – 5.9 GHz applications: Wi-Fi ®
802.11a/b/g/j/n/ac
Maintains high performance within device: DFI (Designed For Integration)
1.13mm diameter RF cable with IPEX MHF connector
Self-Adhesive mounted
Quick integration minimizes design cycle
High performance
Available 3 standard cable lengths
Description
Dromus is intended for use with all Wi-Fi applications. A flexible antenna with cable
enables direct connection to the host PCB. Simple integration with plug and play
simplicity. This product specification shows the performance of the antenna to cover
a typical dual band Wi-Fi reception: 2.4-2.5/ 4.9-5.9GHz.
3.
Applications
Access Points
Portable Devices
PC-cards
Game Consoles
Set-Top-Box
Network Devices
Wearable devices
MIMO Systems
Antennas for Wireless M2M Applications
Page 1
Dromus
Part No. SRF2W012
4.
Part Number
Dromus: SRF2W012-xxx
Note. -xxx refers to cable length option:
5.
Part Number
SRF2W012-50
Cable Length
50mm
SRF2W012-100
100mm
SRF2W012-150
150mm
General Data
Product name
Dromus
Part Number
SRF2W012
Frequency
2.4-2.5GHz;4.9-6.0GHz
Polarization
Linear
Operating temperature
-40°C to +85°C
Impedance with matching
50 Ω
Weight
< 0.5 g
FPC Self-adhesive 3M
468MP
Antenna Assembly type
Dimensions (Antenna)
30.0 x 6.0 x 0.15 (mm)
Cable length
50 /100 / 150
Connection
MHF IPEX
6.
RF Characteristics
2.4 – 2.5 GHz
4.9 – 5.9 GHz
Peak gain
3.0dBi
4.0dBi
Average gain
-1.5dBi
-1.8dBi
Average efficiency
>60%
>60%
Maximum return loss
-14dB
-10dB
Maximum VSWR
1.5:1
1.8:1
Conditions
All data measured in a loaded
condition adhered to a plastic
carrier free space.
Page 2
Dromus
Part No. SRF2W012
7.
RF Performance
7.1 Return Loss
5
[dB ]
Atyune
-1 0
2
-1 5
3
1
-2 0
-2 5
-3 0
[M H z]
-3 5
2300 2500 2700 2900 3100 3300 3500 3700 3900 4100 4300 4500 4700 4900 5100 5300 5500 5700 5900
M A RK E RS :
MHz
dB
MHz
dB
WL A N .S 1 P - S 1 1
1: 2401
2: 2495
- 1 8 .6 9
- 1 5 .5 1
3: 4900
4: 5900
- 1 8 .3 8
- 4 0 .0 8
7.2 VSWR
10
Atyune
9
8
7
6
5
4
3
2
1
2
3
4
[M H z]
1
M A RK E RS :
MHz
MHz
1: 2401
2: 2495
1 .2 6
1 .4 0
3: 4900
4: 5900
1 .2 7
1 .0 2
Page 3
Dromus
Part No. SRF2W012
7.3 Antenna patterns
7.3.1
2400 MHz – 2500 MHz
3D pattern at 2.45GHz
Drag to rotate pattern and PCB by using Adobe Reader
(Click to Activate)
Page 4
Dromus
Part No. SRF2W012
7.3.2
4900 MHz – 5900 MHz
3D pattern at 5.45GHz
(Click to Activate)
Page 5
Dromus
Part No. SRF2W012
8. Antenna Dimensions
8.1 Dimensions FPC section
L
2.0
1.5
W
2 Holes = 1mm ø (diameter)
1.0
1.5
L
W
T
Length
Width
Thickness
30.0 ±0.2 (mm)
6.0 ±0.2 (mm)
0.15 (mm) nominal
All dimensions in mm
8.2 Dimensions assembled
L
SRF2W012-50
SRF2W012-100
SRF2W012-150
L
L
L
51 ±2.0 (mm)
101 ±2.0 (mm)
151 ±2.0 (mm)
Page 6
Dromus
Part No. SRF2W012
8.3 IPEX Connector
I-PEX
Front
Material
Copper Alloy
Plating
Ag
Side
Back
5.0
3.0
8.4 Assembly
1.13mm ø Cable
I-PEX Connector
FPC
Page 7
Dromus
Part No. SRF2W012
9. Electrical Interface
9.1 Host Interface
The host PCB requires the mating connector which is IPEX MHF (UFL) receptacle.
The location should be close to the chip/modules pin for the RF. Any feed from this
receptacle should be maintained at 50Ω impedance.
9.2 Transmission Line
All transmission lines should be designed to have a characteristic impedance of 50Ω.
• The length of the transmission lines should be kept to a minimum.
• Any other parts of the RF system like transceivers, power amplifiers, etc, should
also be designed to have an impedance of 50 Ω.
Once the material for the PCB has been chosen, (PCB thickness and dielectric
constant), a coplanar transmission line can easily be designed using any of the
commercial software packages for transmission line design. For the chosen PCB
thickness, copper thickness and substrate dielectric constant, the program will
calculate the appropriate transmission line width and gaps on either side of the feed.
A DC blocking capacitor should be placed in line to protect the RF front end.
10. Mechanical Fixing
The antenna uses 3M 468MP adhesive on the reverse side of the FPC. The antenna
has an easy access split line to peel off to reveal the adhesive side. It is designed for
a one time fix to a clean smooth surface.
FPC back side
Split line for
easy peel
Page 8
Dromus
Part No. SRF2W012
10.0 Antenna Integration Guide
10.1 Placement
For placing the FPC antenna within a device, the host PCB size is not a factor like
PCB mounted antennas. However placement still needs to follow some basic rules, as
any antenna is sensitive to its environment.
Using six spatial directions shown below as a guide. The antenna FPC section should
try to maintain a minimum of three directions free from obstructions to be able to
operate effectively. The other directions will have obstacles in its path, these directions
still require a minimum clearance. These minimum clearances are further defined in
this section. The plastic case is not included in this, only metal objects/components
that will obstruct or come in close proximity to the antenna.
Six spatial directions relative to FPC
Example with 4 spatial directions clear
Battery
FPC
PCB
Page 9
Dromus
Part No. SRF2W012
10.2 Orientation of FPC
The orientation of the FPC with respect to the host PCB should be defined depending
on the unit. The proximity of the GND will have an influence on the antenna so the
PCB location relative to the antenna should be considered.
The FPC will normally be placed in one of the three following options for orientation.
In each option a distance (d) is the critical dimension to consider. Below shows the
minimum value of (d) for each. Other obstructions may increase this dimension.
1)
Vertical mounted
FPC
Cable +Connector
d ≥ 2mm
PCB
1) Co-planar to PCB
d ≥ 10mm
2) Planar to PCB (Same plane)
d ≥ 2mm
Page 10
Dromus
Part No. SRF2W012
10.3 Device Integration example
An example of integration within a device is shown below. The device contains the
major components along with the device outer case. The FPC is shown adhered to
the inside of the device’s plastic housing. The cable routing is along the edge of the
PCB so as not to interfere with any other component. The length of the cable is
sufficient to allow ease of assembly when produced (SRF2W012-100).
The FPC was placed vertically relative to the PCB. The battery is conductive and is
kept the minimum recommended distance away from the FPC of 10mm. The FPC is
kept at maximised height above the PCB to ensure it is above the minimum clearance
of ≥2mm. This example shows the FPC 5mm above the PCB.
For vertical placement
relative to PCB d=5mm
(min ≥2mm)
Distance to battery follows
minimum spec for co-planar
placement d= 10mm (min
≥10mm)
Page 11
Dromus
Part No. SRF2W012
11. Hazardous Material Regulation Conformance
The antenna has been tested to conform to RoHS requirements. A certificate of
conformance is available from Antenova M2M’s website.
12. Packaging
The antennas are stored in individual plastic (PE) bags, then stored within a second
bag of 10pcs.
Single antenna per bag
10 units per second bag (Labelled)
12.1 Optimal Storage Conditions
Temperature
-10ºC to 40ºC
Humidity
Less than 75% RH
Shelf life
24 Months
Storage place
Away from corrosive gas and direct sunlight
Antennas should be stored in unopened sealed
manufacturer’s plastic packaging.
Packaging
The shelf life of the antenna is two years, provided the bag of 10 pieces remains
factory- sealed.
Page 12
Dromus
Part No. SRF2W012
12.2 Label Information
Antenova Limited
Antenova Asia Ltd
4F, No 324, Sec 1, Nei-Hu Road
Nei-Hu District, Taipei 11493, Taiwan, ROC
50.00mm
info@antenova-m2m.com / www.antenova-m2m.com
Description: Dromus
Part number: SRF2W012
Quantity: 1000
Date Code: YYWW
Manufacturer’s code number:
flexiiANT®
70.00mm
Page 13
Dromus
Part No. SRF2W012
Corporate Headquarters
North America Headquarters
Asia Headquarters
Antenova Limited
2nd Floor Titan Court
Bishop Square
Hatfield
AL10 9NA
UK
Antenova Limited
100 Brush Creek Road, Suite 103
Santa Rosa
California 95404
USA
Antenova Asia Limited
4F, No. 324, Sec. 1, Hei-Hu Road
Hei-Hu District
Taipei 11493
Taiwan, ROC
Tel: +1 847 551 9710
Email: sales@antenova-m2m.com
Tel: +886 (0) 2 8797 8630
Fax: +886 (0) 2 8797 6890
Tel: +44 1233 810600
Copyright® Antenova Ltd. All Rights Reserved. Antenova ® , Antenova M2M ® , gigaNOVA ® the Antenova
product family names and the Antenova and Antenova M2M logos are trademarks and/or registered trademarks
of Antenova Ltd. Any other names and/or trademarks belong to their respective companies.
The materials provided herein are believed to be reliable and correct at the time of printing. Antenova does not
warrant the accuracy or completeness of the information, text, graphics or other items contained within this
information. Antenova further assumes no responsibility for the use of this information, and all such information
shall be entirely at the user’s risk.
Product Specification PS-SRF2W012-1.0
Release date November 2015
Page 14
很抱歉,暂时无法提供与“SRF2W012-100”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+22.274141+2.88150
- 10+20.3524510+2.63290
- 25+19.2169125+2.48600
- 100+17.46992100+2.26000
- 200+16.07232200+2.07920
- 600+15.11148600+1.95490
- 800+14.06328800+1.81930
- 国内价格
- 1+20.68601
- 10+18.90128
- 25+17.84722
- 100+16.21821
- 200+14.92459
- 600+14.02624
- 800+13.05602
