Approval sheet
PCB ANTENNA
5.x GHz Band Working Frequency
Halogens Free Product
P/N: RFPCA201018IM5B301
Customer:
Customer ‘s Part No.:
Approval No.:
Issue Date:
*Contents in this sheet are subject to change without prior notice.
Page 1 of 11
RFPCA201018IM5B301_V02
Dec. 2014
Approval sheet
Version
V01
V02
Page 2 of 11
Date
2014
Oct.
2014
Dec.
Description
Author
New Release
HWCHAN
Modify Cable Color and Add Release Paper
HWCHAN
Dec. 2014
Approval sheet
ELECTRICAL CHARACTERISTICS
Item
Specification
Frequency Range
5.15 ~ 5.85 GHz
Impedance
50 Ohm Nominal
Return Loss
-10 dB (Max)
Peak Gain
5.47 dBi
VSWR
2.0 (Max)
Radiation
Omni-directional
Polarization
Admitted Power
Linear Vertical
1W
*note-1: Electrical characteristics will depend on customer’s final application.
MATERIAL TABLE
Items
Description
ψ1.13(Gray)
Cable
Connector
IPEX
FPC Antenna
FR4(綠漆噴錫板) T=0.8mm
Sponge+Doubel Tape
EPDM+G9000
ORDERING RULE
RF
PCA
Type Code
Product
Code
Walsin RF
Device
PCA:
PCB
Antenna
Page 3 of 11
2010
PCB
Dimension
(Unit: mm)
18
I
Cable
Connector
Length (unit:
Brand
cm)
A: N
C:MCX
D:IPEX III
Per 2 digits of
2 digits for
E: IPEX IV
length, width
cable length F: IPEX A13
H: Hirose
e.g.: 2010
e.g.: 18
I: IPEX
Length
Cable
M: MMCX
20.1mm, Width
Length:18cm S: SMA
10mm
T: TNC
U:MURATA
N: None
M
5
B
Type of Connector
Application
Project
status
0: 0GHz
3: 3GHz
5: 5GHz
6: 6GHz
A: 2.4GHz ISM band
A: Reverse Female B: GSM 900/1800
B: Reverse Male
dual band
F: Female
G: GPS band
M: Male
L: 2.4/5.2/5.8 GHz
N: None
tri-band
N: NFC
T: LTE band
W:
WCDMA
band
3
01
Wire
Project
Diameter
0:None
1:∅ 0.81
B: MP
01~99
3:∅ 1.13
T:Durin
series
g Test
6:RG316
X: Pile Run 7:∅ 1.37 number
8:RG178
Dec. 2014
Approval sheet
Appendix A: Dimensions
Page 4 of 11
Dec. 2014
Approval sheet
Test Report
■ELECTRICAL CHARACTERISTICS
Return Loss
Page 5 of 11
Dec. 2014
Approval sheet
Isolation
Page 6 of 11
Dec. 2014
Approval sheet
Antenna Efficiency & Peak Gain
5150~5850 MHz
Page 7 of 11
Dec. 2014
Approval sheet
■RADIATION PATTERN
5150~5850 MHz
Phi=0.00deg
Gain . dB
Page 8 of 11
Dec. 2014
Approval sheet
5150~5850 MHz
Phi=90.00deg
Gain . dB
Page 9 of 11
Dec. 2014
Approval sheet
5150~5850 MHz
Theta=90.00deg
Gain . dB
Page 10 of 11
Dec. 2014
Approval sheet
Package
Page 11 of 11
Dec. 2014
很抱歉,暂时无法提供与“RFPCA201018IM5B301”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+27.843591+3.60141
- 10+20.8329910+2.69463
- 25+19.0849925+2.46854
- 100+17.16266100+2.21990
- 250+16.24462250+2.10115
- 500+15.69181500+2.02965
- 2000+14.862112000+1.92233
- 4000+14.553834000+1.88246
- 6000+14.399436000+1.86249
