Bentoni
Part No. SRFG017
Bentoni GNSS Antenna
Part No. SRFG017
1.
flexiiANT ®
Product Specification
Features
2.
Antenna for 1559 – 1609 MHz applications
Solution for all global public constellations: GPS, GLONASS, Beidou and
GALILEO
Maintains high performance within device: DFI (Designed For Integration)
1.13mm diameter RF cable with IPEX MHF connector
Self-Adhesive mounted
Quick integration minimizes design cycle
High performance
Available 3 standard cable lengths
Description
Bentoni is intended for use with all positioning applications. A flexible antenna with
cable enables direct connection to the host PCB. Simple integration with plug and
play simplicity. This product specification shows the performance of the antenna to
cover a typical GNSS reception: 1559 – 1609 MHz.
3.
Applications
Trackers
Portable devices
Drones
Network devices
Wearable devices
Antennas for Wireless M2M Applications
Page 1
Bentoni
Part No. SRFG017
4.
Part Number
Bentoni: SRFG017-xxx
Note. -xxx refers to cable length option:
5.
Part Number
Cable Length
SRFG017-50
50mm
SRFG017-100
100mm
SRFG017-150
150mm
General Data
Product name
Bentoni
Part Number
SRFG017
Frequency
1559 – 1609MHz
Polarization
Linear
Operating temperature
-40°C to +85°C
Impedance with matching
50 Ω
Weight
< 0.5 g
FPC Self-adhesive 3M
468MP
Antenna Assembly type
Dimensions (Antenna)
40.0 x 14.0 x 0.15 (mm)
Cable length
50 /100 / 150
Connection
MHF IPEX
6.
RF Characteristics
1559 – 1609 MHz
Peak gain
4.0dBi
Average gain
-1.2dBi
Average efficiency
>75%
Maximum return loss
-14dB
Maximum VSWR
1.45:1
Conditions
All data measured in a loaded
condition adhered to a plastic
carrier free space.
Page 2
Bentoni
Part No. SRFG017
7.
RF Performance
7.1 Return Loss
5
[dB]
Atyune
-10
4
1
-15
3
2
-20
-25
-30
-35
1450
[MHz]
1500
MARKERS:
MHz
RD8017.s1p - S11
1: 1563
2: 1587
1550
dB
1600
MHz
-15.40
-18.18
3: 1597
4: 1609
1650
1700
dB
-17.06
-14.76
7.2 VSWR
10
Atyune
9
8
7
6
5
4
3
2
1
1
1450
2
3
4
[MHz]
1500
1550
MARKERS:
MHz
RD8017.s1p - S11
1: 1563
2: 1587
1600
1650
1700
MHz
1.41
1.28
3: 1597
4: 1609
1.33
1.45
Page 3
Bentoni
Part No. SRFG017
7.3 Antenna patterns
7.3.1
1575 MHz
3D pattern at 1575MHz
Drag to rotate pattern and PCB by using Adobe Reader
(Click to Activate)
Page 4
Bentoni
Part No. SRFG017
8. Antenna Dimensions
8.1 Dimensions FPC section
2 Holes = 1mm ø (diameter)
L
W
T
Length
Width
Thickness
40.0 ±0.2 (mm)
14.0 ±0.2 (mm)
0.15 (mm) nominal
All dimensions in mm
8.2 Dimensions assembled
L
SRF2W012-50
SRF2W012-100
SRF2W012-150
L
L
L
57 ±2.0 (mm)
107 ±2.0 (mm)
157 ±2.0 (mm)
Page 5
Bentoni
Part No. SRFG017
8.3 IPEX Connector
I-PEX
Front
Material
Copper Alloy
Plating
Ag
Side
Back
5.0
3.0
8.4 Assembly
1.13mm ø Cable
I-PEX Connector
FPC
Page 6
Bentoni
Part No. SRFG017
9. Electrical Interface
9.1 Host Interface
The host PCB requires the mating connector which is IPEX MHF (UFL) receptacle.
The location should be close to the chip/modules pin for the RF. Any feed from this
receptacle should be maintained at 50Ω impedance.
9.2 Transmission Line
All transmission lines should be designed to have a characteristic impedance of 50Ω.
• The length of the transmission lines should be kept to a minimum
• Any other parts of the RF system like transceivers, power amplifiers, etc, should
also be designed to have an impedance of 50 Ω
Once the material for the PCB has been chosen (PCB thickness and dielectric
constant), a coplanar transmission line can easily be designed using any of the
commercial software packages for transmission line design. For the chosen PCB
thickness, copper thickness and substrate dielectric constant, the program will
calculate the appropriate transmission line width and gaps on either side of the feed.
A DC blocking capacitor should be placed in line to protect the RF front end.
10. Mechanical Fixing
The antenna uses 3M 468MP adhesive on the reverse side of the FPC. The antenna
has an easy access split line to peel off to reveal the adhesive side. It is designed for
a one time fix to a clean smooth surface.
FPC back side
Split line for
easy peel
Page 7
Bentoni
Part No. SRFG017
10.0 Antenna Integration Guide
10.1 Placement
For placing the FPC antenna within a device, the host PCB size is not a factor like
PCB mounted antennas. However placement still needs to follow some basic rules,
as any antenna is sensitive to its environment.
Using six spatial directions shown below as a guide. The antenna FPC section
should try to maintain a minimum of three directions free from obstructions to be able
to operate effectively. The other directions will have obstacles in its path, these
directions still require a minimum clearance.
Six spatial directions relative to FPC
Page 8
Bentoni
Part No. SRFG017
10.2 Orientation of FPC
The orientation of the FPC with respect to the host PCB should be defined
depending on the unit. The proximity of the GND will have an influence on the
antenna so the PCB location relative to the antenna should be considered.
The FPC will normally be placed in one of the three following options for orientation.
In each option a distance (d) is the critical dimension to consider. Below shows the
minimum value of (d) for each. Other obstructions may increase this dimension.
1) Vertical mounted
FPC
Cable +Connector
d ≥ 3mm
PCB
1) Co-planar to PCB
d ≥ 12mm
2) Planar to PCB (Same plane)
d ≥ 3mm
Page 9
Bentoni
Part No. SRFG017
10.3 Device Integration example
An example of integration within a drone is shown below. The device contains the
major components along with the device outer case. The FPC is shown adhered to
the inside of the device’s plastic housing. The length of the cable should be chosen
to be sufficient to allow ease of assembly when produced (SRFG017-100 in
example).
The FPC was placed vertically relative to the PCB. The FPC is kept at maximised
height above the PCB to ensure it is above the minimum clearance of ≥2mm. This
example shows the FPC 5mm above the PCB. For this type of device it is advisable
to keep the antenna away from the electric motor cables and motors themselves that
may interfere.
For vertical placement
relative to PCB d=15mm
(min ≥2mm)
Page 10
Bentoni
Part No. SRFG017
11. Hazardous Material Regulation Conformance
The antenna has been tested to conform to RoHS requirements. A certificate of
conformance is available from Antenova M2M’s website.
12. Packaging
The antennas are stored in individual plastic (PE) bags. Then stored within a second
bag of 10pcs.
Single antenna per bag
10 units per second bag (Labelled)
12.1 Optimal Storage Conditions
Temperature
-10ºC to 40ºC
Humidity
Less than 75% RH
Shelf life
18 Months
Storage place
Away from corrosive gas and direct sunlight
Antennas should be stored in unopened sealed
manufacturer’s plastic packaging.
Packaging
Page 11
Bentoni
Part No. SRFG017
12.2 Label Information
Antenova Limited
Antenova Asia Ltd
4F, No 324, Sec 1, Nei-Hu Road
Nei-Hu District, Taipei 11493, Taiwan, ROC
60.00mm
info@antenova-m2m.com / www.antenova-m2m.com
Description: Bentoni
Part number: SRFG017
Quantity: 1000
Date Code: YYWW
Manufacturer’s code number:
flexiiANT
90.00m
m
Page 12
Corporate Headquarters
North America Headquarters
Asia Headquarters
Antenova Limited
nd
2 Floor Titan Court
Bishop Square
Hatfield
AL10 9NA
UK
Antenova Limited
100 Brush Creek Road, Suite 103
Santa Rosa
California 95404
USA
Antenova Asia Limited
4F, No. 324, Sec. 1, Nei-Hu Road
Nei-Hu District
Taipei 11493
Taiwan, ROC
Tel: +44 1233 810600
Email: sales@antenova-m2m.com
Tel: +1 (707) 890 5202
Tel: +886 (0) 2 8797 8630
Fax: +886 (0) 2 8797 6890
Copyright® Antenova Ltd. All Rights Reserved. Antenova ®, Antenova M2M ®, gigaNOVA ® the Antenova
product family names and the Antenova and Antenova M2M logos are trademarks and/or registered trademarks
of Antenova Ltd. Any other names and/or trademarks belong to their respective companies.
The materials provided herein are believed to be reliable and correct at the time of printing. Antenova does not
warrant the accuracy or completeness of the information, text, graphics or other items contained within this
information. Antenova further assumes no responsibility for the use of this information, and all such information
shall be entirely at the user’s risk.
Product Specification DS-SRFG017 1.0
Release date January 2016
Page 13
很抱歉,暂时无法提供与“SRFG017-100”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 200+15.13014200+1.96620
