SGGP.12.4.A.02
SGGP.12.4.A.02
    TAOGLASLIMITED
    SGGP.12.4.A.02
SGGP.12.4.A.02 数据手册
SPECIFICATION PATENT PENDING Part No. : SGGP.12A Description : 12mm GPS/GLONASS/GALILEO SMT Mount Ceramic Patch Antenna 12*12*4mm Features : 1575.42 /1602 MHz GPS/GLONASS Antenna 2.67 dBi Peak Gain for GPS/GALILEO Band 2.94 dBi Peak Gain for GLONASS Band 12 x 12 x 4mm dimension SMT direct mount ceramic patch antenna Automotive TS16949 Production and Quality Approved RoHS compliant DSP-15-8-SPE-15-8-034/A/SS Page 1 of 18 SGGP.12.4.A.02 1. Introduction The SGGP.12.4.A.02 is a ceramic GPS/GLONASS/GALILEO passive patch antenna with low-profile thickness of 4mm. It is designed for applications in navigation devices, vehicle tracking/fleet management systems, and telematics devices. Typical applicable industries are transportation, defense, marine, agriculture, and navigation. The antenna has been tuned on a 50 x 50 mm ground plane, working at 1575.42MHz and 1602MHz, with a 2.67 dBi gain and 2.94 dBi gain, respectively. The ceramic patch is mounted via SMT process. It is manufactured and tested in a TS16949 first tier automotive approved facility. For customer specific device environments, custom tuned patch antennas are highly recommended, subject to potential NRE and MOQ. Contact your regional Taoglas sales office for details. DSP-15-8-SPE-15-8-034/A/SS Page 2 of 18 SGGP.12.4.A.02 2. Specification ELECTRICAL Application Bands GPS/GALILEO GLONASS Operation Frequency (MHz) 1575.42 ±1.023 1602±5 Return Loss (dB) < -10 < -10 Gain at Zenith (dBi) 2.67 2.94 Efficiency (%) 60.78 60.58 Impedance 50 ohms MECHANICAL Ceramic Dimension (mm) 12 x 12 x 4 Weight (g) 3.3 ENVIRONMENTAL Operation Temperature -40°C to 85°C Humidity Non-condensing 65°C 95% RH * Antenna properties were measured with the antenna mounted on 50*50mm Ground Plane Taoglas Part # SGGPD.12A DSP-15-8-SPE-15-8-034/A/SS Page 3 of 18 SGGP.12.4.A.02 3. Antenna Characteristics 3.1. Return Loss 3.2. Efficiency DSP-15-8-SPE-15-8-034/A/SS Page 4 of 18 SGGP.12.4.A.02 3.3. Average Gain 3.4. Peak Gain DSP-15-8-SPE-15-8-034/A/SS Page 5 of 18 SGGP.12.4.A.02 4. Antenna Radiation Pattern 4.1. Measurement Setup The SGGP.12.4.A.02 antenna is tested with 50mm*50mm ground plane in a CTIA certified ETS-Lindgren Anechoic Chamber. The test setup is shown below. Y X Z DSP-15-8-SPE-15-8-034/A/SS Page 6 of 18 SGGP.12.4.A.02 4.2. 2D Radiation Pattern XY Plane X Y XZ Plane Z X DSP-15-8-SPE-15-8-034/A/SS Page 7 of 18 SGGP.12.4.A.02 YZ Plane Z Y DSP-15-8-SPE-15-8-034/A/SS Page 8 of 18 SGGP.12.4.A.02 4.3. 3D Radiation Pattern 1575.42MHz 1602MHz DSP-15-8-SPE-15-8-034/A/SS Page 9 of 18 SGGP.12.4.A.02 5. Mechanical Drawing Unit:mm DSP-15-8-SPE-15-8-034/A/SS Page 10 of 18 SGGP.12.4.A.02 6. Evaluation Board (SGGPD.12A) Unit:mm DSP-15-8-SPE-15-8-034/A/SS Page 11 of 18 SGGP.12.4.A.02 7. PCB Footprint Recommendation 7.1. Footprint Copper Keepout Area (unit: mm) DSP-15-8-SPE-15-8-034/A/SS Page 12 of 18 SGGP.12.4.A.02 7.2. Paste Area (unit: mm) DSP-15-8-SPE-15-8-034/A/SS Page 13 of 18 SGGP.12.4.A.02 7.3. Top Solder Mask(unit: mm) DSP-15-8-SPE-15-8-034/A/SS Page 14 of 18 SGGP.12.4.A.02 7.4. Composite Diagram (unit: mm) DSP-15-8-SPE-15-8-034/A/SS Page 15 of 18 SGGP.12.4.A.02 8. Recommended Reflow Soldering Profile SGGP.12A can be assembled following Pb-free assembly. According to the Standard IPC/JEDEC J-STD-020C, the temperature profile suggested is as follows: DSP-15-8-SPE-15-8-034/A/SS Page 16 of 18 SGGP.12.4.A.02 9. Packaging 9.1. Inner Tray DSP-15-8-SPE-15-8-034/A/SS Page 17 of 18 SGGP.12.4.A.02 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. Copyright © Taoglas Ltd. DSP-15-8-SPE-15-8-034/A/SS Page 18 of 18 SGGP.12.4.A.02
SGGP.12.4.A.02 价格&库存
很抱歉,暂时无法提供与“SGGP.12.4.A.02”相匹配的价格&库存,您可以联系我们找货
SGGP.12.4.A.02
  • 1+54.102741+6.99964
  • 10+41.4229210+5.35916
  • 25+38.2683325+4.95103
  • 100+34.79408100+4.50155
  • 250+33.16369250+4.29061
库存:1373
SGGP.12.4.A.02
  • 500+32.14051500+4.15824
  • 1000+31.318941000+4.05194
  • 1500+30.907571500+3.99872
  • 2500+30.451972500+3.93978
库存:1373
SGGP.12.4.A.02
  • 28+39.0156528+5.04772
库存:4000
SGGP.12.4.A.02
  • 500+19.20791500+2.48506
  • 1000+19.016471000+2.46029
  • 1500+18.825031500+2.43552
  • 2500+18.641572500+2.41179
库存:9000
SGGP.12.4.A.02
  • 100+29.93770100+3.87324
  • 300+28.13517300+3.64004
库存:300
SGGP.12.4.A.02
    库存:1000
    SGGP.12.4.A.02
    • 500+19.54294500+2.52840
    • 1000+19.348161000+2.50320
    • 1500+19.153381500+2.47800
    • 2500+18.966712500+2.45385
    库存:9000
