SGGP.25.4.A.02
SGGP.25.4.A.02
    TAOGLASLIMITED
    SGGP.25.4.A.02
SGGP.25.4.A.02 数据手册
  SGGP.25A Specification Part No. SGGP.25A Product Name GPS/GLONASS SMT Patch Antenna Features 25mm*25mm*4.5mm Single Feed SMT Mount GPS: 1575MHz GLONASS: 1602MHz Patent pending RoHS SGGP.25.4.A.02 | page 1 of 14 1. Introduction This ceramic 25mm GPS/GLONASS patch antenna is mounted via SMT process and has been pre-tuned for a 50*50mm ground plane. Custom part no’s tuned for different ground-plane or layout positions and taking into account the specific conditions in your device can be created and supplied by Taoglas. 2. Specification Original Patch Specification tested on 50*50mm ground plane No.: PARAMETER Specification Notes 1 Range of Receiving Frequency 2 Center Frequency 1592± 3MHz With 50*50mm ground plane 3 Bandwidth 8MHz min Return Loss > 1.62100 GHz 3 2 1: 2: 49.844 Ω -1.0605 Ω 1.60200 GHz 3: 24.081 Ω 5.4004 GHz 1.60800 GHz 4: 8.6426 Ω 22.757 Ω 1.62100 GHz 2 1 Center 1 592.000 000 MHz Span 100.000 000 MHz CH3 Markers 49.156 Ω 0.0020 Ω 1.57542 Ghz SGGP.25.4.A.02 | page 3 of 14 4. Radiation Patterns 4.1 1575MHz - XZ and YZ Plane 30 330 0 -5 -10 -15 60 300 -20 -25 -30 -35 -40 90 270 -45 120 240 150 (dBi) 210 180 Pattern Model No. Test Mode Freq (Mhz) Max Gain (dBi) Min Gain (dBi) Avg. Gain (dBi) Source Polar Date 1 SGGP.25 XZ 1575.42 -0.36 / 356.00 -8.52 / 248.00 -3.54 V+H 2012/6/8 2 SGGP.25 YZ 1575.42 1.20 / 351.00 -9.29 / 105.00 -2.49 V+H 2012/6/8 SGGP.25.4.A.02 | page 4 of 14 4.2 1602MHz - XZ and YZ Plane 30 330 0 -5 -10 -15 60 300 -20 -25 -30 -35 -40 90 270 -45 120 240 150 (dBi) 210 180 Pattern Model No. Test Mode Freq (Mhz) Max Gain (dBi) Min Gain (dBi) Avg. Gain (dBi) Source Polar Date 1 SGGP.25 XZ 1602.00 2.88 / 355.00 -5.41 / 254.00 -0.65 V+H 2012/6/8 2 SGGP.25 YZ 1602.00 1.95 / 350.00 -8.76 / 249.00 -1.83 V+H 2012/6/8 SGGP.25.4.A.02 | page 5 of 14 5. Mechanical Specifications 5.1 Antenna Dimensions and Drawing   SGGP.25.4.A.02 | page 6 of 14 5.1.1 Footprint Copper Keepout Area   SGGP.25.4.A.02 | page 7 of 14 5.1.2 Paste Area   SGGP.25.4.A.02 | page 8 of 14 5.1.3 Soder Mask (Negative)   SGGP.25.4.A.02 | page 9 of 14 5.1.4 Footprint Composite   SGGP.25.4.A.02 | page 10 of 14 5.2 Test Jig and Dimension SGGPD.25A SGGP.25.4.A.02   | page 11 of 14 5.3 SGGPD.25A   SGGP.25.4.A.02 | page 12 of 14 6. Recommended Reflow Soldering Profile SGGP.25A can be assembled following Pb-free assembly. According to the Standard IPC/JEDEC J-STD-020C, the temperature profile suggested is as follows: Phase Profile Features Pb-Free Assembly (SnAgCu) PREHEAT Temperature Min(Tsmin) 150°C Temperature Max(Tsmax) 200°C Time(ts) from (Tsmin to Tsmax) 60-120 seconds RAMP-UP Avg. Ramp-up Rate (Tsmax to TP) 3°C/second(max) REFLOW Temperature(TL) 217°C Total Time above TL (tL) 30-100 seconds PEAK Temperature(TP) 260°C Time(tp) 2-5 seconds RAMP-DOWN Rate 3°C/second(max) Time from 25°C to Peak Temperature 8 minutes max. Composition of solder paste 96.5Sn/3Ag/0.5Cu Solder Paste Model SHENMAO PF606-P26     Soldering Iron condition: Soldering iron temperature 270°C±10°C. Apply preheating at 120°C for 2-3 minutes. Finish soldering for each terminal within 3 seconds, if soldering iron temperature over270°C±10°C or 3 seconds, it will make cause component surface peeling or damage. SGGP.25.4.A.02 | page 13 of 14 7. Packaging Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. Copyright © Taoglas Ltd. SGGP.25.4.A.02   | page 14 of 14
SGGP.25.4.A.02
物料型号:SGGP.25A
器件简介:该器件是一款25mm x 25mm x 4.5mm尺寸的GPS/GLONASS表面贴装(SMT)平板天线,适用于50mm x 50mm的接地平面,并且是专为此尺寸的接地平面预调谐的。Taoglas可以为不同接地平面尺寸或布局位置,以及考虑到设备中特定条件的客户创建和提供定制型号。
引脚分配:文档中没有明确提供引脚分配信息,但提到了天线的接地焊盘2、3、4、5和6应连接到地线(GND)。
参数特性: - 接收频率范围:GPS:1575.42 MHz ± 1.023 MHz,GLONASS: 1602 MHz - 中心频率:1592 MHz ± 3 MHz(50mm x 50mm接地平面) - 带宽:最小8MHz,回波损耗小于-10 dB - 电压驻波比(VSWR):最大1.5(中心频率) - 天线增益:GPS典型值-0.14 dBi,GLONASS典型值1.75 dBi - 极化:右旋圆极化(RHCP) - 阻抗:50欧姆 - 频率温度系数:0至+85°C时为20 ppm/°C - 工作温度范围:-40°C至+85°C
功能详解:文档提供了天线的电气规格、辐射模式、机械规格、测试夹具和尺寸、推荐的回流焊接曲线以及包装信息。
应用信息:适用于GPS和GLONASS定位系统,文档中提到用户接地平面和环境的变化可能会偏移中心频率。
封装信息:详细描述了天线尺寸和图纸,包括顶部视图、侧面视图和底部视图,以及接地焊盘、焊膏区域、焊膏掩模(负片)和复合焊盘的尺寸。还提供了测试夹具的尺寸和推荐的回流焊接曲线。
SGGP.25.4.A.02 价格&库存
很抱歉,暂时无法提供与“SGGP.25.4.A.02”相匹配的价格&库存,您可以联系我们找货
SGGP.25.4.A.02
    SGGP.25.4.A.02
    • 200+42.85744200+5.54476
    • 400+41.55379400+5.37609
    • 600+40.90088600+5.29162
    • 1000+40.177761000+5.19807
    • 1400+39.755031400+5.14338
    • 2000+39.348542000+5.09079
    库存:1587
    SGGP.25.4.A.02
    • 1+68.075681+8.80741
    • 10+52.5785310+6.80244
    • 25+48.7027525+6.30100
    • 100+44.44082100+5.74961
    库存:1587
    SGGP.25.4.A.02
      • 200+32.37971
      库存:42
      SGGP.25.4.A.02
        SGGP.25.4.A.02
          库存:600
          SGGP.25.4.A.02
          • 50+40.0094550+5.17629
          • 200+37.02688200+4.79042
          库存:250
