WDP.2458.25.4.B.02
WDP.2458.25.4.B.02
    TAOGLASLIMITED
    WDP.2458.25.4.B.02
WDP.2458.25.4.B.02 数据手册
Part No: WPD.2458.25.4.B.02 Description: Wi-Fi Dual-band 2.4/5 GHz Embedded Ceramic Patch Antenna 6dBi+ at 2.4GHz 6dBi+ on 5 to 6 GHz Features: Dimensions: 25mm*25mm*4mm 2400MHz to 2500MHz/5150MHz to 5850MHz Pin Type Supports IEEE 802.11 Dual-band Wi-Fi systems Dual linear polarization Tuned for 70x70mm ground plane RoHS and REACH Compliant SPE-14-8-039/D 1. Introduction 3 2. Specifications 4 3. Antenna Characteristics 5 4. Radiation Patterns 7 5. Mechanical Drawing 9 6. Footprint 10 7. Packaging 11 Changelog 12 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-14-8-039-D www.taoglas.com 2 1. Introduction 1. Introduction 1. Introduction 1. Introduction patent pending high gain, high efficiency embedded ceramic patch antenna is designed for 1.This unique Introduction professional Wi-Fi dual-band IEEE 802.11 applications. It is mounted via pin and double-sided adhesive. The passive patch offers stable high gain response from 4 dBi to 6dBi on the 2.4GHz band and from 5dBi to 8dBi on the 5 ~6 GHz band. Efficiency values are impressive also across the bands with on average 60%+. high gain, high efficiency performance is the perfect solution for directional dual-band WiFi 1.The WDP.25’s Introduction application which need long range but which want to use small compact embedded antennas. The much higher gain and efficiency of the WDP.25 over smaller less efficient more omni-directional chip antennas (these typically have no more than 2dBi gain, 30% efficiencies) means it can deliver much longer range over a wide sector. 1.TypicalIntroduction applications are • • • • • • • • • 1. Access Points Tablets High definition high throughput video streaming routers High data MIMO bandwidth routers Automotive Home and industrial in-wall WiFi automation Drones/Quad-copters UAV Long range WiFi remote control applications Introduction The WDP patch antenna has two distinct linear polarizations, on the 2.4 and 5GHz bands, increasing isolation between bands. Custom tuned versions for different ground-planes and housing environments can be made subject to a minimum order quantity. Contact your regional Taoglas customer support team for further information or to integrate and test this antenna performance in your device. SPE-14-8-039-D www.taoglas.com 3 2. Specifications 3. Antenna Characteristics2. GNSSSpecifications Electrical 3. 4. Frequency Range (MHz) 2400-2500 5150-5850 Return Loss (dB) Min. -19, -2 at edge
WDP.2458.25.4.B.02
物料型号:WPD.2458.25.4.B.02
器件简介:该天线是为专业Wi-Fi双频IEEE 802.11应用设计的高增益、高效率嵌入式陶瓷贴片天线。它通过引脚和双面胶安装。在2.4GHz频段提供4dBi至6dBi的稳定高增益响应,在5至6GHz频段提供5dBi至8dBi的增益。效率值在各频段上也相当高,平均超过60%。
引脚分配:文档中未明确提供引脚分配信息。
参数特性:支持2400MHz至2500MHz和5150MHz至5850MHz的双频Wi-Fi系统,具有双线性极化,为70x70mm的接地平面调谐,符合RoHS和REACH标准。
功能详解:该天线适用于需要长距离但希望使用小型紧凑嵌入式天线的定向双频Wi-Fi应用。与更小、效率更低、更全向的芯片天线相比,WDP.25的增益和效率更高,可以提供更长的覆盖范围。
应用信息:适用于接入点、平板电脑、高清高吞吐量视频流路由器、高数据MIMO带宽路由器、汽车、家庭和工业墙面Wi-Fi自动化、无人机/四轴飞行器、UAV、长距离Wi-Fi遥控应用等。
封装信息:尺寸为25mm25mm4mm,高度为4mm,平面尺寸为25x25mm。
WDP.2458.25.4.B.02 价格&库存
很抱歉,暂时无法提供与“WDP.2458.25.4.B.02”相匹配的价格&库存,您可以联系我们找货
WDP.2458.25.4.B.02
  • 1+31.606311+4.08876
  • 10+23.7543710+3.07299
  • 25+21.7962925+2.81969
  • 200+18.84317200+2.43766
  • 400+18.18402400+2.35238
  • 600+17.85394600+2.30968
  • 1000+17.488101000+2.26236
  • 2600+16.930142600+2.19018
  • 5000+16.626035000+2.15083
库存:342
WDP.2458.25.4.B.02
  • 100+16.90516100+2.18694
库存:100
