ACTPAT182 ACTIVE GPS ANTENNA
Functional Specification
Inventek Systems, LLC
239 Littleton Road, Suite 4D
Westford, Massachusetts 01886
978‐392‐2202
ACTPAT182 Functional Specification Version 0.2
PRELIMINARY
1
© 2008 Inventek Systems, LLC
978‐392‐2202
978‐692‐3502 (Fax)
Visit us at http://www.inventeksys.com/
Inventek Systems, LLC, reserves the right to make changes to its products, specifications and
other information at any time without notice. Inventek Systems assumes no liability or responsibility for
any claims or damages arising out of the use of this document, or from the use of products based on this
document, including, but not limited to claims or damages based on infringement of patents, copyrights
or other intellectual property rights. Inventek Systems makes no warranties, either express or implied
with respect to the information and specifications contained in this document. Performance
characteristics listed in this document do not constitute a warranty or guarantee of product
performance.
2
PRELIMINARY
Contents
Contents .................................................................................................................................................................... 3
Overview.................................................................................................................................................................... 4
Mechanical ................................................................................................................................................................ 5
Thermal...................................................................................................................................................................... 5
Power .................................................................................................................................................................... 5
Patch Characteristics............................................................................................................................................. 6
Active Antenna and LNA Characteristics ................................................................................................................... 6
Far field amplitude excluding the LNA gain............................................................................................................... 7
Shipping ..................................................................................................................................................................... 8
Ordering Information ................................................................................................................................................ 8
Figure 1 Patch Dimension (mm) ................................................................................................................................ 5
Table 1 Mechanical.................................................................................................................................................... 5
Table 2 Antenna Temperature .................................................................................................................................. 5
Table 3 Power Requirements .................................................................................................................................... 5
PRELIMINARY
3
Overview
Inventek’s GPS antenna, part number, ACTPAT182‐01‐IP is designed to work with a variety of GPS receivers. The
active antenna is designed to snap directly onto the Inventek GPS modules ISM300F1 and ISM300F2 Family of
GPS receivers.
The standard model is made from ceramic and comes with a LNA and mini coaxial 1.13mm cable with a U.FL RF
connector that you can mount it directly on the board or attach to your GPS receiver. The active antenna can be
used in a variety of applications including automotive with an impedance of 50 ohms.
The antenna, P/N ACTPAT182‐01‐IP lets you integrate low cost GPS functionality into your product quickly and
easily. It’s suitable for a wide range of applications, including the most compact:
Hand‐held personal positioning and navigation
External PDAs, Pocket PCs and other hand‐held computers
Fleet management
Asset tracking
Automatic vehicle location
The ACTPAT182‐01‐IP provides world class performance suits it to navigating urban canyons, as well as wide‐
open spaces. Being lead‐free, it complies with the European Union’s RoHS (Restriction of Hazardous Substances)
directive.
4
PRELIMINARY
Mechanical
Table 1 summarizes the dimensions of the Antenna.
Parameter
Rectangular
Width
Value
18.6 x 18.6 mm
4.9 ± 0.2 mm including Shield
Color
Black with silver shield
Impedance
50 Ohms
Connector
IPEX U.FL ( MHFI)
Table 1 Mechanical
Thermal
Name
Operation Temperature range
‐40 to +85 °C
Storage temperature
‐40 to +90 °C
Humidity
10 to 95% RH
Frequency Temp Coefficient
20 max ppm/ °C at ‐40 to ‐90 °C
Power
Table 3 summarizes the Antenna’s power requirements.
Parameter
VCC
Continuous tracking
Value
2.7–5.4 V dc
10 mA @ 3 Volts
You can reduce power consumption by turning on the antenna and only when needed to acquire a fix.
PRELIMINARY
5
The Patch characteristics are measured with 50x50 mm ground plane in an anechoic chamber. Active antenna
ESD test (working): >16kv (contact discharge with radome)
Antenna
Patch Center Frequency
Patch Bandwidth ( under ‐10
dB return loss)
Patch Gain at Zenith
Patch Gain at 10 degrees
elevation
Polarization
Axial Ratio
Value
1578.00 +/‐ 2.0 Mhz
10 Mhz min
+ 1.0 dBic Typical
‐5.5 dBic min
R.H.C.P
2.0 dB Typical
LNA
Gain
Noise figure
Value
26 to 35 dB ( @ 3volts 28 dB)
1.4 dB (@ 3 volts 1.35dB)
Output VSWR
DC= 1.5 max
*Center Frequency
1575.42+/‐ 1.0 Mhz
* Center Frequency may be offset based upon the surroundings. ACTPAT182 has been tuned and tested in free
space with printed circuit board and shield as shown in Figure 1.
6
PRELIMINARY
Here is an example of Radiation Pattern of the patch (0 and 90°) Far field amplitude excluding the LNA gain. The
Patch characteristics are measured with 50x50 mm ground plane in an anechoic chamber. Active antenna ESD
O ° degrees
Figure 3 Radiation Pattern (Excluding LNA Gain) (90°)
PRELIMINARY
7
Shipping
Each antenna is individually packaged in Plastic bags
All bags are sealed, impulse sealer
20 units per tray
All material and components are ROHS compliance
The Antenna is RoHS‐compliant and you can custom configure the cable length, type and connector type. Min
orders are required for custom builds. Please specify the corresponding part number when ordering.
Build a part number:
The following ordering configurations are available by order:
P/N: ACTPAT182‐XX‐CT
(XX) = Cable length 01: 63 mm , xx: Custom length in meters
(CT) = Connector Types
00 : No connector
IP: IPEX U.FL connector
HR: Hiroshi U.Fl connector (non standard)
xx: Custom connector
Ordering Part number sequence example
Standard Parts:
Part No.
Antenna Type
ACTPAT182‐01‐IP 18.6 x18.6 x 4.9 mm
ACTPAT182‐01‐00 18.6 x18.6 x 4.9 mm
ACTPAT182‐07‐00 18.6 x18.6 x 4.9 mm
ACTPAT182‐07‐1P 18.6 x18.6 x 4.9 mm
* Hirose U.FL compatible
Connector Type
*Ipex U.FL ( MHFI)
None
None
Ipex U.FL ( MHFI)
Cable
Length
Inches
~ 2.5
~ 2.5
~ 6.5
~ 6.5
Cable
Length
(mm)
63 mm
63 mm
164mm
164mm
8
PRELIMINARY
很抱歉,暂时无法提供与“ACTPAT182-01-IP”相匹配的价格&库存,您可以联系我们找货
