ANT-868-PW-QW-UFL
ANT-868-PW-QW-UFL
    LINXTECHNOLOGIES(灵思)
    设计用于,PW系列14波长鞭状天线在坚固且成本效益高的封装中表现出色。天线通过将其底座穿过产品上的6.35mm孔并用螺母固定或拧入PEM式插入件来安装。天线通过底座馈电,配有8.5英寸(216mm)的...
ANT-868-PW-QW-UFL 数据手册
ANT-868-PW-QW-xxx Data Sheet by Product Description Designed for permanent attachment, PW Series ¼-wave whips give outstanding performance in a rugged and cost-effective package. The antenna is attached by placing its base through a ¼" (6.35 mm) hole in the product and securing it with a nut or by threading it into a PEM-style insert. The antenna is fed through the base with 8.5" (216 mm) of coax cable. Straight-cut RG-174 allows the addition of any 50-ohm RF connector or allows the cable to be soldered directly to the PCB, saving the cost of the connector. It is also available with 1.32 mm coax cable terminated with a U.FL / MHF compatible connector. This saves the labor of adding a connector while using one that is small enough to fit through the antenna’s mounting hole. Custom lengths and terminations are available by special order. 7.8 mm (0.31") 13.0 mm (0.51") 6.0 mm (0.24") or U.FL 84.0 mm (3.31") I-PEX silhouette shown in shadow 52.0 mm (2.05") Features 4.5 mm (0.18") • • • • • • • Low cost Outstanding performance Omni-directional pattern Wide bandwidth Flexible main shaft Rugged & weatherized Integral 8.5" (216 mm) RG-174 coax cable or 1.32 mm coax (U.FL) • Use with plastic* or metal enclosures 1/4-28 UNF 216 mm (8.5") * Requires proximity ground plane 7/16" HEX 14.5 mm (0.57") Electrical Specifications Center Frequency: Bandwidth: Wavelength: VSWR: Peak Gain: Impedance: Connection: Cable: Oper. Temp. Range: Straight Cut 868MHz 750–950MHz ¼-wave ≤ 1.9 typical at center 1.6dBi 50-ohms Straight-cut or U.FL/MHF 8.5" (216 mm) RG-174 coax cable or 1.32 mm coax (U.FL) –40°C to +90°C End View Ordering Information ANT-868-PW-QW (with straight cut RG-174 coax) ANT-868-PW-QW-UFL (U.FL/MHF compatible connector) Electrical specifications and plots measured on 10.16 cm x 10.16 cm (4.00" x 4.00") reference ground plane –1– Revised 1/26/15 Counterpoise Quarter-wave or monopole antennas require an associated ground plane counterpoise for proper operation. The size and location of the ground plane relative to the antenna will affect the overall performance of the antenna in the final design. When used in conjunction with a ground plane smaller than that used to tune the antenna, the center frequency typically will shift higher in frequency and the bandwidth will decrease. The proximity of other circuit elements and packaging near the antenna will also affect the final performance. For further discussion and guidance on the importance of the ground plane counterpoise, please refer to Linx Application Note AN-00501: Understanding Antenna Specifications and Operation. VSWR Graph VSWR 3:1 Reflected Power 25% 1.557 2:1 1:1 768MHz 11% 0% 968MHz 868MHz What is VSWR? The Voltage Standing Wave Ratio (VSWR) is a measurement of how well an antenna is matched to a source impedance, typically 50-ohms. It is calculated by measuring the voltage wave that is headed toward the load versus the voltage wave that is reflected back from the load. A perfect match will have a VSWR of 1:1. The higher the first number, the worse the match, and the more inefficient the system. Since a perfect match cannot ever be obtained, some benchmark for performance needs to be set. In the case of antenna VSWR, this is usually 2:1. At this point, 88.9% of the energy sent to the antenna by the transmitter is radiated into free space and 11.1% is either reflected back into the source or lost as heat on the structure of the antenna. In the other direction, 88.9% of the energy recovered by the antenna is transferred into the receiver. As a side note, since the “:1” is always implied, many data sheets will remove it and just display the first number. How to Read a VSWR Graph VSWR is usually displayed graphically versus frequency. The lowest point on the graph is the antenna’s operational center frequency. In most cases, this will be different than the designed center frequency due to fabrication tolerances. The VSWR at that point denotes how close to 50-ohms the antenna gets. Linx specifies the recommended bandwidth as the range where the typical antenna VSWR is less than 2:1. –2– Data Sheet ANT-868-PW-QW-xxx by
ANT-868-PW-QW-UFL 价格&库存
很抱歉,暂时无法提供与“ANT-868-PW-QW-UFL”相匹配的价格&库存,您可以联系我们找货
