868MHz Terminal Antenna
Part No:
TI.08.C.0112
Description:
868MHz ISM Band Terminal Antenna Fixed Right-Angle SMA(M) Connector
Features:
Omni-Directional Dipole Antenna
TPU Housing
Dimensions: 53x17mm
SMA Male Right Angle Connector
RoHS & Reach Compliant
SPE-11-8-039/C
1.
Introduction
3
2.
Specifications
4
3.
Antenna Characteristics
5
4.
2D Radiation Patterns
7
5.
3D Radiation Patterns
9
6.
Mechanical Drawing
11
7.
Packaging
12
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to
make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and
the information contained herein.
Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
Copyright © Taoglas Ltd.
SPE-11-8-039/C
www.taoglas.com
2
1.
Introduction
1.
Introduction
1.
Introduction
1.
Introduction
1.
Introduction
1.
The Taoglas TI.08.C.0112 is a high performance 868MHz, small form factor, dipole omni-direction terminal
mount antenna. This antenna features an SMA(M) right angle connector as standard.
1.
Some typical applications include:
• Smart Lighting
• Remote Monitoring
• IoT (Internet of Things)
• Smart Metering
1.
Introduction
Introduction
Introduction
This antenna is fabricated using TPU, which is a lightweight robust material used on several other Taoglas
products. The TI.08.0112 can function impressively with a small ground plane while maintaining high
efficiencies, on the band 863~870 it can reach at least 53% on a 15x9cm ground plane. The antenna
connector type can be customizable, please contact your regional Taoglas sales facility for support.
SPE-11-8-039/C
www.taoglas.com
3
2.
Specifications
3.
Antenna Characteristics2.
Specifications
ISM
Frequency (MHz)
3.
863~870
902~928
1.75
2.43
On 15 X 9cm ground plane
-2.74
Antenna
Radiation Patterns3.Antenna
-2.26
Peak Gain (dBi)
Average Gain (dBi)
4.
Efficiency (%)
Characteristics2.
Specifications
3.
53.22
Impedance
50Ω
Polarization
Linear
Antenna
Characteristics2.
Radiation Pattern
Specifications
Omni-Directional
Input Power
3.
4.
59.37
50 W
Mechanical
Height
53 ± 2 mm
Diameter
∅7 ± 0.2 mm
Width
Antenna Radiation
Patterns3.Antenna
Casing
17 ± 0.8 mm
TPU
CharacteristicsConnector
SMA(M) RA
Environmental
Temperature Range
4.
Antenna Radiation Patterns
4.
Antenna Radiation Patterns3.Antenna
-40°C to 70°C
Characteristics
4.
Characteristics2.
SPE-11-8-039/C
Specifications
www.taoglas.com
4
3.
4.
3.1
Return Loss
Characteristics
4.
4.
Characteristics
4.
Characteristics
3.2
Efficiency
4.
4.
4.
4.
Characteristics
4.
SPE-11-8-039/C
www.taoglas.com
5
3.3
Average Gain
3.4
Peak Gain
SPE-11-8-039/C
www.taoglas.com
6
4.
4.
4.
4.1
Test Setup
4.
4.
Y
X
4.
Z
4.
4.
4.
SPE-11-8-039/C
www.taoglas.com
7
XY Plane
X
Y
XZ Plane
Z
X
YZ Plane
Z
Y
SPE-11-8-039/C
www.taoglas.com
8
5.
On 15 X Radiation
9cm ground plane
4.5.1 Antenna
Patterns
4.
4.
4.
4.
4.
4.
SPE-11-8-039/C
www.taoglas.com
9
SPE-11-8-039/C
www.taoglas.com
10
6.
Mechanical Drawing (Units: mm)
6.
Packaging5.
6.
Packaging
7.
Application Note6. Packaging5.
Mechanical Drawing
Mechanical
Drawing
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
7.
Application Note
7.
7.
Mechanical
Drawing
6.
Packaging5.
SPE-11-8-039/C
Mechanical Drawing
www.taoglas.com
11
7.
Packaging
6.
Packaging5.
6.
Packaging
7.
Mechanical Drawing
Mechanical
Drawing
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
7.
Application Note
7.
7.
Mechanical
Drawing
6.
Packaging5.
SPE-11-8-039/C
Mechanical Drawing
www.taoglas.com
12
Changelog for the datasheet
SPE-11-8-039 – TI.08.C.0112
Revision: C (Current Version)
Date:
Changes:
Changes Made by:
2019-04-02
Added new introduction and data
Jack Conroy
Previous Revisions
Revision: B
Date:
Changes:
Changes Made by:
2011-11-15
Packaging amended
Aine Doyle
Revision: A (Original First Release)
Date:
2011-07-16
Notes:
Author:
SPE-11-8-039/C
Aine Doyle
www.taoglas.com
13
Previous Revisions (Continued)
SPE-11-8-039/C
www.taoglas.com
14
SPE-11-8-039/C
www.taoglas.com
15
www.taoglas.com
SPE-11-8-039/C
www.taoglas.com
16
很抱歉,暂时无法提供与“TI.08.C.0112”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+56.449451+7.31218
- 10+43.3475910+5.61503
- 25+40.0613025+5.18934
- 100+36.44995100+4.72155
- 300+34.43616300+4.46069
- 500+33.69174500+4.36426
- 1000+32.837761000+4.25364
- 2500+31.936682500+4.13692
