FXP832.03.0458D
FXP832.03.0458D
    TAOGLASLIMITED
    FXP832.03.0458D
FXP832.03.0458D 数据手册
Freedom FXP832 Part No: FXP832.03.0458D Description: FXP832 Freedom Wi-Fi 2.4GHz and 4.9-6GHz Dipole Antenna Features: Flexible PCB Very High Efficiency 42mm*7mm*0.1mm Ground-plane Independent Cable: 458mm (18 inches) RG174 Connector: RP-SMA(M) Straight RoHS & REACH Compliant SPE-14-8-067-D 1. Introduction 3 2. Specifications 4 3. Antenna Characteristics 5 4. 2D Radiation Patterns 7 5. 3D Radiation Patterns 9 6. Mechanical Drawing 11 7. Packaging 12 Changelog 13 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-14-8-067-E www.taoglas.com 2 1. Introduction 1. Introduction 1. Introduction 1. Introduction 1. 1. 1. 1. Introduction The Freedom FXP832 is a breakthrough, very high efficiency, small, dual-band Wi-Fi dipole omni-directional antenna for 2.4/5GHz bands. This antenna is designed for DSRC, V2V, Wi-Fi, Bluetooth, Zigbee and other applications in these bands. It is designed in such a narrow rectangular form factor to cover most of the current applications on the market. Taoglas FXP series are conformal flexible antennas and can fit irregular housings. Introduction With dimensions of 42*7*.01mm it comes with double-sided 3M tape for easy “peel and stick” mounting. This longer cable length version of the FXP832 is ideal for applications in embedded industrial and automotive environments. Introduction Typical Applications include: • Automotive • Remote Monitoring • Security Introduction Like all embedded omni-directional antennas, care should be taken to keep the antenna away from metal as much as possible, a minimum of 10mm is recommended. The cable length and connector type are fully customizable, for more information contact your regional Taoglas Customer Support Team. SPE-14-8-067-E www.taoglas.com 3 2. Specifications 3. Antenna Characteristics2. Frequency (MHz) Specifications Electrical 2400-2500 4900-6000 Peak Gain (dBi) 3. On 2mm ABS Antenna Characteristics On 2mm ABS 4. 3.66 5.33 Average Gain (dB) -1.25 -1.89 Efficiency (%) Antenna Antenna On 2mm ABS Radiation Patterns3. 74.9 Impedance Characteristics2. Polarization 50Ω Specifications Linear Radiation Pattern 3. Omni Input Power Antenna Characteristics2. 2W Specifications Mechanical Dimensions 3. 4. 64.7 42mm x 7mm Antenna Characteristics Antenna Body Material Polymer Cable Black 458mm (18 inches) RG174 Coaxial Cable Connector RP-SMA(M) Straight Weight Antenna Radiation Patterns3.Antenna7.5g Characteristics Temperature Range Environmental -40°C to 85°C Humidity Non-condensing 65°C 95% RH 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics2. SPE-14-8-067-E Specifications www.taoglas.com 4 3. Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna 3.1 Return Loss Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics 3.2 Efficiency 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna SPE-14-8-067-E www.taoglas.com 5 3.3 Peak Gain SPE-14-8-067-E www.taoglas.com 6 4. 2D Radiation Patterns 4. 4. 4.1 Antenna Radiation Patterns Test Setup 4. Antenna Radiation Patterns 4. Antenna Radiation Patternsy 4. Antenna Radiation Patterns x z 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Free space Antenna Radiation Patterns SPE-14-8-067-E www.taoglas.com 7 XY Plane X X Y Y XZ Plane Z 330 10 30 0 -10 300 Z 0 330 60 30 0 -10 300 -20 60 -20 -30 270 10 0 -30 90 -40 240 X 120 270 2400MHz 90 -40 240 X 120 5150MHz 2450MHz 210 150 180 210 (dB) 2500MHz 150 180 5550MHz (dB) 5850MHz YZ Plane Z Z Y SPE-14-8-067-E Y www.taoglas.com 8 5. 3D Radiation Patterns 5.1 Free Space 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 2400MHz 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 2500MHz 4. 2450MHz 4900MHz Antenna Radiation Patterns 5150MHz SPE-14-8-067-E 5550MHz www.taoglas.com 9 5850MHz SPE-14-8-067-E www.taoglas.com 10 6. Mechanical Drawing (Units: mm) 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-14-8-067-E Mechanical Drawing www.taoglas.com 11 7. Packaging 50pcs FXP832.03.0458D per PE Bag 450*280mm 6. Bag Dimensions: Packaging5. 6. Mechanical Drawing 450mm Weight: 375g Packaging 280mm 7. 500pcs FXP832.03.0458D per carton Dimensions: 320*250*230mm Weight: 3.75Kg Application Note6. Packaging5. Mechanical Drawing 230mm 6. Packaging5. Mechanical Drawing 320mm 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. 250mm Mechanical Drawing 6. Packaging5. SPE-14-8-067-E Mechanical Drawing www.taoglas.com 12 Changelog for the datasheet SPE-17-8-042 – FXP832.03.0458D Revision: E (Current Version) Date: Changes: Changes Made by: 2019-11-14 Updated Images Russell Meyler Previous Revisions Revision: D Date: Changes: Changes Made by: 2019-07-23 Packaging Amended Jack Conroy Revision: C Date: Changes: Changes Made by: 2015-06-30 Added DSRC Aine Doyle Revision: B Date: Changes: Changes Made by: 2015-01-20 added note on gain and 3D radiation patterns Aine Doyle Revision: A (Original First Release) Date: Notes: 2014-04-07 Author: Aine Doyle SPE-14-8-067-E www.taoglas.com 13 www.taoglas.com SPE-14-8-067-E © Taoglas www.taoglas.com 14
FXP832.03.0458D 价格&库存
很抱歉,暂时无法提供与“FXP832.03.0458D”相匹配的价格&库存,您可以联系我们找货
FXP832.03.0458D
    • 1+55.39320
    • 200+21.43800
    • 500+20.69280
    • 1000+20.31480
