ANT-DB1-VDP-SMA
ANT-DB1-VDP-SMA
    LINXTECHNOLOGIES(灵思)
    SMA(DO-214AC)
    VDP系列是一款紧凑、中心馈电的天线,可在三个频率范围内高效运行。其耐用、隐蔽的外壳可永久粘贴在非导电平面上,如窗户、干墙、天花板瓷砖、塑料等。天线配备3米RG-174电缆,从底部进入,便于垂直安装。...
ANT-DB1-VDP-SMA 数据手册
ANT-DB1-VDP-xxx Data Sheet by Product Description 22.0 mm (0.87") The VDP Series is a compact, center-fed antenna that achieves efficient operation at any or all three frequency bands. Its durable, unobtrusive housing attaches permanently with integral adhesive to flat, non-conductive surfaces such as windows, drywall, ceiling tiles, plastic, etc. The antenna is supplied with 9.8 feet (3m) of RG-174 cable that enters from the bottom to facilitate vertical orientation. It can be terminated in a TNC, standard SMA, or FCC Part 15 compliant RP-SMA connector. 4.52 mm (0.18") 115.0 mm (4.53") Features • Tri-band (824–960MHz, 1.71–1.99GHz and 2.40–2.48GHz) • Center-fed from the bottom • Surface-mount • Low VSWR • Excellent performance • Omni-directional pattern • Fully weatherized, durable & unobtrusive • TNC, SMA or RP-SMA connector Electrical Specifications Recom. Freq. Range: Band 1: 824–960MHz Band 2: 1.71–1.99GHz Band 3: 2.40–2.48GHz Wavelength: ½-wave VSWR: Band 1: ≤1.5 typ. at center Band 2: ≤1.9 typ. at center Band 3: ≤1.9 typ. at center Peak Gain: Band 1: –1.8dBi Band 2: –1.7dBi Band 3: –1.3dBi Impedance: 50-ohms Connector: TNC, SMA or RP-SMA Cable: 9.8' (3 m) RG-174 coax Oper. Temp. Range: –40°C to +80°C 14.0 mm (0.55") TNC connector 7.9 mm (0.31") SMA, RP-SMA connector Ordering Information ANT-DB1-VDP-TNC (with TNC connector) ANT-DB1-VDP-SMA (with SMA connector) ANT-DB1-VDP-RPS (with RP-SMA connector) –1– Revised 1/23/14 VSWR Graph VSWR 3:1 1.530 2.028 2.024 Reflected Power 25% 2:1 11% 1:1 0% CENTER 910.000MHz CENTER 1 825.000MHz CENTER 2 450.000MHz SPAN 200.000MHz What is VSWR? The Voltage Standing Wave Ratio (VSWR) is a measurement of how well an antenna is matched to a source impedance, typically 50-ohms. It is calculated by measuring the voltage wave that is headed toward the load versus the voltage wave that is reflected back from the load. A perfect match will have a VSWR of 1:1. The higher the first number, the worse the match, and the more inefficient the system. Since a perfect match cannot ever be obtained, some benchmark for performance needs to be set. In the case of antenna VSWR, this is usually 2:1. At this point, 88.9% of the energy sent to the antenna by the transmitter is radiated into free space and 11.1% is either reflected back into the source or lost as heat on the structure of the antenna. In the other direction, 88.9% of the energy recovered by the antenna is transferred into the receiver. As a side note, since the “:1” is always implied, many data sheets will remove it and just display the first number. How to Read a VSWR Graph VSWR is usually displayed graphically versus frequency. The lowest point on the graph is the antenna’s operational center frequency. In most cases, this will be different than the designed center frequency due to fabrication tolerances. The VSWR at that point denotes how close to 50-ohms the antenna gets. Linx specifies the recommended bandwidth as the range where the typical antenna VSWR is less than 2:1. 159 Ort Lane, Merlin, OR, US 97532 Phone: +1 541 471 6256 Fax: +1 541 471 6251 www.linxtechnologies.com –2– Data Sheet ANT-DB1-VDP-xxx by
ANT-DB1-VDP-SMA 价格&库存
很抱歉,暂时无法提供与“ANT-DB1-VDP-SMA”相匹配的价格&库存,您可以联系我们找货
