SPECIFICATION
Part No.
TG.19.0112
Product Name
Mini Helical Quad-Band Cellular Antenna
Connector Mount Monopole
GSM-DCS-PCS -CDMA-GPRS-EDGE
824 MHz ~ 1990 MHz (850/900/1800/1900)
Features
0dBi Gain
SMA(M) Fixed Right Angle plug, 50 ohms
28.5*17.0*7.8 mm
RoHS Compliant
SPE-13-8-016/B/EZ
Page 1 of 10
1. INTRODUCTION
The TG.19 Quad-band GSM-DCS-PCS-CDMA-GPRS-EDGE 824MHz to 1990MHz monopole helical
antenna is a quality robust antenna with high gain in a small form factor. Its tiny size allows it to
be used inside as well as outside product housings.
Connection is made via fixed right angle SMA(M) connector with a hardened waterproof PU
casing. Care should be taken that the antenna is connected to the device main-board ground,
through the mating connector grounding on the device main-board.
For smaller ground-plane devices or for devices where a ground-connection to antenna is not
possible we recommend the TG.10 or TG.30 dipole antennas which do not need to couple to
ground.
SPE-13-8-016/B/EZ
Page 2 of 10
2. SPECIFICATION
ELECTRICAL
TG19
Antenna
GSM/DCS/PCS/CDMA/GPRS/EDGE
Standard
Operation Frequency
(MHz)
Polarization
824~880
880~960
1710~1880
1880~1990
Linear
Linear
Linear
Linear
Impedance
50 Ohms
50 Ohms
50 Ohms
50 Ohms
VSWR
2.0:1
2.3.0:1
2.3:1
很抱歉,暂时无法提供与“TG.19.0112”相匹配的价格&库存,您可以联系我们找货
