FXP810.09.0100C
FXP810.09.0100C
    TAOGLASLIMITED
    FXP810.09.0100C
FXP810.09.0100C 数据手册
SPECIFICATION FXP.810 2.4/4.9-6GHz Dual-band Antenna Part No. : FXP.810.09.0100C Product Name : FXP.810 Freedom WIFI 2.4/4.9-6GHz Series PIFA Antenna Feature : Very High Efficiency Ground-plane Independent MMCX(M)RA Connector 1.37mm Diameter Micro Cable - 100 mm 31mm*31mm*0.1 mm RoHS Compliant SPE-11-8-051/E Page 1 of 11 1. Introduction The FXP810 has a peak gain of 1.5dBi at 2.4GHz and efficiencies of 60-70%, increasing to 5dBi and 80-90% along bands 4.9GHz to 6GHz. At 31*31*0.1mm in size this antenna is uniquely valuable for small tag type mobile devices in that it can slip between the battery and the main PCB ground of small devices to get increased performance from the ground coupling effect. Only the top 6.5mm radiating element needs to protrude out from the side of the main board, allowing such devices to have the highest possible performance at smallest possible dimensions, it accomplishes this because it does not need clearance or footprint space on the device board itself that all on-board chip, loop and patch antennas need. Many module manufacturers specify peak gain limits for any antennas that are to be connected to that module. Those peak gain limits are based on free-space conditions. In practice, the peak gain of an antenna tested in free-space can degrade by at least 1 or 2dBi when put inside a device. So ideally you should go for a slightly higher peak gain antenna than mentioned on the module specification to compensate for this effect, giving you better performance. Upon testing of any of our antennas with your device and a selection of appropriate layout, integration technique, or cable, Taoglas can make sure any of our antennas’ peak gain will be below the peak gain limits. Taoglas can then issue a specification and/or report for the selected antenna in your device that will clearly show it complying with the peak gain limits, so you can be assured you are meeting regulatory requirements for that module. For example, a module manufacturer may state that the antenna must have less than 2dBi peak gain, but you don’t need to select an embedded antenna that has a peak gain of less than 2dBi in free-space. This will give you a less optimized solution. It is better to go for a slightly higher free-space peak gain of 3dBi or more if available. Once that antenna gets integrated into your device, performance will degrade below this 2dBi peak gain due to the effects of GND plane, surrounding components, and device SPE-11-8-051/E Page 2 of 11 housing. If you want to be absolutely sure, contact Taoglas and we will test. Choosing a Taoglas antenna with a higher peak gain than what is specified by the module manufacturer and enlisting our help will ensure you are getting the best performance possible without exceeding the peak gain limits. SPE-11-8-051/E Page 3 of 11 2. Specification ELECTRICAL Frequency 2.4 ~ 2.5GHz, 4.9 ~ 5.8GHz Peak Gain (free space) 1.5dBi 5.1dBi Peak Gain (on plastic*) 2.4dBi 5.0dBi Average Gain (free space) -2.6dBi -1.1dBi Average Gain (on plastic) -1.2dBi -0.8dBI Efficiency (free space) 56% 78% Efficiency (on plastic) 76% 84% VSWR ≦1.7 : 1 Impedance 50 Ohms Polarization Linear Radiation Pattern Omni Input Power 2W max. MECHANICAL Dimensions 31mm*31mm*0.1mm Antenna Body Material Polymer Cable Gray 100mm 1.37 co-axial Connector MMCX(M)RA ENVIRONMENTAL Temperature Range -40°C to 85°C Humidity Non-condensing 65°C 95% RH * On ABS Plastic 4mm SPE-11-8-051/E Page 4 of 11 3. Electrical Property 3.1 S11 Measurement Free Space: Plastic 1.5mm: SPE-11-8-051/E Page 5 of 11 3.2 Efficiency FXP. 810 100 Efficiency (Free space) 90 80 70 60 50 40 30 20 10 0 2200 2300 2400 2500 2600 2700 2800 2900 3000 5000 5200 5400 5600 5800 Frequency (MHz) 3.3 Gain FXP. 810 8 7 6 Gain (dBi) 5 4 3 2 1 0 -1 -2 -3 -4 -5 2200 2300 2400 2500 2600 2700 2800 2900 3000 5000 5200 5400 5600 5800 Frequency (MHz) SPE-11-8-051/E Page 6 of 11 3.4 Radiation Pattern y z x 2450 MHz Pattern SPE-11-8-051/E Page 7 of 11 4900 MHz Pattern 5500 MHz Pattern 5900 MHz Pattern SPE-11-8-051/E Page 8 of 11 4. Mechanical Drawing. SPE-11-8-051/E Page 9 of 11 . 5. Packaging SPE-11-8-051/E Page 10 of 11 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. Copyright © Taoglas Ltd. SPE-11-8-051/E Page 11 of 11
FXP810.09.0100C 价格&库存
很抱歉,暂时无法提供与“FXP810.09.0100C”相匹配的价格&库存,您可以联系我们找货
FXP810.09.0100C
  • 1+188.650461+24.39405
  • 10+150.7208410+19.48944
  • 25+141.2351825+18.26286
  • 100+130.81139100+16.91498
  • 300+124.99825300+16.16330
  • 500+122.84839500+15.88530
库存:78
