FXP07.07.0100A
FXP07.07.0100A
    TAOGLASLIMITED
    FXP07.07.0100A
FXP07.07.0100A 数据手册
SPECIFICATION Part No. : FXP07.07.0100A Product Name : Flexible PCB Penta Band GSM Antenna, 100mm Ø1.13 cable, IPEX connector Feature : Very low profile Penta band GSM Adhesive tape for easy mounting RoHS compliant SPE-11-8-114/C Page 1 of 10 1. Introduction FXP07.07.0100A is a general version of stick-on flexible PCB. It is designed with 100mm 1.13mm coaxial cable and the IPEX connector for easy installation. FXP07.07.0100A is ideal for initial test of FPCB type antenna. 2. Specification Penta-band Cellular Communication System AMPS GSM DCS PCS UMTS 824 ~ 896 880~960 1710~1880 1850~1990 1710~2170 plane) 82% 82% 29% 60% 49% Efficiency (free space) 11% 12% 41% 32% 33% Frequency (MHz) Efficiency (ground Impedance 50 Ohm Radiation Pattern Omni-directional Polarization Linear FPCB 41.0 x 24.0 mm Connector IPEX Cable Ø1.13 Cable Length 100 mm Adhesive Tape 3M 467 Operation Temperature -40℃ ~ +85℃ Storage Temperature -40℃ ~ +85℃ SPE-11-8-114/C Page 2 of 10 3. Electrical Property 3.1 Test Setup FXP.07 was design with a cell phone size ground plane (110 x 45 mm) so works the best with this ground plane. Tests were setup to demonstrate its RF properties with this ground plane, in free space and adhere to a plastic. Satimo SG64 3D-chamber is used for radiation and efficiency test with 5% tolerance. FXP.07 with original ground plane SPE-11-8-114/C Page 3 of 10 3.2 Mounting instructions and ground-plane connection Peel back 3m paper. On the underside of the antenna is automotive grade 3m adhesive (glue) for sticking the FXP.07 directly to plastic (e.g. housing). The antenna can be curved around housing but should not be folded sharply Ground connection - this small square pad at the bottom of the FXP.07 can be seen when paper is removed. This should be connected to extra ground or metal to increase efficiency (e.g. allow pad to touch the side of a PCB like the picture above This is the antenna trace or signal feed and should be allowed to be free from the PCB and allowed to exist in free area on non metal area (plastic housing)_ SPE-11-8-114/C Page 4 of 10 z y x Free space antenna setup and Satimo SG64 3D-chamber. z y x FXP.07 places on a plastic in the chamber. SPE-11-8-114/C Page 5 of 10 3.3 Radiation Pattern x-y plane x-z plane FXP-07 with ground plane FXP-07 in free space FXP-07 adhere on plastic SPE-11-8-114/C Page 6 of 10 3.4 Efficiency 100% 80% 60% 40% 20% Ground Plane Free Space 0% 600 1000 1400 1800 2200 Plastic Miniature antennas couple to the ground plane for radiation so the efficiency of the antenna without a ground plane is largely degrades. These tests demonstrate the best performance (with the designed ground) and the worst performance (with no ground) possible of FXP.07. Adhere the antenna to a plastic changes the result, particularly in higher frequency bands. SPE-11-8-114/C Page 7 of 10 3.5 Return Loss -2 -6 -10 -14 -18 -22 -26 -30 400 G round Plane Free Space 800 1200 1600 2000 2400 Plastic Return loss result also indicates that FXP.07 needs to connect to a ground plane for proper operation. SPE-11-8-114/C Page 8 of 10 4. Mechanical Drawing SPE-11-8-114/C Page 9 of 10 5. Packaging SPE-11-8-114/C Page 10 of 10
FXP07.07.0100A
- 物料型号:FXP07.07.0100A - 器件简介:这是一款通用的粘贴式柔性PCB天线,设计用于初始测试FPCB类型天线,具有非常低的轮廓和易于安装的IPEX连接器。 - 引脚分配:文档中没有明确提到引脚分配,但提到了天线的接地连接点。 - 参数特性: - 通信系统:五频带蜂窝 - 频率范围:824~896 MHz(AMPS)、880~960 MHz(GSM)、1710~1880 MHz(DCS)、1850~1990 MHz(PCS)、1710~2170 MHz(UMTS) - 效率:在地面平面上为82%(GSM),在自由空间中为11%(GSM) - 阻抗:50欧姆 - 辐射模式:全向 - 极化:线性 - FPCB尺寸:41.0x24.0 mm - 连接器类型:IPEX - 电缆类型:01.13 - 电缆长度:100mm - 胶带:3M467 - 工作温度范围:-40°C~+85°C - 功能详解:文档详细描述了天线的电气特性,包括测试设置、安装说明、接地平面连接、辐射模式和效率、回波损耗等。 - 应用信息:适用于需要五频带GSM天线的设备,如手机等。 - 封装信息:提供了机械绘图和包装规格,包括PCB尺寸、切割线、材料、完成、数量等。
FXP07.07.0100A 价格&库存
很抱歉,暂时无法提供与“FXP07.07.0100A”相匹配的价格&库存,您可以联系我们找货
FXP07.07.0100A
  • 1+109.454131+14.17814
  • 10+85.9283710+11.13073
  • 25+80.0385625+10.36780
  • 100+73.56484100+9.52922
  • 300+69.95506300+9.06163
  • 500+68.62050500+8.88876
  • 1000+67.089811000+8.69048
库存:129
