Specification
Part No.
PC29.07.0100A
Product Name
TheStripe™ Penta-Band
GSM 850 / 900 / 1800 / 1900 & UMTS / WCDMA (3G)
2100 MHz
80mm*30mm PCB Antenna
Feature
100mm long, 1.13 mm diameter
Miniature Co-axial Cable IPEX MHF I (U.FL) connector
Average Efficiency 62%
Tested in Free space
Dims: 80*30mm
RoHS Compliant
SPE-11-8-066/B
Page 1 of 11
1. Introduction
This high performance, low profile, PCB antenna is based on smart TheStripe™
antenna technology. It consists of a PCB antenna and mini coaxial cable. The product
is a high gain Penta-band 850/900/1800/1900/2100 antenna suitable for worldwide
GSM, UMTS and WCDMA applications. Its high efficiency (62% average) makes it an
ideal choice to pass telecom operator’s testing approvals. The product should be tested
in free space conditions connected to the client’s cellular device.
Further optimization can be done upon receipt of the client’s device at a local Taoglas
facility.
2. Specifications
CELLULAR
Communication system
AMPS
GSM
DCS
PCS
UMTS/WCDMA
Frequency Band
850MHz
900MHz
1800MHz
1900MHz
2100MHz
VSWR
1.58
1.78
1.51
1.38
1.37
Return Loss
-12.96
-11.00
-13.79
-15.81
-16.11
Efficiency
56.84%
72.98%
63.52%
55.79%
63.25%
Peak Gain
0.01dBi
1.2dBi
2.66dBi
1.25dBi
1.43dBi
Average Gain
-2.45dB
-1.37dB
-1.97dB
-2.53dB
-1.99dB
Impedance
50 Ohm
Radiation Pattern
Omnidirectional
Polarization
Horizontal
MECHANCIAL
Dimensions
RF Cable
RF Connector
80 * 30mm
RF Coaxial Cable ψ1.13 ± 0.1mm, L = 100 mm
Gray Color
IPEX MHF I (U.FL)
ENVIRONMENTAL
Operation Temperature
-40°C to + 85°C
Storage Temperature
-40°C to + 95°C
Relative Humidity
40% to 95%
SPE-11-8-066/B
Page 2 of 11
3. Antenna Characteristics
3.1. Return loss
SPE-11-8-066/B
Page 3 of 11
4. Reliability
Test Items
Procedure
Thermal Shock
Starting at -40 for 30minutes and
then cycled to +85 to remain
30minutes (a complete cycle). To
repeat 5 complete cycles. (Refer to
IEC 68-2-14 Method Na)
1. The value of return loss
must be within product
specifications after this test.
2. No physical deformation
should be evident.
Requirement
Storage Temperature
(Cold)
Samples must be put into -30°C
chamber for 72 hours and samples
shall be powered during test.
(Refer to IEC 68-2-1 Method Aa)
Storage Temperature
(Dry Heat)
Samples must be put into +75°C
(Refer to IEC 68-2-1 Method Ba)
1. The value of return loss must
be within product
should be evident.
be within product
should be evident.
Operating Temperature
(Cold)
Samples must be put into -20°C
chamber for 2 hours and samples
met specification during
test/after test
2. No mechanical defects after
test.
(Dry Heat)
Samples must be put into +65°C
test/after test
test.
SPE-11-8-066/B
Page 4 of 11
5. Antenna Test Procedures and Setup
5.1. Test Procedure for VSWR/Return Loss
STEP 1 Route Cable in Correct Position
STEP 2 Connect Antenna to Module
Connect feed-line to network analyze
STEP 3 - Assemble Antenna in Correct Position
STEP 4 - Assemble Housing
5.2. 3D Radiation Pattern Testing
Test Setup Diagram
SPE-11-8-066/B
Page 5 of 11
5.3. 3D Radiation Pattern Testing
850MHz
900MHz
SPE-11-8-066/B
Page 6 of 11
1800MHz
1900 MHz
2100MHz
SPE-11-8-066/B
Page 7 of 11
5.4. 3D Chamber Testing – Tabular Results
SPE-11-8-066/B
Page 8 of 11
6. Mechanical Drawings (Unit: mm)
6.1. Dimensions and Drawing
6.2. Antenna Placement
Antenna designed to for testing when connected outside the client’s device and placed
in frees pace conditions, for example on plastic foam block. Final product can use preapplied double sided adhesive tape, slot or screw mount.
SPE-11-8-066/B
Page 9 of 11
7. Packaging (Unit: mm)
SPE-11-8-066/B
Page 10 of 11
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document
and reserves the right to make changes to specifications and product descriptions at any time without
notice.
Taoglas reserves the rights to this document and the information contained herein. Reproduction, use or
disclosure to third parties without express permission is strictly prohibited.
Copyright © Taoglas Ltd.
SPE-11-8-066/B
Page 11 of 11
很抱歉,暂时无法提供与“PC29.07.0100A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+60.469481+7.82265
- 10+46.4912610+6.01436
- 25+43.0052825+5.56339
- 100+39.17047100+5.06730
- 300+37.03106300+4.79054
- 500+36.24000500+4.68820
- 1000+35.332831000+4.57084
- 2500+34.375342500+4.44698
