Specification
Part No.
Product Name
PC81.07.0100A.db
TheStripe™ 868Mhz PCB Antenna
100mm IPEX 1.13mm diameter MHF connector
foam attachment for assembly
Features
34mm*7mm*0.8mm(PCB)
16mm*6mm*7mm(foam)
Compatible with Hirose U.FL
With 3M Adhesive, easy stick on client enclosure
Photo:
SPE-12-8-85/B/SS
Page 1 of 9
1. Introduction
This miniaturized low profile PCB antenna is based on smart TheStripe™ antenna
technology. It consists of a PCB antenna and a 1.13mm mini coaxial cable with Ipex MHF
(Hirose U.FL comp) connector. The PC81 comes with a foam attachment which has £M
adhesive on the underside which assists in placing the antenna with sufficient clearance for
optimal performance.
Cable lengths and connectors are fully customizable.
2. Specification
Parameter
Electrical Specification
Applications
868MHz ISM Band
Frequency Band
868-870MHz
Efficiency
50.46%
Return Loss
很抱歉,暂时无法提供与“PC81.07.0100A.DB”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 100+43.98783100+5.69100
- 300+41.70728300+5.39595
- 500+40.63599500+5.25735
- 1000+39.475431000+5.10720
- 国内价格 香港价格
- 100+43.23376100+5.59344
- 300+40.99230300+5.30345
- 500+39.93938500+5.16723
- 1000+38.798711000+5.01965
- 国内价格 香港价格
- 15+67.0597715+8.67597
- 25+64.1196025+8.29558
- 100+44.70365100+5.78361
- 300+41.80873300+5.40908
- 500+41.12051500+5.32004
