FXP280 Flexible PCB 868MHz Antenna
Part No:
FXP280.07.0100A
Description:
868MHz LoRA, Sigfox, ISM Flexible PCB Antenna
with 100mm of Ø1.13 cable and IPEX MHFI Connector
Features:
Operates between 863-870MHz
Covers LoRA, Sigfox ISM band 868MHz
Dimensions: 75*45*0.2mm
Cable: 100mm of Ø1.13
Connector: IPEX MHFI (U.FL Compatible)
RoHS & Reach Compliant
SPE-13-8-060-C
1.
Introduction
3
2.
Specifications
4
3.
Antenna Characteristics
5
4.
Radiation Patterns
7
5.
Mechanical Drawing
9
6.
Packaging
10
Changelog
11
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to
make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and
the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
SPE-13-8-060-C
www.taoglas.com
2
1.
Introduction
1.
Introduction
1.
Introduction
1.
Introduction
1.
1.
1.
Introduction
The Taoglas FXP280 is a rectangular Flexible PCB Antenna designed to be used at the 868MHz band on the
LoRA/Sigfox Network and the ISM Network. This small antenna has been designed to be flexible and fit in
many different enclosures and be mounted on many different surfaces. The FXP280 comes with 3M adhesive
for ease of installation and is fed by a cable and connector.
Introduction
Typical Applications Include:
- Medical Devices
- Smart Monitoring
- Smart Home
Introduction
The FXP280 has been tested with2mm thick ABS and these results are provided. The Cable and connector is
fully customizable for further information please contact your regional Taoglas customer support team.
1.
Introduction
SPE-13-8-060-C
www.taoglas.com
3
2.
Specifications
3.
Antenna Characteristics2.
Specifications
Electrical
Frequency (MHz)
3.
863~870
Antenna
Characteristics
Return Loss (dB)
-16
Efficiency (%)
4.
Gain (dBi)
Antenna
Radiation Patterns3.Antenna
Impedance
Characteristics2.
3.
52
1.8
50 Ω
Specifications
VSWR
≤2:1
Polarization
Linear
Max Power Input
Antenna
Characteristics2.
5W
Specifications
Mechanical
Dimensions
3.
75*45*0.1mm
Antenna
Characteristics
Weight
1.5g
Connector
4.
Antenna
Cable Standard
Mini-Coax 1.13 mm
Characteristics
Cable Length and color
100mm, Black
RoHS Compliant
4.
Yes
REACH Compliant
Antenna
Radiation Patterns
Yes
Adhesive
4.
3M 467
Environmental
Antenna Radiation Patterns3.Antenna
Operation Temperature
-40°C ~ +85°C
Characteristics
Storage Temperature
4.
-40°C ~ +85°C
Characteristics2.
SPE-13-8-060-C
Specifications
www.taoglas.com
4
3.
4.
3.1
Return Loss
Characteristics
Antenna
Radiation Patterns
Return Loss [dB]
4.
4.
-10
-15
Antenna
Characteristics
-20
-25
4.
Antenna
-30
820
Characteristics
3.2
4.
835
850
865
880
895
910
Frequency [MHz]
VSWR
Antenna
Radiation Patterns
9.0
8.0
4.
7.0
Antenna
Radiation Patterns
4.
VSWR
6.0
5.0
Antenna
Radiation Patterns
4.0
3.0
4.
2.0
Antenna
1.0
820
Characteristics
835
850
865
880
895
910
Frequency [MHz]
4.
SPE-13-8-060-C
www.taoglas.com
5
3.3
Efficiency
100
90
80
Efficiency [%]
70
60
50
40
30
830
840
850
860
870
880
890
900
910
880
890
900
910
Frequency [MHz]
3.4
Peak Gain
3
2.5
Gain [dBi]
2
1.5
1
0.5
830
840
850
860
870
Frequency [MHz]
SPE-13-8-060-C
www.taoglas.com
6
4.
Radiation Patterns
4.
4.
4.1
Test Setup on 2mm Thick ABS
4.
4.
4.
4.
4.
4.
SPE-13-8-060-C
www.taoglas.com
7
4.2
868MHz 3D and 2D Radiation Patterns
XY Plane
SPE-13-8-060-C
XZ Plane
YZ Plane
www.taoglas.com
8
5.
Mechanical Drawing (Units: mm)
6.
Packaging5.
6.
Packaging
7.
Application Note6. Packaging5.
Mechanical Drawing
Mechanical
Drawing
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
7.
Application Note
7.
7.
Mechanical
Drawing
6.
Packaging5.
SPE-13-8-060-C
Mechanical Drawing
www.taoglas.com
9
6.
Packaging
100pcs FXP280.07.0100A per PE Bag
- 300*160mm
6. Dimensions
Packaging5.
Weight - 110g
Mechanical Drawing
6.
Packaging
7.
Mechanical
Drawing
1000pcs FXP280.07.0100A per Large PE Bag
Dimensions - 450*250mm
Weight - 1.2Kg
6.
Packaging5.
6.
Packaging
Mechanical Drawing
FXP280.07.0100A per carton
7. 5000pcs
Application
Note6. Packaging
Dimensions - 320*250*230mm
Weight - 6.1Kg
7.
Application Note
230mm
7.
320mm
7.
250mm
Mechanical
Drawing
6.
Packaging5.
SPE-13-8-060-C
Mechanical Drawing
www.taoglas.com
10
Changelog for the datasheet
SPE-13-8-060 – FXP280.07.0100A
Revision: C (Current Version)
Date:
Changes:
Changes Made by:
2022-02-04
Updated data
Gary West
Previous Revisions
Revision: B
Date:
Changes:
Changes Made by:
2020-03-31
Packaging Details, Drawing & Photo Updated
Jack Conroy
Revision: A (Original First Release)
Date:
2013-09-03
Notes:
Author:
SPE-13-8-060-C
Technical Writer
www.taoglas.com
11
www.taoglas.com
SPE-13-8-060-C
© Taoglas 12
www.taoglas.com
很抱歉,暂时无法提供与“FXP280.07.0100A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+83.171221+10.77358
- 国内价格
- 10+73.84437
- 55+58.44066
- 100+54.66759
- 国内价格
- 10+48.92020
- 55+43.09234
- 100+40.21468
- 国内价格 香港价格
- 10+79.4712110+10.29430
- 55+62.8965355+8.14730
- 100+58.88372100+7.62750
