FXP523.A.07.A.001
FXP523.A.07.A.001
    TAOGLASLIMITED
    FXP523.A.07.A.001
FXP523.A.07.A.001 数据手册
Part No: FXP523.A.07.A.001 Description: Venti Flex PCB Wi-Fi MIMO 2.4/5.8/7.1GHz Antenna with 3 ports with Wi-Fi 6 frequency bands included Features: Covers Extended Wi-Fi Frequencies of 2.4-2.5GHz, 5-7.125GHz Flex PCB MIMO Antenna Adhesive Tape for ease of installation Dimensions: 80*20*0.2mm Cables: 120mm of Ø1.13mm Connectors: I-PEX MHF® I (U.FL Compatible) RoHS & Reach Compliant SPE-14-8-107-D 1. Introduction 3 2. Specifications 5 3. Antenna Characteristics 6 4. Radiation Patterns 9 5. Mechanical Drawing 11 6. Packaging 12 Changelog 13 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-14-8-107-D www.taoglas.com 1. Introduction 1. Introduction 1. Introduction 1. Introduction 1. 1. 1. 1. Introduction The FXP523 Venti antenna is a 3-in-1 MIMO, flexible PCB monopole type antenna designed to operate at widely used Wi-Fi frequencies. The FXP524 is a future proof antenna as it has been proven to cover the frequencies required for Wi-Fi 6 applications. The antenna has excellent efficiency and isolation performance for all Wi-Fi applications. Featuring a low profile height of only 0.15mm, the FXP523 is an ideal solution for maintaining high performance while fitting into narrow spaces such as plastic enclosures for laptops, tablets, routers, and other Wi-Fi applications. Introduction The antenna has been designed in a flexible material with a rectangular form-factor and cable connection for an easy installation. The antenna comes with double-sided 3M tape for easy and robust "peel and stick" mounting. The antenna cables feature IPEX connectors for easy installation. Introduction Typical applications include: - Smart Home - Routers and Gateways - Smart Devices - HD Video Streaming Introduction Many module manufacturers specify peak gain limits for any antennas that are to be connected to that module. Those peak gain limits are based on free-space conditions. In practice, the peak gain of an antenna tested in free-space can degrade by at least 1 or 2dBi when put inside a device. So ideally you should go for a slightly higher peak gain antenna than mentioned on the module specification to compensate for this effect, giving you better performance. Upon testing of any of our antennas with your device and a selection of appropriate layout, integration technique, or cable, Taoglas can make sure any of our antennas’ peak gain will be below the peak gain limits. Taoglas can then issue a specification and/or report for the selected antenna in your device that will clearly show it complying with the peak gain limits, so you can be assured you are meeting regulatory requirements for that module. SPE-14-8-107-D www.taoglas.com For example, a module manufacturer may state that the antenna must have less than 2dBi peak gain, but you don’t need to select an embedded antenna that has a peak gain of less than 2dBi in free-space. This will give you a less optimized solution. It is better to go for a slightly higher free-space peak gain of 3dBi or more if available. Once that antenna gets integrated into your device, performance will degrade below this 2dBi peak gain due to the effects of GND plane, surrounding components, and device housing. If you want to be absolutely sure, contact Taoglas and we will test. Choosing a Taoglas antenna with a higher peak gain than what is specified by the module manufacturer and enlisting our help will ensure you are getting the best performance possible without exceeding the peak gain limits. The Cables and connectors are fully customizable subject to MOQ, for further information please contact your regional Taoglas customer support team for more information. SPE-14-8-107-D www.taoglas.com 2. Specifications Electrical 3. BandAntenna Efficiency Average GainSpecifications Peak Gain Frequency Characteristics2. Max Power Setup Impedance (MHz) Right Port (%) (dB) (dBi) 41 -3.9 0.2 -4 5.7 2400~2500 Characteristics Centre Port 39 3.2.4GHz Wi-Fi Antenna 4. Left Port 28 -5.7 6.6 Right Port 58 -2.3 1 Centre Port 45 -3.4 4.4 Input Polarization Radiation Pattern Linear Omnidirectional Antenna Radiation Patterns3.Antenna 5.8GHz Wi-Fi 5150~5850 Characteristics2.Left PortSpecifications 49 -3.1 Right Port 31 -5.3 50Ω 2W 5.1 -0.8 7.1GHz Wi-Fi 6 5925~7125 Centre Port 35 -4.7 4.3 3. Antenna Characteristics2. Specifications Left Port 39 -4.1 4.5 Mechanical 3. Dimensions Characteristics Antenna 80mm X 20mm X 0.1mm Antenna Body Material 4. Polymer Cable 3* Black 1.13mm Coaxial Cable Antenna Radiation Patterns3.Antenna Cable Length 120mm Connector IPEX MHFHT Weight 8g Characteristics 4. Antenna Radiation Patterns Environmental Temperature Range 4. -40°C to 85°C Humidity Non-condensing 65°C 95% RH Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics2. SPE-14-8-107-D Specifications www.taoglas.com 3. Antenna Characteristics 3.1 4. Return Loss Antenna Radiation Patterns3.Antenna 0.00 Characteristics 4. 4. Return Loss [dB] -5.00 Antenna Radiation Patterns -10.00 -15.00 Antenna Radiation Patterns3.Antenna -20.00 Characteristics Right Port -25.00 Center Port Left Port 4. -30.00 2000 3000 3500 4000 4500 5000 5500 Antenna2500 Radiation Patterns3. Antenna Frequency [MHz] 6000 6500 7000 7500 8000 Characteristics 3.2 4. VSWR Antenna Radiation Patterns 10.00 4. 9.00 Left Port 8.00 Center Port Antenna Radiation Patterns 7.00 Right Port 4. VSWR 6.00 5.00 4.00 Antenna Radiation Patterns 3.00 2.00 4. 1.00 Antenna Radiation Patterns3.Antenna 0.00 2000 2500 Characteristics 4. 3000 3500 4000 4500 5000 5500 Frequency [MHz] Antenna Radiation Patterns3.Antenna SPE-14-8-107-D 6000 6500 7000 7500 8000 www.taoglas.com 3.3 Efficiency 100 Left Port 90 Right Port 80 Center Port Efficiency [%] 70 60 50 40 30 20 10 0 2000 Gain [dBi] 3.4 2500 3000 3500 4000 4500 5000 5500 Frequency [MHz] 6000 6500 7000 7500 8000 7500 8000 Peak Gain 10 9 8 7 6 5 4 3 2 1 0 -1 -2 -3 -4 -5 2000 SPE-14-8-107-D Left Port Center Port Right Port 2500 3000 3500 4000 4500 5000 5500 Frequency [MHz] 6000 6500 7000 www.taoglas.com 3.5 Average Gain 0 -1 -2 Average Gain [dB] -3 -4 -5 -6 -7 Left Port -8 Center Port -9 Right Port -10 2000 SPE-14-8-107-D 2500 3000 3500 4000 4500 5000 5500 Frequency [MHz] 6000 6500 7000 7500 8000 www.taoglas.com 4. Radiation Patterns 4. 4. 4. 4.1 Antenna Radiation Patterns Test Setup – 2mm ABS Antenna Radiation Patterns Y 4. Antenna Radiation Patterns X Z 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns SPE-14-8-107-D www.taoglas.com 4.2 842MHz 3D and 2D Radiation Patterns Right Port XY Plane XZ Plane YZ Plane Centre Port XY Plane XZ Plane YZ Plane Left Port XY Plane SPE-14-8-107-D XZ Plane YZ Plane www.taoglas.com 5. Mechanical Drawing (Units: mm) 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-14-8-107-D Mechanical Drawing www.taoglas.com 6. Packaging 10 pcs per Small PE Bag 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-14-8-107-D Mechanical Drawing www.taoglas.com Changelog for the datasheet SPE-14-8-107 – FXP523.A.07.A.001 Revision: E (Current Version) Date: Changes: Changes Made by: 2022-04-26 Updated product image Jack Conroy Previous Revisions Revision: D Date: Changes: Changes Made by: 2020-07-03 Updated to Include Wi-Fi 6 Jack Conroy Revision: C Date: Changes: Changes Made by: 2015-08-14 Amended Cable Length Aine Doyle Revision: B Date: Changes: Changes Made by: 2015-01-14 Added Note on Intro Aine Doyle Revision: A (Original First Release) Date: Notes: Author: SPE-14-8-107-D 2014-10-21 Technical Writer www.taoglas.com SPE-14-8-107-D © Taoglas www.taoglas.com
FXP523.A.07.A.001 价格&库存
很抱歉,暂时无法提供与“FXP523.A.07.A.001”相匹配的价格&库存,您可以联系我们找货
