DELTA6A/X/SMAM/S/S/11
    SIRETTA
DELTA6A/X/SMAM/S/S/11 数据手册
Delta 6A 2G/3G/4G/(5G) & ISM 915 MHz 196MM HINGED DIRECT CONNECT ANTENNA Key Features • Quad band GSM / GPRS (2G) • 3G, 4G & some 5G Bands • ISM: 915 MHz General Description Additional Considerations The Delta6A multi-band whip antenna has excellent performance across the frequency bands. • Fits to most popular GSM / GPRS and 3G terminal equipment • Adjustable mount allows positioning for best signal • Does not rely on mounting on metallic surface Terminated with an SMA Male or SMARP (reverse polarity) Male connector. The knuckle joint allows for antenna position adjustment through a 0, 45 & 90 degree angles and then swivels to allow vertical positioning. • Meets EU compliance criteria for electronic goods Common IoT applications include: car park / utilities metering, wireless key entry, security systems, remote monitoring and many other IoT applications. Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Delta 6A 2G/3G/4G/(5G) & ISM 915 MHz 196MM HINGED DIRECT CONNECT ANTENNA Electrical Specifications Mechanical Specifications Impedance: 50 Ohm Dimensions: Polarization: Vertical Connector: Ground Plane Independent: Yes SMA Cable: RG316 (Internal) Mounting Method: Environmental Specification Operating temperature range: L196 x 13mm Ø Direct connect -20 - +65 °C X Z Y orientation Return Loss Return Loss in -dB 0 -2 -4 -6 -dB -8 -10 -12 -14 -16 -18 -20 0 1000 2000 3000 4000 5000 6000 MHz Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Delta 6A 2G/3G/4G/(5G) & ISM 915 MHz 196MM HINGED DIRECT CONNECT ANTENNA VSWR VSWR 10.00 9.00 8.00 VSWR 7.00 6.00 5.00 4.00 3.00 2.00 1.00 0 1000 2000 3000 4000 5000 6000 4000 5000 6000 MHz Radiation Efficiency Antenna Radiation Efficiency (in %) 110.00 100.00 90.00 80.00 % Efficiency 70.00 60.00 50.00 40.00 30.00 20.00 10.00 0.00 0 1000 2000 3000 MHz Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Delta 6A 2G/3G/4G/(5G) & ISM 915 MHz 196MM HINGED DIRECT CONNECT ANTENNA LTE/5G Band Coverage M/5G Bands NB-IoT Band 1/n1 B1 2/n2 3/n3 LTE, CAT- Avg Efficieny % over band Max VSWR over Band Uplink Downlink Europe / Asia 1920-1980 MHz 2110-2170 MHz 76.8 / 69.0 3.82 / 3.76 B2 North America/Latin America/Caribbean 1850-1910 MHz 1930-1990 MHz 68.47 / 78.06 4.53 / 3.63 B3 Europe/Africa/Asia/Oceania 1710-1785 MHz 1805-1880 MHz 53.47 / 60.11 4.10 / 4.61 4 B4 North America/Latin America/Caribbean 1710-1755 MHz 2110-2155 MHz 55.44 / 70.62 3.38 / 3.57 5/n5 B5 Country Specific 824-849 MHz 869-894 MHz 31.00 / 59.51 x 13.85 / 5.20 x 6.43 / 7.17 7/n7 Regional Coverage 2500-2570 MHz 2620-2690 MHz 38.20 / 33.36 8/n8 B8 Latin America/Europe/Asia + Europe / Asia + 880-915 MHz 925-960 MHz 74.86 / 82.17 11 B11 Country Specific 1427.9-1447.9 MHz 1475.9-1495.9 MHz 45.96 / 45.78 12/n12 B12 North America/Caribbean + 699-716 MHz 729-746 MHz 3.48 / 2.00 5.09 / 4.87 1.35 / 3.08 x 33.4 / 31.6 24.3 / 29.9 22.3 / 28.4 13/n13 B13 North America/Caribbean + 777-787 MHz 746-756 MHz 8.57 / 3.79 x 14/n14 B14 Country Specific 788-798 MHz 758-768 MHz 10.4 / 5.20 x 17 B17 North America/Caribbean + 704-716 MHz 734.746 MHz 1.45 / 3.08 x 32.9 / 31.6 18/n18 B18 Country Specific 815-830 MHz 860-875 MHz 21.11 / 51.43 x 14.93 / 5.81 19 B19 Country Specific 830-845 MHz 875-890 MHz 31.00 / 59.51 x 11.39 / 4.01 20/n20 B20 Europe/Africa + 832-862 MHz 791-821 MHz 38.35 / 17.83 x 11.39 / 21.0 Country Specific 1447.9-1462.9 MHz 1495.9-1510.9 MHz 45.22 / 46.96 5.01 / 4.61 25/n25 21 B25 Country Specific 1850-1915 MHz 1525-1559 MHz 68.47 / 52.86 4.53 / 4.45 26/n26 B26 Country Specific 814-849 MHz 859-894 MHz 26.45 / 52.20 x 16.12 / 6.46 32.9 / 28.4 32.2 28/n28 B28 29/n29 703-748 MHz 758-803 MHz 3.08 / 9.73 - 717-728 MHz 1.86 x Country Specific 30/n30 31 Latin America/Europe/Asia + x B31 32 Country Specific 2305-2315 MHz 2350-2360 MHz 40.81 / 41.60 Country Specific 452.5-457.5 MHz 462.5-467.5 MHz 15.88 / 9.99 Country Specific - 1452-1496 MHz 45.53 5.50 / 5.80 x 23.4 / 25.0 4.97 x 38/n38 Europe + 2570-2620 MHz 36.39 39/n39 Country Specific 1880-1920 MHz 72.72 4.25 40/n40 Asia + 2300-2400 MHz 41.03 5.98 41/n41 Country Specific 2496-2690 MHz 35.81 42 Country Specific 3400-3600 MHz 63.73 3.7 43 Country Specific 3600-3800 MHz 45.43 4.85 46/n46 Country Specific 5150-5925 MHz 63.88 3.45 48/n48 Country Specific 3550-3700 MHz 49.27 4.73 65/n65 66/n66 71/n71 B66 B71 x Country Specific 1920-2010 MHz 2110-2200 MHz 79.47 / 66.34 Country Specific 1710-1780 MHz 2110-2200 MHz 54.24 / 66.34 Country Specific 663-698 MHz 617-652 MHz 7.17 3.82 / 4.18 3.98 / 4.18 x 1.20 / 1.25 6.57 33.5 / 34.5 Table data for bands as detailed in 3GPP TS 36.101 & 38.101 Usable Band Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Adequate in good signal area x Not Usable Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Delta 6A 2G/3G/4G/(5G) & ISM 915 MHz 196MM HINGED DIRECT CONNECT ANTENNA 5G Extended Table for Band Coverage LTE/5G Band NB-IoT Band n24 Uplink Downlink 1626.5 – 1660.5 MHz 1525 – 1559 MHz Max VSWR over Band Avg Efficieny % over band 63.40 / 52.86 2.67 / 4.45 n34 2010 – 2025 MHz 85.53 2.93 n47 5855 – 5925 MHz 53.61 3.34 n50 1432 – 1517 MHz 46.46 5.09 n51 1427 – 1432 MHz 45.88 5.09 n53 2483.5 – 2495 MHz 37.56 n67 738 – 758 MHz 3.08 n70 B70 n74 6.32 x 30.85 1695 – 1710 MHz 1995 – 2020 MHz 61.75 / 81.66 2.23 / 3.02 1427 – 1470 MHz 1475 – 1518 MHz 45.67 / 46.75 5.09 / 4.87 n75 1432 – 1517 MHz 46.46 5.09 n76 1427 – 1432 MHz 45.88 5.09 n77 3300 – 4200 MHz 53.96 6.75 n78 3300 – 3800 MHz 52.35 6.75 n79 4400 – 5000 MHz 47.4 6.88 n80 1710 – 1785 MHz 53.47 4.10 n81 880 – 915 MHz 74.86 3.48 n82 832 – 862 MHz 38.35 x 11.39 n83 703 – 748 MHz 2.62 x 32.9 1920 – 1980 MHz 76.83 n84 n85 B85 n86 698 – 716 MHz 728 – 746 MHz 1710 – 1780 MHz 3.82 x 1.35 / 3.08 54.24 33.5 / 31.7 3.98 n89 824 – 849 MHz 31.00 x n90 2496 – 2690 MHz 35.81 x 7.17 13.85 n91 832 – 862 MHz 1427 – 1432 MHz 38.35 / 45.88 x 11.39 / 5.09 n92 832 – 862 MHz 1432 – 1517 MHz 38.35 / 46.46 x 11.39 / 5.09 n93 880 – 915 MHz 1427 – 1432 MHz 74.86 / 45.88 3.48 /5.09 n94 880 – 915 MHz 1432 – 1517 MHz 74.86 / 46.46 3.48 / 5.09 n95 2010 – 2025 MHz n96 5925 – 7125 MHz 85.53 n97 2300 – 2400 MHz 41.03 5.98 n98 1880 – 1920 MHz 72.72 4.25 n99 1626.5 – 1660.5 MHz 63.40 2.67 2.93 unmeasured Table data for bands as detailed in 3GPP TS 38.101 Usable Band Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Adequate in good signal area x Not Usable Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Delta 6A 2G/3G/4G/(5G) & ISM 915 MHz 196MM HINGED DIRECT CONNECT ANTENNA Radiation Plots 900 MHz XY XZ YZ 1400 MHz XY XZ YZ 1500 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Delta 6A 2G/3G/4G/(5G) & ISM 915 MHz 196MM HINGED DIRECT CONNECT ANTENNA Radiation Plots 1600 MHz XY XZ YZ 1700 MHz XY XZ YZ 1800 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Delta 6A 2G/3G/4G/(5G) & ISM 915 MHz 196MM HINGED DIRECT CONNECT ANTENNA Radiation Plots 1900 MHz XY XZ YZ 2000 MHz XY XZ YZ 2100 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Delta 6A 2G/3G/4G/(5G) & ISM 915 MHz 196MM HINGED DIRECT CONNECT ANTENNA Radiation Plots 2200 MHz XY XZ YZ 2300 MHz XY XZ YZ 2400 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Delta 6A 2G/3G/4G/(5G) & ISM 915 MHz 196MM HINGED DIRECT CONNECT ANTENNA Radiation Plots 3300 MHz XY XZ YZ 3400 MHz XY XZ YZ 3500 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Delta 6A 2G/3G/4G/(5G) & ISM 915 MHz 196MM HINGED DIRECT CONNECT ANTENNA Radiation Plots 3600 MHz XY XZ YZ 3700 MHz XY XZ YZ 3800 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Delta 6A 2G/3G/4G/(5G) & ISM 915 MHz 196MM HINGED DIRECT CONNECT ANTENNA Radiation Plots 3900 MHz XY XZ YZ 4000 MHz XY XZ YZ 4100 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Delta 6A 2G/3G/4G/(5G) & ISM 915 MHz 196MM HINGED DIRECT CONNECT ANTENNA Radiation Plots 4200 MHz XY XZ YZ 4400 MHz XY XZ YZ 4600 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Delta 6A 2G/3G/4G/(5G) & ISM 915 MHz 196MM HINGED DIRECT CONNECT ANTENNA Radiation Plots 4800 MHz XY XZ YZ 5000 MHz XY XZ YZ 5200 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Delta 6A 2G/3G/4G/(5G) & ISM 915 MHz 196MM HINGED DIRECT CONNECT ANTENNA Radiation Plots 5400 MHz XY XZ YZ 5600 MHz XY XZ YZ 5800 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Delta 6A 2G/3G/4G/(5G) & ISM 915 MHz 196MM HINGED DIRECT CONNECT ANTENNA Radiation Plots 5900 MHz XY Registered in England No. 08405712 VAT Registration No. GB163 04 0349 XZ YZ Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Delta 6A 2G/3G/4G/(5G) & ISM 915 MHz 196MM HINGED DIRECT CONNECT ANTENNA 3D Radiation Plots 900 MHz Theta 65 Phi 45 1600 MHz Theta 65 Phi 45 1900 MHz Theta 65 Phi 45 Registered in England No. 08405712 VAT Registration No. GB163 04 0349 1400 MHz Theta 65 Phi 45 1700 MHz Theta 65 Phi 45 2000 MHz Theta 65 Phi 45 1500 MHz Theta 65 Phi 45 1800 MHz Theta 65 Phi 45 2100 MHz Theta 65 Phi 45 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Delta 6A 2G/3G/4G/(5G) & ISM 915 MHz 196MM HINGED DIRECT CONNECT ANTENNA 3D Radiation Plots 2200 MHz Theta 65 Phi 45 3300 MHz Theta 65 Phi 45 3600 MHz Theta 65 Phi 45 Registered in England No. 08405712 VAT Registration No. GB163 04 0349 2300 MHz Theta 65 Phi 45 3400 MHz Theta 65 Phi 45 3700 MHz Theta 65 Phi 45 2400 MHz Theta 65 Phi 45 3500 MHz Theta 65 Phi 45 3800 MHz Theta 65 Phi 45 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Delta 6A 2G/3G/4G/(5G) & ISM 915 MHz 196MM HINGED DIRECT CONNECT ANTENNA 3D Radiation Plots 3900 MHz Theta 65 Phi 45 4200 MHz Theta 65 Phi 45 4800 MHz Theta 65 Phi 45 Registered in England No. 08405712 VAT Registration No. GB163 04 0349 4000 MHz Theta 65 Phi 45 4400 MHz Theta 65 Phi 45 5000 MHz Theta 65 Phi 45 4100 MHz Theta 65 Phi 45 4600 MHz Theta 65 Phi 45 5200 MHz Theta 65 Phi 45 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Delta 6A 2G/3G/4G/(5G) & ISM 915 MHz 196MM HINGED DIRECT CONNECT ANTENNA 3D Radiation Plots 5400 MHz Theta 65 Phi 45 5600 MHz Theta 65 Phi 45 5800 MHz Theta 65 Phi 45 5900 MHz Theta 65 Phi 45 Ordering Details Part number Description DELTA6A/X/SMAM/S/S/11 2G/3G/4G/(5G) & ISM 915MHz 196MM HINGED DIRECT CONNECT ANTENNA SMA MALE Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0
DELTA6A/X/SMAM/S/S/11 价格&库存
很抱歉,暂时无法提供与“DELTA6A/X/SMAM/S/S/11”相匹配的价格&库存,您可以联系我们找货
  • 1+127.87151
  • 10+125.30971
  • 50+122.79997
库存:56
