AP.35A.07.0054A
AP.35A.07.0054A
    TAOGLASLIMITED
    AP.35A.07.0054A
AP.35A.07.0054A 数据手册
SPECIFICATION Part No. : Product Name : AP.35A.07.0054A 35mm One Stage GPS/GALILEO Active Patch Antenna Module with back-end Saw Filter Features : 35*35*3.5mm (Ground Plane) 54mm Ø1.13 I-PEX MHFI (U.FL) 15dB LNA RoHS Compliant SPE-12-8-023/D/SS Page 1 of 11 1. Introduction The AP.35A has been designed for embedded (inside device) integration with GPS receiver modules, the AP.35A combines a 35*35*3.5mm advanced low profile ceramic patch antenna with a one stage LNA and ultra thin coaxial cable. The Ground Plane size of 35*35mm combined with the larger size GPS Patch, gives this solution a performance increase in gain of 12dB. It also helps shields the patch antenna from noise and increases performance at low elevations.. Taoglas active antenna modules utilise XtremeGain™ technology for the highest sensitivity in the industry. This antenna system consists of two functional blocks, the LNA portion and the patch antenna. The AP.35A has a back-end SAW filter. SPE-12-8-023/D/SS Page 2 of 11 2. Specification 2.1. Patch Antenna Parameter Specification Frequency 1575.42 ± 1.023MHz Gain @ Zenith +2.5 dBic Typ. @ Zenith (35mm GP) Polarization RHCP Axial Ratio 3.0dB max. @Zenith Patch Dimension 35*35*3.5mm 2.2 LNA Parameter Specification Frequency 1575.42 ± 1.023MHz F0=1575.42MHz F0±30MHz 5dB min. Outer Band F0±50MHz 23dB min. Attenuation F0±100MHz 28dB min. Output Impedance 50Ω Output VSWR 2.0 Max Pout at 1dB Gain Typ. -2dBm Compression point Min. -6dBm LNA Gain, Power Consumption and Noise Figure LNA Gain Voltage (Typ) Power Consumption(mA) Typ Noise Figure Typ Min. 1.8V 14dB 3mA 1.5dB Typ. 3.0V 15dB 3mA 1.5dB Max. 5.5V 15dB 3mA 1.5dB SPE-12-8-023/D/SS Page 3 of 11 2.2. Cable & Connector Parameter Specification RF Cable Coaxial Cable Ø1.13 ± 0.1mm, length 54 ± 2.5mm Connector IPEX MHFI (U.FL) 2.3. Total Specification (through Antenna, LNA, Cable and Connector) Parameter Specification Frequency 1575.42 ± 1.023MHz At 90° At 5V:18 ± 3dBic At 3V: 17.5  3dBic Gain At 1.8V: 15.5  3dBic Output Impedance 50Ω Polarization RHCP Output VSWR Max 2.0 Operation Temperature -40°C to + 85°C Storage Temperature -40°C to + 85°C Relative Humidity 40% to 95% Input Voltage Min:1.8V Typ. 3.0V Max:5V Antenna 35*35*5.5mm SPE-12-8-023/D/SS Page 4 of 11 3. Technical Drawing SPE-12-8-023/D/SS Page 5 of 11 4. Radiation Patterns XY Plane XZ Plane YZ Plane SPE-12-8-023/D/SS Page 6 of 11 5. Axial Ratio 6. LNA Gain and Out of Band Rejection at 3.0V SPE-12-8-023/D/SS Page 7 of 11 6. LNA Noise Figure at 3.0V SPE-12-8-023/D/SS Page 8 of 11 7. Reliability Tests 7.1. Reliability Test (Room temperature +25C) 7.1.1. S21 Radiation Gain at +25C 7.1.2. C/N at +25C SPE-12-8-023/D/SS Page 9 of 11 7.2. Reliability Test (High temperature +85C) 7.2.1. S21 Radiation Gain at +85C 7.2.2. C/N at +85C SPE-12-8-023/D/SS Page 10 of 11 7.3. Reliability Test (Low temperature -40C) 7.3.1. S21 Radiation Gain at -40C 7.3.2. C/N at -40C Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. Copyright © Taoglas Ltd. SPE-12-8-023/D/SS Page 11 of 11
AP.35A.07.0054A 价格&库存
很抱歉,暂时无法提供与“AP.35A.07.0054A”相匹配的价格&库存,您可以联系我们找货
AP.35A.07.0054A
  • 1+164.437281+21.37189
  • 10+143.2249310+18.61493
  • 25+135.8580125+17.65745
  • 120+124.51318120+16.18296
  • 360+117.43451360+15.26295
  • 600+114.36614600+14.86415
库存:75
AP.35A.07.0054A
  • 10+80.00617
  • 30+78.51897
  • 55+77.04387
  • 120+74.08157
库存:290
