SPECIFICATION
Part No.
MA412.A.BI.001
Product Name
MA412 Storm 2in1 Screwmount Antenna
LTE MIMO 2in1
Features
2* LTE MIMO 698 to 960MHz/1710 to 2170MHz/
2490 to 2690MHz Antenna
Screw-Mount [Permanent Mount]
Worldwide 4G Bands including 3G and 2G
Suitable for worldwide HSPA/GSM/GPRS/CDMA/UMTS
Aerodynamic, Super Low-profile Vandal Resistant Housing
IP67 Enclosure
Dims: 216.24*93.25*30.95mm
0.3M CFD-200 with Fakra connectors as standard
Custom Cables and Connectors Available
Product conforms to the EMC directive 2014/30/EU.
RoHS Compliant
Side view
SPE-15-8-007/G/WY
Page 1 of 55
1. Introduction
The Storm MA412 LTE MIMO antenna is a low profile, heavy-duty, fully IP67
waterproof external M2M antenna for use in worldwide telematics applications which
require best in class LTE performance.
This unique product, only 30mm high, delivers powerful worldwide 4G LTE MIMO
antenna technology at 700/800/900/1700/1800M/1900M/2600MHz.
Typical applications
- HD Video over LTE
- First Responder and Emergency Services
- Intelligent Transport Systems
- Internet of Things (IoT market)
- High Definition Video Broadcast Systems
- Wireless LTE MIMO M2M Devices
- Digital Signage
LTE 4G applications demand high speed data uplink and downlink. High efficiency and
high gain MIMO antennas are necessary to achieve the required signal to noise ratio
and throughput required to solve these challenges. Taoglas also takes care to have
high isolation between the two MIMO antennas to prevent self-interference. The
MA412 does not require a ground plane. Low loss cables are used to keep efficiency
high over long cable lengths. In contrast, smaller MIMO antennas with poorer quality
thinner cables will have much reduced efficiency and isolation, which would lead to a
large drop in system throughput or drops, and may indeed not make a system
connection at all.
We have a version with SMA(M) also as standard MA412.A.BI.003. Cable length and
connector types are customizable. Conformity is declared under the following
standard:
Conformity is declared under the following standard: EN55022 Class B
This is to declare that the product listed above conform to the EMC directive
SPE-15-8-007/G/WY
Page 2 of 55
2014/30/EU.
2. Specification
2G/3G/4G MIMO1 Antenna
Frequency (MHz)
LTE700
GSM850
GSM900
698~803 824~894
880~960
DCS
PCS
UMTS1
LTE2600
LTE3500
1710~1880 1850~1990 1920~2170 2490~2690 3300~3600
Efficiency (%)
30cm
1M
2M
3M
5M
30cm
1M
2M
3M
5M
62.06
59.27
55.31
51.62
44.25
65.08
62.15
58.00
54.13
46.39
41.76
39.88
36.93
34.20
28.85
48.08
45.91
42.54
39.46
33.24
49.16
46.95
42.81
39.76
33.36
55.44
52.95
48.29
44.80
37.60
On the
50*50cm
ground
plane
30cm
1M
2M
3M
5M
-2.22
-2.42
-2.72
-3.02
-3.70
-3.98
-4.18
-4.51
-4.84
-5.58
-3.20
-3.40
-3.80
-4.13
-4.88
In free
space
30cm
1M
2M
3M
5M
-2.02
-2.22
-2.52
-2.82
-3.50
-3.19
-3.39
-3.72
-4.05
-4.79
-2.60
-2.80
-3.20
-3.52
-4.28
On the
50*50cm
ground
plane
In free
space
44.93
40.98
36.86
32.65
25.50
49.41
45.06
40.62
35.92
28.10
59.56
54.46
48.53
42.73
32.98
57.62
52.69
46.96
41.31
31.89
59.39
54.71
48.56
42.47
32.90
59.92
55.18
48.99
42.84
33.19
55.42
50.55
43.53
36.84
28.22
54.98
50.14
43.17
36.53
27.99
37.39
33.33
27.99
23.59
16.96
38.19
34.83
29.65
24.66
19.14
-3.55
-3.95
-4.40
-4.94
-6.00
-2.27
-2.66
-3.16
-3.72
-4.84
-2.27
-2.63
-3.14
-3.73
-4.84
-2.57
-2.97
-3.62
-4.35
-5.50
-3.11
-3.51
-3.97
-4.50
-5.57
-2.42
-2.81
-3.31
-3.86
-4.98
-2.23
-2.59
-3.10
-3.69
-4.80
-2.62
-3.02
-3.67
-4.39
-5.55
-4.36
-4.86
-5.61
-6.36
-7.79
-4.25
7.04
6.64
6.14
5.64
4.44
6.57
6.17
5.67
5.07
3.97
7.11
6.81
6.31
5.71
4.61
6.69
6.35
5.79
5.19
4.09
7.91
7.51
6.91
6.21
5.11
8.11
7.71
7.11
6.41
5.31
Average Gain(dBi)
-4.65
-5.35
-6.15
-7.25
Peak Gain(dBi)
On the
50*50cm
ground
plane
In free
space
30cm
1M
2M
3M
5M
30cm
1M
2M
3M
5M
5.37
5.17
4.87
4.57
3.87
3.54
3.34
3.04
2.74
2.04
3.66
3.46
3.06
2.76
2.06
4.07
3.87
3.47
3.17
2.37
4.35
4.15
3.75
3.45
2.65
4.13
3.93
3.53
3.23
2.43
6.24
5.84
5.34
4.84
3.74
4.67
4.27
3.77
3.27
2.17
SPE-15-8-007/G/WY
6.46
5.96
5.16
4.46
4.82
6.27
5.87
5.17
4.37
3.27
Page 3 of 55
2G/3G/4G MIMO2 Antenna
Frequency (MHz)
LTE700
GSM850
GSM900
698~803 824~894
880~960
DCS
PCS
UMTS1
LTE2600
LTE3500
Efficiency (%)
On the
50*50cm
ground
plane
In free
space
30cm
1M
2M
3M
5M
30cm
1M
2M
3M
5M
64.02
61.13
57.05
53.25
45.57
55.35
52.86
49.33
46.04
39.41
46.23
44.15
40.91
37.91
31.95
40.93
39.09
36.19
33.55
28.29
45.95
43.91
40.05
37.20
31.19
43.23
41.29
37.65
34.96
29.34
66.28
60.45
54.37
48.10
37.61
62.98
57.44
51.67
45.71
35.75
61.93
56.58
50.43
44.46
34.31
59.12
54.01
48.14
42.45
32.75
55.94
51.48
45.69
39.97
30.95
53.24
49.00
43.49
38.04
29.46
67.23
61.32
52.80
44.69
34.23
67.13
61.23
52.73
44.63
34.18
32.20
28.70
24.24
20.32
14.73
31.79
28.99
24.68
20.53
15.93
Average Gain(dBi)
On the
50*50cm
ground
plane
In free
space
30cm
1M
2M
3M
5M
30cm
1M
2M
3M
5M
-2.17
-2.37
-2.67
-2.97
-3.64
-2.87
-3.38
-3.58
-3.91
-4.23
-4.98
-3.93
-3.48
-3.68
-4.08
-4.41
-5.17
-3.71
-1.84
-2.24
-2.69
-3.23
-4.29
-2.04
-2.17
-2.56
-3.06
-3.62
-4.74
-2.39
-2.57
-2.93
-3.44
-4.03
-5.14
-2.80
-1.73
-2.13
-2.78
-3.50
-4.66
-1.73
-5.25
-5.75
-6.50
-7.25
-8.68
-5.28
-3.07
-3.37
-3.67
-4.35
-4.13
-4.46
-4.79
-5.53
-3.91
-4.31
-4.63
-5.39
-2.44
-2.90
-3.43
-4.50
-2.78
-3.28
-3.84
-4.96
-3.16
-3.67
-4.26
-5.37
-2.13
-2.78
-3.51
-4.67
-5.68
-6.38
-7.18
-8.28
8.06
7.66
7.16
6.66
5.46
7.48
7.08
6.58
6.08
4.98
7.89
7.49
6.99
6.49
5.29
7.29
6.89
6.39
5.88
4.69
8.16
7.76
7.16
6.46
5.36
8.13
7.73
7.13
6.43
5.33
5.48
4.98
4.28
3.48
2.18
5.37
4.97
4.27
3.47
2.37
Peak Gain(dBi)
On the
50*50cm
ground
plane
In free
space
30cm
1M
2M
3M
5M
30cm
1M
2M
3M
5M
6.51
6.31
6.01
5.71
5.01
5.21
5.01
4.71
4.41
3.71
4.09
3.89
3.59
3.19
2.49
2.85
2.65
2.25
1.95
1.15
3.82
3.62
3.22
2.92
2.22
3.16
2.96
2.56
2.26
1.46
7.93
7.53
7.03
6.53
5.43
7.48
7.08
6.58
6.08
4.98
SPE-15-8-007/G/WY
Page 4 of 55
Impedance
50Ω
Polarization
Linear
VSWR
< 3.5
Cable
0.3 meter CFD200 standard, fully customizable
Connector
Fakra(Jack) standard connector , fully customizable
MECHANICAL
Antenna Dimensions
Casing
ABS+PC
Base and thread
Nickel Plated Aluminum
Weight
400g
Ingress Protection Rating
IP67
Maximum Assembly Torque
39.2 N-m
ENVIRONMENTAL
Operation Temperature
-40°C to 85°C
Storage Temperature
-40°C to 90°C
Humidity
Non-condensing 65°C 95% RH
SPE-15-8-007/G/WY
Page 5 of 55
LTE BANDS
LTE/LTE- Advanced /WCDMA/HSPA.HSPA+
Band Number
Uplink
Downlink
1
UL: 1920 to 1980
DL: 2110 to 2170
2
UL: 1850 to 1910
DL: 1930 to 1990
3
UL: 1710 to 1785
DL: 1805 to 1880
4
UL: 1710 to 1755
DL: 2110 to 2155
5
UL: 824 to 849
DL: 869 to 894
7
UL: 2500 to 2570
DL:2620 to 2690
8
UL: 880 to 915
DL: 925 to 960
9
UL: 1749.9 to 1784.9
DL: 1844.9 to 1879.9
11
UL: 1427.9 to 1447.9
DL: 1475.9 to 1495.9
12
UL: 699 to 716
DL: 729 to 746
13
UL: 777 to 787
DL: 746 to 756
14
UL: 788 to 798
DL: 758 to 768
17
UL: 704 to 716
DL: 734 to 746 (LTE only)
18
UL: 815 to 830
DL: 860 to 875 (LET only)
19
UL: 830 to 845
DL: 875 to 890
UL: 832 to 862
DL: 791 to 821
21
UL: 1447.9 to 1462.9
DL: 1495.9 to 1510.9
22
UL: 3410 to 3490
DL: 3510 to 3590
23
UL:2000 to 2020
DL: 2180 to 2200 (LTE only)
24
UL:1625.5 to 1660.5
DL: 1525 to 1559 (LTE only)
25
UL: 1850 to 1915
DL: 1930 to 1995
26
UL: 814 to 849
DL: 859 to 894
27
UL: 807 to 824
DL: 852 to 869 (LTE only)
28
UL: 703 to 748
DL: 758 to 803 (LTE only)
29
UL: -
DL: 717 to 728 (LTE only)
30
UL: 2305 to 2315
DL: 2350 to 2360 (LTE only)
31
UL: 452.5 to 457.5
DL: 462.5 to 467.5 (LTE only)
32
UL: -
DL: 1452 - 1496
35
1850 to 1910
38
2570 to 2620
39
1880 to 1920
40
2300 to 2400
41
2496 to 2690
42
3400 to 3600
43
3600 to 3800
Covered
Covered
SPE-15-8-007/G/WY
Page 6 of 55
3. Antenna Characteristics
3.1 LTE MIMO Antenna
3.1.1 Test Setup
In free space
on the 50*50cm ground plane
SPE-15-8-007/G/WY
Page 7 of 55
3.1.2 LTE Antenna Return Loss
Setup on the 50*50cm ground plane with 0.3 meter cable length
Setup in free space with 0.3 meter cable length
SPE-15-8-007/G/WY
Page 8 of 55
3.1.3 LTE Antenna Efficiency
SPE-15-8-007/G/WY
Page 9 of 55
3.1.4 LTE Antenna Peak Gain
SPE-15-8-007/G/WY
Page 10 of 55
3.1.5 LTE Antenna Average gain
length
SPE-15-8-007/G/WY
Page 11 of 55
3.1.6 Test Setup For Antenna Radiation Pattern (ETS Anechoic chamber)
Y
X
Z
On the 50*50cm ground plane
SPE-15-8-007/G/WY
Page 12 of 55
3.1.7 2D Radiation pattern (MIMO1 with 0.3M cable length on the 50*50
ground plane)
XY Plane
X
Y
X
Y
SPE-15-8-007/G/WY
Page 13 of 55
X
Y
X
Y
SPE-15-8-007/G/WY
Page 14 of 55
XZ Plane
Z
X
Z
X
SPE-15-8-007/G/WY
Page 15 of 55
Z
X
Z
X
SPE-15-8-007/G/WY
Page 16 of 55
YZ Plane
Z
Y
Z
Y
SPE-15-8-007/G/WY
Page 17 of 55
Z
Y
Z
Y
SPE-15-8-007/G/WY
Page 18 of 55
3.1.8 3D Radiation pattern (MIMO1 with 0.3M cable length on the 50*50
ground plane
704MHz
960MHz
1710MHz
2170MHz
2690MHz
3500MHz
SPE-15-8-007/G/WY
Page 19 of 55
3.1.9 2D Radiation pattern (MIMO2 with 0.3M cable length on the 50*50
ground plane
XY Plane
X
Y
X
Y
SPE-15-8-007/G/WY
Page 20 of 55
X
Y
X
Y
SPE-15-8-007/G/WY
Page 21 of 55
XZ Plane
Z
X
Z
X
SPE-15-8-007/G/WY
Page 22 of 55
Z
X
Z
X
SPE-15-8-007/G/WY
Page 23 of 55
YZ Plane
Z
Y
Z
Y
SPE-15-8-007/G/WY
Page 24 of 55
Z
Y
Z
Y
SPE-15-8-007/G/WY
Page 25 of 55
3.1.10 3D Radiation pattern (MIMO2 with 0.3M cable length on the 50*50
ground plane
704MHz
960MHz
1710MHz
2170MHz
2690MHz
3500MHz
SPE-15-8-007/G/WY
Page 26 of 55
3.1.11 Test Setup For Antenna Radiation Pattern (ETS Anechoic chamber)
Y
X
Z
In free space
SPE-15-8-007/G/WY
Page 27 of 55
3.1.12 2D Radiation pattern (MIMO1 with 0.3M cable length in free space)
XY Plane
X
Y
X
Y
SPE-15-8-007/G/WY
Page 28 of 55
X
Y
X
Y
SPE-15-8-007/G/WY
Page 29 of 55
XZ Plane
Z
X
Z
X
SPE-15-8-007/G/WY
Page 30 of 55
Z
X
Z
X
SPE-15-8-007/G/WY
Page 31 of 55
YZ Plane
Z
Y
Z
Y
SPE-15-8-007/G/WY
Page 32 of 55
Z
Y
Z
Y
SPE-15-8-007/G/WY
Page 33 of 55
3.1.13 3D Radiation pattern (MIMO1 with 0.3M cable length in free space)
704MHz
1710MHz
2690MHz
960MHz
2170MHz
3500MHz
SPE-15-8-007/G/WY
Page 34 of 55
3.1.14 2D Radiation pattern (MIMO2 with 0.3M cable length in free space)
XY Plane
X
Y
X
Y
SPE-15-8-007/G/WY
Page 35 of 55
X
Y
X
Y
SPE-15-8-007/G/WY
Page 36 of 55
XZ Plane
Z
X
Z
X
SPE-15-8-007/G/WY
Page 37 of 55
Z
X
Z
X
SPE-15-8-007/G/WY
Page 38 of 55
YZ Plane
Z
Y
Z
Y
SPE-15-8-007/G/WY
Page 39 of 55
Z
Y
Z
Y
SPE-15-8-007/G/WY
Page 40 of 55
3.1.15 2D Radiation pattern (MIMO2 with 0.3M cable length in free space)
704MHz
960MHz
1710MHz
2170MHz
2690MHz
3500MHz
SPE-15-8-007/G/WY
Page 41 of 55
4. Mechanical Drawing (units: mm)
SPE-15-8-007/G/WY
Page 42 of 55
4.1 Connector Drawing (units mm)
Detail “A”
SPE-15-8-007/G/WY
Page 43 of 55
5. Installation
SPE-15-8-007/G/WY
Page 44 of 55
6. Packaging
SPE-15-8-007/G/WY
Page 45 of 55
7. Application Note (LTE MIMO Antenna)
The MA412 antenna performance with different cable lengths and different
environments is shown below.
7.1 On the 50*50cm ground plane
7.1.1 Return Loss (MIMO_1 on the 50*50cm ground plane)
7.1.2 Return Loss (MIMO_2 on the 50*50cm ground plane)
SPE-15-8-007/G/WY
Page 46 of 55
7.1.3 Insertion Loss (on the 50*50cm ground plane)
7.1.4 Efficiency (MIMO_1 on the 50*50cm ground plane)
SPE-15-8-007/G/WY
Page 47 of 55
7.1.5 Efficiency (MIMO_2 on the 50*50cm ground plane)
7.1.6 Average Gain (MIMO_1 on the 50*50cm ground plane)
SPE-15-8-007/G/WY
Page 48 of 55
7.1.7 Average Gain (MIMO_2 on the 50*50cm ground plane)
7.1.8 Peak Gain (MIMO_1 on the 50*50cm ground plane)
SPE-15-8-007/G/WY
Page 49 of 55
7.1.9 Peak Gain (MIMO_2 on the 50*50cm ground plane)
7.2 In free space
7.2.1 Return Loss (MIMO_1 in free space)
SPE-15-8-007/G/WY
Page 50 of 55
7.2.2 Return Loss (MIMO_2 in free space)
7.2.3 Insertion Loss (in free space)
SPE-15-8-007/G/WY
Page 51 of 55
7.2.4 Efficiency (MIMO_1 in free space)
7.2.5 Efficiency (MIMO_2 in free space)
SPE-15-8-007/G/WY
Page 52 of 55
7.2.6 Average Gain (MIMO_1 in free space)
7.2.7 Average Gain (MIMO_2 in free space)
SPE-15-8-007/G/WY
Page 53 of 55
7.2.8 Peak Gain (MIMO_1 in free space)
7.2.9 Peak Gain (MIMO_2 in free space)
SPE-15-8-007/G/WY
Page 54 of 55
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves
the right to make changes to specifications and product descriptions at any time. Taoglas reserves all rights to this
document and the information contained herein.
Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
Copyright © Taoglas
SPE-15-8-007/G/WY
Page 55 of 55
很抱歉,暂时无法提供与“MA412.A.BI.001”相匹配的价格&库存,您可以联系我们找货
