IS.01.B.305111
IS.01.B.305111
    TAOGLASLIMITED
    IS.01.B.305111
IS.01.B.305111 数据手册
SPECIFICATION Part Number: IS.01.B.305111 Product Name: 433 MHz Heavy Duty Screw Mount Antenna Features: Hercules Screw-Mount 0dBi ISM 433 MHz Band 3M NFC-200 SMA (M) 29mm*49mm (Diameter) Waterproof IP67 & IP69K Rated RoHS Compliant SPE-13-8-004/D/RC Page 1 of 15 1. INTRODUCTION The IS.01 is a high performance 433MHz thread mount antenna for external use on mesh Networks, vehicles and outdoor and indoor assets. It is designed for heavy duty work with extra thick threads. Durable UV resistant PC housing is resistant to vandalism and direct attack. At only 29mm high it complies with the latest EU directives for vehicle height restrictions, whilst also enabling covert operation with a diameter of 49mm. Range of signal travels up to 300m (see range tests below). The antenna housing is completely waterproof to IP67, and also to IP69K, which means it is waterproof against high pressure water jets used in industrial environments for cleaning. 2. SPECIFICATION ELECTRICAL ANTENNA IS.01 STANDARD Peak Gain Average Gain Efficiency VSWR Impedance Polarization ISM 400~460 MHz 1.6 dBi -3.5 dB 45%
IS.01.B.305111 价格&库存
很抱歉,暂时无法提供与“IS.01.B.305111”相匹配的价格&库存,您可以联系我们找货
IS.01.B.305111
