RI.02.01.3000W
RI.02.01.3000W
    TAOGLASLIMITED
    RI.02.01.3000W
RI.02.01.3000W 数据手册
SPECIFICATION Part Number: RI.02.01.3000W Product Name: 915MHz Road Marker Kit-Quad Band Cellular Antenna RI.01 with CAB.826 Cable Assembly Features: Low Profile - Diameter 101.4mm*Height 17.6 mm UV and Vandal resistant PP housing RI.01: 1.5M WY-100 cable SMB(M) Jack CAB.826: 1.5M WY-100 SMB(F) to SMA(M)ST RoHS Compliant Top Bottom Side Profile SPE-14-8-050/B/AS Page 1 of 13 1. Introduction Taoglas USA has designed a range of efficient antennas inside US standard raised non reflective roadmarkers. These are designed for, and installed inside, the low profile “Bott’s dots” that can to be mounted directly on the pavement and road in the USA. These antennas exhibit remarkably high efficiencies in such small packages and live in a very low profile enclosure. They are designed to be mounted directly on the road or pavement, just like a standard roadmarker. These antennas have been potted with the epoxy that is traditionally used to secure the roadmarker itself to the ground. There are no air gaps whatsoever inside the new type approved roadmarker with antenna, in order to maintain the mechanical integrity. It is presumed that the standard black epoxy will also be used to install the roadmarker in its final resting place on the ground. The CAB.826 cable assembly is included so the antenna cable can be easily disconnected if desired. This is useful if the antenna is mounted on a movable area, as the cable will split at the push-pull connectors, preventing damage to the cable. SPE-14-8-050/B/AS Page 2 of 13 2. Specification ELECTRICAL Band 915 MHz ISM Frequency (MHz) 902-928 Polarization Linear Impedance (Ohms) 50 Ohms Peak Gain (dBi) 6.2 Efficiency (%) 26 Return Loss (dB) -18 Radiation Properties Max Input Power (Watts) Omni-directional 10 MECHANICAL Dimensions Height = 17.6 mm and Diameter =101.4mm Cable WY100 Coaxial cable Connector SMB (M) Jack Straight 50 Ohms Casing UV Resistant PP Sealant Potting ENVIRONMENTAL Protection IP67 Corrosion 5% NaCI for 96hrs Temperature Range -40°C to +85°C Thermal Shock 100 cycles -40°C to +85°C Humidity Non-condensing 65°C 95% RH Shock (Drop Test) 1m drop on concrete 6 axes Cable Pull 8 Kgf SPE-14-8-050/B/AS Page 3 of 13 3. Test Set Up Figure 1. Impedance (left hand) and peak gain, efficiency and radiation pattern measurements (right hand). SPE-14-8-050/B/AS Page 4 of 13 4. Antenna Parameters 4.1. Return Loss Figure 2. Return Loss 915MHz Road Marker in Free Space and on Piece of Road. 4.2. Efficiency Figure 3. Efficiency of the 915MHz Road Marker in Free Space and on Piece of Road. SPE-14-8-050/B/AS Page 5 of 13 4.3. Peak Gain Figure 4. Peak Gain 915MHz Road Marker in Free Space and on Piece of Road SPE-14-8-050/B/AS Page 6 of 13 4.4. Radiation Pattern Figure 5. Road Marker ISM Antenna radiation pattern at 900 MHz on Piece of Road. . Figure 6. Radiation pattern at 915 MHz on a Piece of Road. SPE-14-8-050/B/AS Page 7 of 13 Figure 7. Radiation pattern at 930 MHz on a Piece of Road. . Figure 8. Radiation pattern at 900 MHz in Free Space. SPE-14-8-050/B/AS Page 8 of 13 . Figure 9. Radiation pattern at 915 MHz in Free Space. Figure 10. Radiation pattern at 930 MHz in Free Space. SPE-14-8-050/B/AS Page 9 of 13 5. MECHANICAL DRAWING 5.1 RI.01 Antenna SPE-14-8-050/B/AS Page 10 of 13 Note: Configuration of bumps or protrusions subject to change without notice Unit: mm (unless stated otherwise) SPE-14-8-050/B/AS Page 11 of 13 5.2 CAB.826 Cable Assembly SPE-14-8-050/B/AS Page 12 of 13 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. Copyright © Taoglas Ltd. SPE-14-8-050/B/AS Page 13 of 13
RI.02.01.3000W 价格&库存
很抱歉,暂时无法提供与“RI.02.01.3000W”相匹配的价格&库存,您可以联系我们找货
