MA410.A.LBIJ.001
MA410.A.LBIJ.001
    TAOGLASLIMITED
    MA410.A.LBIJ.001
MA410.A.LBIJ.001 数据手册
SPECIFICATION Part No. : MA410.A.LBIJ.001 Product Name : MA410 Storm 4in1 Permanent Mount Antenna LTE MIMO + GPS/GLONASS/GALILEO/BeiDou + Satellite L Band 1621MHz Features : 2* LTE MIMO Antennas 698~960MHz / 1710~2170MHz / 2490~2690MHz / 3300~3600MHz 1* Satellite L Band 1621MHz Antenna 1* GPS-GLONASS-GALILEO-BeiDou Antenna Screw-Mount [Permanent Mount] Worldwide 4G Bands including 3G and 2G Aerodynamic, Super Low-profile Vandal Resistant Housing IP67 Enclosure Dims: 216.24*93.25*30.95mm 1M cable (GNSS: RG-174)(LTE MIMO & SATELLITE L BAND CFD-200) with SMA(M) connectors as standard Custom Cables and Connectors Available Product conforms to the EMC directive 2014/30/EU. RoHS Compliant SPE-15-8-062/D/WY Page 1 of 57 1. Introduction The Storm MA410 antenna is a low profile, heavy-duty, fully IP67 waterproof external M2M antenna for use in worldwide telematics applications which combine Global Cellular, Location and Satellite Communications. MA410 delivers best in class LTE, GNSS and Iridium antenna performance. You will never be out of touch with this extremely robust antenna. At only 31mm high, the Storm is the world’s lowest profile global telematics antenna solution. It delivers powerful worldwide 4G LTE MIMO antenna technology while also covering the 3G and 2G bands, plus GPS-GLONASS-GALILEO-BeiDou for next generation location accuracy, and 1621MHz L-band antenna for global satellite communications. Typical applications - High speed data links with a need for satellite communication as fallback - Automotive and Heavy Equipment Vehicle Tracking and Telematics - Remote Asset and Pipeline Monitoring - HD Video over LTE - First Responder and Emergency Services - Global data communications/IoT LTE 4G applications demand high speed data uplink and downlink. High efficiency and high gain MIMO antennas are necessary to achieve the required signal to noise ratio and throughput required to solve these challenges. Taoglas also takes care to have high isolation between the two MIMO antennas to prevent self-interference. The MA410 does not require a ground plane. Low loss cables are used to keep efficiency high over long cable lengths. The GPS-GLONASS-GALILEO-BeiDou active antenna receives efficiently on all three bands, leading to higher location accuracy and stability of tracking in urban environments. Finally, a low axial ratio Satellite L Band 1621MHz Antenna is also SPE-15-8-062/D/WY Page 2 of 57 embedded, providing connectivity for Satellite L Band systems, enabling global coverage, and back-up in case of cellular network failure. Cable length and connector types are customizable. Contact your regional Taoglas sales office for support. Conformity is declared under the following standard: EN55022 Class B This is to declare that the product listed above conform to the EMC directive 2014/30/EU. SPE-15-8-062/D/WY Page 3 of 57 2. Specification GPS-GLONASS-GALILEO-BeiDou GPS/GALILEO:1575.42±1.023MHz GLONASS:1602±5MHz BeiDou:1561.098±2.046MHz Center Frequency Passive Antenna efficiency GPS/GALILEO: 45% GLONASS: 48% BeiDou: 45% VSWR < 2:1 Impedance 50Ω Axial Ratio GPS/GALILEO:
MA410.A.LBIJ.001 价格&库存
很抱歉,暂时无法提供与“MA410.A.LBIJ.001”相匹配的价格&库存,您可以联系我们找货
