Specification
Part No.
MA140.A.LB.001
Product Name
Olympian 2in1 LTE 4G/3G/2G and
GPS/GLONASS/GALILEO
Features
Permanent Mount Robust Housing
48mm Height/50mm Diameter
IP67 Waterproof
LTE 1M RG-316 SMA(M)
GPS/Glonass 1M RG-RG-174 SMA(M)
Cables and Connectors Customizable
RoHS Compliant
SPE-14-8-117/E/WY Page 1 of 26
1. Introduction
The Olympian MA140 is a high performance combination LTE and
GPS/GLONASS/GALILEO screw mount antenna in a compact housing, for external
use on vehicles and outdoor assets worldwide. The LTE antenna functions equally
well on 2G and 3G. The GPS/GLONASS/GALILEO antenna has stable gain and
radiation patterns on both bands.
The antenna can be mounted on metal and plastic structures. Customized cable
length and connectors are available.
Durable UV resistant IP67 ABS housing is resistant to vandalism and direct attack.
A rubber O-ring is provided under the antenna to prevent water entering under the
antenna. If the lower frequency bands are required the antenna functions best
when mounted on a metal ground-plane, but can still work well with short cable
lengths below 1 meters on plastic structures and is locked from the inside of the
structure by a nut. The thread is extra small, allowing for installation in the tightest
of environments.
Customized cable length and connectors are available. Taoglas recommends
minimum of 1m cable length for stable antenna performance. When mounted on a
ground-plane, the antenna can function well at all frequencies up to 3 meters cable
length. Generally, antenna efficiency of less than 20% at the connector would lead
to unreliable wireless system performance.
For better efficiency, especially on longer cable lengths up to 5 meters, a short
300mm cable can be used as standard, and then add a low loss 5 meter CFD200
extension cable SMA(F) to SMA(M) [CAB.0149].
If your device requires certification for PTCRB or US/Canadian network operators
please contact Taoglas USA to check is this antenna suitable.
SPE-14-8-117/E/WY Page 2 of 26
2. Specification
2.1 LTE Antenna
ELECTRICAL
Measurement Environment
In free space
Standard
4G / 3G / 2G
Operation Frequency(MHz)
698~960
1710~2170
2305~2360
2500~2800
3400~3600
Peak Gain (dBi)
30cm Cable Length
2.74
4.39
3.49
1M Cable Length
1.58
2.70
1.11
2M Cable Length
1.79
2.06
1.44
3M Cable Length
1.04
-0.42
-0.97
5M Cable Length
0.59
-1.98
-4.40
Efficiency (%)
30cm Cable Length
44.39
61.48
52.47
1M Cable Length
30.70
47.06
35.83
2M Cable Length
28.61
36.48
26.16
3M Cable Length
22.44
22.25
19.34
5M Cable Length
22.02
15.21
8.77
Average Gain (dBi)
30cm Cable Length
-3.57
-2.12
-2.83
1M Cable Length
-6.07
-3.32
-4.47
2M Cable Length
-5.90
-4.40
-5.83
3M Cable Length
-6.79
-6.55
-7.16
5M Cable Length
-7.16
-8.21
-10.58
SPE-14-8-117/E/WY Page 3 of 26
On 30x30 metal ground
Standard
4G / 3G / 2G
698~960
1710~2170
2305~2360
2500~2800
3400~3600
Peak Gain (dBi)
30cm Cable Length
3.84
3.76
1.42
1M Cable Length
4.92
2.40
-0.10
2M Cable Length
3M Cable Length
5M Cable Length
4.69
0.34
1.37
2.05
-0.55
-2.59
-0.49
-2.57
-5.67
30cm Cable Length
1M Cable Length
2M Cable Length
3M Cable Length
5M Cable Length
45.11
50.13
47.54
29.03
25.50
Efficiency (%)
60.43
51.74
36.99
26.41
15.68
41.00
32.31
21.57
15.28
7.88
Average Gain (dBi)
30cm Cable Length
-3.50
-2.21
-3.89
1M Cable Length
-3.03
-2.89
-4.92
2M Cable Length
-3.31
-4.34
-6.68
3M Cable Length
-5.46
-5.81
-8.16
5M Cable Length
-5.98
-8.07
-11.04
VSWR
很抱歉,暂时无法提供与“MA140.A.LB.001”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+655.732841+85.22550
