TLS.01.1F21
TLS.01.1F21
    TAOGLASLIMITED
    TLS.01.1F21
TLS.01.1F21 数据手册
Shockwave Part No: TLS.01.1F21 Description: Shockwave Wideband 5G/4G Direct Mount External Antenna With N Type(F) connector Features: Applicable for 5G/4G cellular bands 600-6000MHz Wideband Operational Over 45% efficiency and 2.3 dBi gain Mechanically robust for indoor/outdoor applications Height: 79.45mm (3.13") Diameter: 42mm (1.65") IP67 Waterproof N type(F) connector RoHS & Reach Compliant SPE-15-8-051-D 1. Introduction 3 2. Specifications 4 3. Antenna Characteristics 6 4. Radiation Patterns 8 5. Mechanical Drawing 18 6. Installation Guide 19 7. Packaging 20 Changelog 21 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-15-8-049-D www.taoglas.com 2 1. Introduction 1. Introduction 1. Introduction 1. Introduction 1. The Shockwave TLS.01.1F21 is a permanent mount, waterproof, external 5G/4G cellular operating at the wideband 600-6000MHz frequency with an N type Female direct mount connector. It has been designed to be used on a Ground Plane. It can be used in mobile and fixed applications for 5G/4G wireless such as: 1. • • • • • • 1. 1. Introduction Public safety Introduction HD Video Streaming Utilities and Smart Cities Fleet Management Agricultural Industrial Introduction This antenna has superior performance over wide-bands compared to traditional whip antennas. Up to 90% efficiency and with a minimum 2.3dBi peak gain over all cellular bands result when mounted on a 30x30 cm ground plane. Stable radiation patterns over low angles provides consistent gain in the horizontal plane, meaning that it is especially suitable for cellular applications. Introduction A unique indent tab on the base of the antenna allows a wrench to be used to solidly lock the antenna on top of its mounting location, where an N type female connector juts out from a metal panel. Waterproof Orings around the bottom base prevent water from leaking under the antenna. The TLS.01 antenna is IP67 waterproof resistant against high pressure water jets in commercial cleaning environments, which makes the antenna ideal for 5G/4G/3G/Cat M/NB-IoT applications either in indoor or in harsh outdoor environments. For more information contact your regional Taoglas customer support team. SPE-15-8-049-D www.taoglas.com 3 2. Specifications 3. Antenna Characteristics2. 3. Electrical Specifications Band Frequency (MHz) Efficiency (%) Average Gain (dB) Peak Gain (dBi) 5GNR/4G Band 71 617~698 46.5 -3.2 -1 Antenna698~806 Characteristics 95.2 -0.2 3.1 4G/3G Band 12,13,14,17,28,29 4G/3G/NB-IoT/Cat M Band 5,8,18,19,20,26,27 824~960 84.5 -0.7 Impedance Max Input Power Polarization Radiation Pattern 100W Vertical Omni-Directional 3.2 71.9 Patterns3. -1.4 2.9 4.Band 5GNR/4G Antenna1427~1518 Radiation Antenna 21,32,74,75,76 50 Ω 4G/3G Characteristics2. Specifications 1710~2200 65.5 -1.8 Band 2.7 1,2,3,4,9,23,25,35,39,66 4G/3G Band 7,38,41 2490~2690 62.7 -2 3.4 41.1 -4.1 3.Band 5GNR/4G Antenna3300~3800 Characteristics2. 22,42,48,77,78 LTE5200/ Wi-Fi 5800 5150~5925 45.9 Specifications 2.5 -3.4 5.3 *Measured on 30*30cm ground plane 3. 4. Antenna Characteristics Mechanical Dimension (mm) Height: 79.45mm(3.13") ; Diameter : 42mm(1.65") Connector Direct Mount N type (F) Housing Material UV Resistant ABS Antenna Radiation Patterns3.Antenna Characteristics 4. 4. Base Material Nickel Plated Zinc Alloy Weight (g) 130 Antenna Radiation Patterns Rec. Torque for Mounting 4.018 N∙m Max. Torque for Mounting 9.8 N∙m Environmental Antenna Radiation Patterns3. Antenna Waterproof Rating IP67 Operation Temperature -40°C to 85°C Humidity Non-condensing 65°C 95% RH Characteristics 4. Housing Rating Radiation Patterns3.Antenna IK10 Antenna Characteristics2. SPE-15-8-049-D Specifications www.taoglas.com 4 5G/4G Bands Band Number 5GNR / FR1 / LTE / LTE-Advanced / WCDMA / HSPA / HSPA+ / TD-SCDMA / Cat M / NB-IoT Uplink Downlink 1 UL: 1920 to 1980 DL: 2110 to 2170 2 UL: 1850 to 1910 DL: 1930 to 1990 3 UL: 1710 to 1785 DL: 1805 to 1880 4 UL: 1710 to 1755 DL: 2110 to 2155 5 UL: 824 to 849 DL: 869 to 894 7 UL: 2500 to 2570 DL:2620 to 2690 8 UL: 880 to 915 DL: 925 to 960 9 UL: 1749.9 to 1784.9 DL: 1844.9 to 1879.9 11 UL: 1427.9 to 1447.9 DL: 1475.9 to 1495.9 12 UL: 699 to 716 DL: 729 to 746 13 UL: 777 to 787 DL: 746 to 756 14 UL: 788 to 798 DL: 758 to 768 17 UL: 704 to 716 DL: 734 to 746 18 UL: 815 to 830 DL: 860 to 875 19 UL: 830 to 845 DL: 875 to 890 20 UL: 832 to 862 DL: 791 to 821 21 UL: 1447.9 to 1462.9 DL: 1495.9 to 1510.9 22 UL: 3410 to 3490 DL: 3510 to 3590 23 UL:2000 to 2020 DL: 2180 to 2200 24 UL:1625.5 to 1660.5 DL: 1525 to 1559 25 UL: 1850 to 1915 DL: 1930 to 1995 26 UL: 814 to 849 DL: 859 to 894 27 UL: 807 to 824 DL: 852 to 869 28 UL: 703 to 748 DL: 758 to 803 29 UL: - DL: 717 to 728 30 UL: 2305 to 2315 DL: 2350 to 2360 31 UL: 452.5 to 457.5 DL: 462.5 to 467.5 32 UL: - DL: 1452 – 1496 35 1850 to 1910 38 2570 to 2620 39 1880 to 1920 40 2300 to 2400 41 2496 to 2690 42 3400 to 3600 43 3600 to 3800 3550 to 3700 48 66 UL: 1710-1780 DL: 2110-2200 71 617 to 698 74/75/76 1427 to 1518 77 3300 to 4200 78 3300 to 3800 79 4400 to 5000 SPE-15-8-049-D Covered ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓  ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ www.taoglas.com 5 3. 4. Antenna Characteristics 3.1 Return Loss Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics 3.2 Efficiency 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna SPE-15-8-049-D www.taoglas.com 6 3.3 Average Gain 3.4 Peak Gain SPE-15-8-049-D www.taoglas.com 7 4. Radiation Patterns 4. 4. 4.1 Antenna Radiation Patterns Test Setup 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns On 30*30cm Ground Plane 4. Antenna Radiation Patterns SPE-15-8-049-D www.taoglas.com 8 4.2 3D and 2D Radiation Patterns 652MHz XY Plane SPE-15-8-049-D XZ Plane YZ Plane www.taoglas.com 9 751MHz XY Plane SPE-15-8-049-D XZ Plane YZ Plane www.taoglas.com 10 890MHz XY Plane SPE-15-8-049-D XZ Plane YZ Plane www.taoglas.com 11 1470MHz XY Plane SPE-15-8-049-D XZ Plane YZ Plane www.taoglas.com 12 1805MHz XY Plane SPE-15-8-049-D XZ Plane YZ Plane www.taoglas.com 13 1990MHz XY Plane SPE-15-8-049-D XZ Plane YZ Plane www.taoglas.com 14 2595MHz XY Plane SPE-15-8-049-D XZ Plane YZ Plane www.taoglas.com 15 3550MHz XY Plane SPE-15-8-049-D XZ Plane YZ Plane www.taoglas.com 16 5530MHz XY Plane SPE-15-8-049-D XZ Plane YZ Plane www.taoglas.com 17 5. Mechanical Drawing (Units: mm) 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-15-8-049-D Mechanical Drawing www.taoglas.com 18 6. Installation 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna SPE-15-8-049-D www.taoglas.com 19 7. Packaging 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-15-8-049-D Mechanical Drawing www.taoglas.com 20 Changelog for the datasheet SPE-17-8-042 - TLS.01.1F21 Revision: D (Current Version) Date: Changes: Changes Made by: 2022-09-02 Updated specifications Cesar Sousa Previous Revisions Revision: C Date: Changes: Changes Made by: 2019-11-18 Included 5G data Jack Conroy Revision: B Date: Changes: Changes Made by: 2017-03-30 Included LTE Table Andy Mahoney Revision: A (Original First Release) Date: Notes: Author: SPE-15-8-049-D 2015-10-11 Initial Release Jack Conroy www.taoglas.com 21 www.taoglas.com SPE-15-8-049-D © Taoglas 22 www.taoglas.com
TLS.01.1F21
物料型号: TLS.01.1F21
器件简介: - 名称: Shockwave Wideband 5G/4G Direct Mount External Antenna - 特点: 适用于5G/4G蜂窝频段,600-6000MHz宽带操作,超过45%的效率和2.3 dBi的增益,机械上适用于室内/室外应用,IP67防水。
引脚分配: N型(F)连接器
参数特性: - 电气特性包括不同5G/4G频段的频率范围、效率、平均增益、峰值增益、阻抗和最大输入功率。 - 机械特性包括尺寸、连接器类型、材料、重量、安装扭矩和防水等级。
功能详解: - 适用于公共安全、高清视频流、公用事业和智能城市、车队管理、农业工业等5G/4G无线应用。 - 与传统鞭状天线相比,在宽带上具有优越的性能,当安装在30x30厘米的接地平面上时,效率高达90%,所有蜂窝频段的峰值增益至少为2.3dBi。
应用信息: - 适用于5G/4G/3G/Cat M/NB-IoT应用,无论是室内还是恶劣的室外环境。
封装信息: - 尺寸: 高79.45mm (3.13"),直径42mm (1.65") - 材料: UV抗紫外线ABS (外壳材料),镀镍锌合金 (底座材料) - 防水等级: IP67 - 工作温度范围: -40°C至85°C
TLS.01.1F21 价格&库存
很抱歉,暂时无法提供与“TLS.01.1F21”相匹配的价格&库存,您可以联系我们找货
TLS.01.1F21
    TLS.01.1F21
