CA.69
CA.69
    TAOGLASLIMITED
    CA.69
CA.69 数据手册
169 MHz VHF Polymer Substrate Chip Monopole Part No: Antenna CA.69 Description: 25.2*5.1*0.8mm CA.69 169MHz 7dBi Polymer Substrate Chip Antenna Features: 169 MHz VHF Polymer Substrate Chip Monopole Antenna Peak Gain – approx. -7 dBi (on evaluation board) Efficiency 10~15% (on evaluation board) Low Profile Dimensions: 25.2*5.1*0.8mm RoHS & REACH Compliant SPE-13-8-077-B 1. Introduction 3 2. Specifications 4 3. Antenna Characteristics 5 4. Radiation Patterns 7 5. Mechanical Drawing 9 6. Layout Guide 11 7. Soldering Conditions 12 8. Packaging 13 9. Changelog 14 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-13-8-077-B www.taoglas.com 1. Introduction 1. Introduction 1. Introduction 1. Introduction 1. 1. 1. 1. The CA.69 Polymer Substrate Chip Antenna from Taoglas, 169 MHz is specifically designed for VHF 169MHz band applications. It is a high efficiency miniature SMD edge mounted antenna with small footprint requirement. This chip antenna uses the main PCB as its ground plane, thereby increasing antenna efficiency. It is tuned for different PCB sizes by simply changing the value of the matching circuit. CA.69 antenna electrical properties are symmetrical therefore the antenna can be soldered to the board from either side. Introduction Introduction This antenna is delivered on tape and reel. Small low frequency antennas such as CA.69 need to be carefully tuned and integrated into devices to perform optimally given the narrow band tuning required, so contact your regional Taoglas sales office for support on gerber review of your layout, advice on ground-plane layout and transmission line design. Taoglas also recommends we test your final device prototype with CA.69 on board and provide final matching values. Introduction Taoglas has tested the CA.69 mounted in realistic conditions in metal or semi metal meter housings with the latest high power modules from Telit and achieved read ranges of more than one hundred metres. Introduction Applications: VHF Band Applications SPE-13-8-077-B www.taoglas.com 2. Specifications 3. Antenna Characteristics2. Specifications Antenna Frequency (MHz) 3. 4. Bandwidth (MHz) Antenna Characteristics 8 (under -10dB Return Loss) VSWR 2 max. Impedance (Ω) 50Ω Antenna Polarization Radiation Patterns3.Antenna Linear Radiation Pattern Characteristics2. 3. 169 MHz Omni Specifications Mechanical Dimensions (mm) 25.2 x 5.1 x 0.8 Ground plane (mm) 110 x 55 (Recommended) Antenna Characteristics2. Material Specifications Polymer Substrate Mechanical Temperature Range 3. -40°C to 85°C Antenna Humidity Characteristics Moisture Sensitivity Level (MSL) 4. 20% to 70% RH 3 (168 Hours) Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics2. SPE-13-8-077-B Specifications www.taoglas.com 3. Antenna Characteristics 3.1 4. Return Loss Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics *The antenna tuning depends on different antenna ground plane application. Taoglas provides and CAD.B.69 evaluation boards to show performance when antenna is parallel mounted to 4.CAD.A.69 Antenna Radiation Patterns3.Antenna the ground plane or when it is orthogonally mounted to the ground-plane. Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna SPE-13-8-077-B www.taoglas.com 3.2 Efficiency 3.3 Peak Gain SPE-13-8-077-B www.taoglas.com 4. 4. Radiation Patterns 4.1 Test Setup – Antenna on Evaluation Board Antenna Radiation PatternsCAD.A.69 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation PatternsCAD.B.69 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns SPE-13-8-077-B www.taoglas.com 4.2 169 MHz Radiation Patterns XY Plane XY Plane Flipped XZ Plane Z Z X Y SPE-13-8-077-B X Y www.taoglas.com 5. Mechanical Drawing 5.1 Antenna Main Body 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 5.2 CAD.A.69 Application 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-13-8-077-B Mechanical Drawing www.taoglas.com 5.2 CAD.B.69 Application SPE-13-8-077-B www.taoglas.com 6. Layout Guide 6.1 Solder Land Pattern 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. 6. Packaging 7. Application Note6. Packaging 6.2 6.3 Mechanical Drawing Matching circuit CAD.A.69 Matching circuit CAD.B.69 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-13-8-077-B Mechanical Drawing www.taoglas.com 7. Soldering Conditions Typical Soldering profile for lead-free process: 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-13-8-077-B Mechanical Drawing www.taoglas.com 9. Packaging Quantity: 4000pcs/ Reel 6. Packaging5. 6. Packaging Mechanical Drawing 7.Tape Dimensions Application Note6. Packaging5. (unit: mm) Feature Specification Drawing W 44.00 P E F P2 D D1 Po 10Po 6. 6. 8.00 1.75 20.20 2.00 1.50 2.00 4.00 40.00 Packaging5. 1. 2. 3. 4. 5. 6. Tolerance ±0.30 ±0.10 ±0.10 ±0.10 ±0.10 +0.10 / -0.00 ±0.10 ±0.10 ±0.20 Mechanical Pocket Dimensions (unit: mm) Feature Ao Bo Ko t Mechanical Drawing Specification 5.3 25.45 1.50 0.30 Tolerance +0.10 -0.10 ±0.05 ±0.05 Cumulative tolerance of 10 pocket hole pitch: ±0.20mm Packaging Carrier camber not to exceed 1mm in 250mm Ao and Bo measured on a plane above the inside bottom of the pocket Ko measured from a plane on the inside bottom of the pocket to the top surface of the carrier All dimensions meet EIA-481-B requirements Material – Clear non Anti-Static Polystyrene, Black Conductive Polystyrene 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-13-8-077-B Mechanical Drawing www.taoglas.com Changelog for the datasheet SPE-13-8-077– CA.69 Revision: B (Current Version) Date: Changes: Changes Made by: 2021-10-05 Format Change, MSL Erik Landi Previous Revisions Revision: A (Original First Release) Date: Notes: Author: SPE-13-8-077-B 2017-10-11 Initial Release STAFF www.taoglas.com SPE-13-8-077-B © Taoglas www.taoglas.com
CA.69 价格&库存
很抱歉,暂时无法提供与“CA.69”相匹配的价格&库存,您可以联系我们找货
CA.69
    • 1000+23.844201000+3.09454
    • 2000+23.303782000+3.02441
    • 3000+23.033033000+2.98927
    库存:3800
    CA.69
    • 1+42.029651+5.45469
    • 10+31.9286910+4.14376
    • 25+29.4017925+3.81582
    • 100+26.62283100+3.45516
    • 250+25.29919250+3.28338
    • 500+25.07226500+3.25393
    库存:3800
    CA.69
      • 1+46.22400
      • 200+18.44640
      • 500+17.83080
      • 1000+17.52840
