ANT-418-CW-HW
ANT-418-CW-HW
    LINXTECHNOLOGIES(灵思)
    HW系列天线在坚固和美观的包装中提供了出色的性能。315、418和433MHz单极子版本具有直鞭14波长元件。直鞭元件提供了宽带宽和一致的性能。天线通过标准SMA或Part 15合规的RP-SMA连接...
ANT-418-CW-HW 数据手册
ANT-418-CW-HW Data Sheet by Product Description 8.1 mm (0.32") HW Series antennas deliver outstanding performance in a rugged and cosmetically attractive package. The 315, 418 and 433MHz monopole versions have a straight whip ¼-wave element. The straight whip element delivers wide bandwidth and consistent performance. The antennas attach via a standard SMA or Part 15 compliant RP-SMA connector. Custom colors and connectors are available for volume OEM customers. Features • • • • • • Low cost Excellent performance Omni-directional pattern Outstanding VSWR Rugged & damage-resistant Standard SMA or Part 15 compliant RP-SMA connector • Custom colors and terminators for volume OEMs • Use with plastic* or metal enclosures • Internal O-ring seal on connector 120.0 mm (4.72") 10.7 mm (0.42") End View * Requires proximity ground plane 5.6 mm (0.22") Electrical Specifications Center Frequency: Recmd. Freq. Range: Wavelength: VSWR: Peak Gain: Impedance: Connection: Oper. Temp. Range: 15.5 mm (0.61") 418MHz 403–433MHz ¼-wave ≤ 2.0 typical at center 0dBi 50-ohms SMA or RP-SMA –20°C to +85°C Electrical specifications and plots measured with a 10.16 cm x 10.16 cm (4.00" x 4.00") reference ground plane. Ordering Information ANT-418-CW-HW (with RP-SMA connector) ANT-418-CW-HW-SMA (with SMA connector) –1– Revised 11/18/13 Counterpoise Quarter-wave or monopole antennas require an associated ground plane counterpoise for proper operation. The size and location of the ground plane relative to the antenna will affect the overall performance of the antenna in the final design. When used in conjunction with a ground plane smaller than that used to tune the antenna, the center frequency typically will shift higher in frequency and the bandwidth will decrease. The proximity of other circuit elements and packaging near the antenna will also affect the final performance. For further discussion and guidance on the importance of the ground plane counterpoise, please refer to Linx Application Note AN-00501: Understanding Antenna Specifications and Operation. VSWR Graph VSWR 3:1 Reflected Power 25% 1.595 2:1 1:1 318MHz 11% 0% 518MHz 418MHz What is VSWR? The Voltage Standing Wave Ratio (VSWR) is a measurement of how well an antenna is matched to a source impedance, typically 50-ohms. It is calculated by measuring the voltage wave that is headed toward the load versus the voltage wave that is reflected back from the load. A perfect match will have a VSWR of 1:1. The higher the first number, the worse the match, and the more inefficient the system. Since a perfect match cannot ever be obtained, some benchmark for performance needs to be set. In the case of antenna VSWR, this is usually 2:1. At this point, 88.9% of the energy sent to the antenna by the transmitter is radiated into free space and 11.1% is either reflected back into the source or lost as heat on the structure of the antenna. In the other direction, 88.9% of the energy recovered by the antenna is transferred into the receiver. As a side note, since the “:1” is always implied, many data sheets will remove it and just display the first number. How to Read a VSWR Graph VSWR is usually displayed graphically versus frequency. The lowest point on the graph is the antenna’s operational center frequency. In most cases, this will be different than the designed center frequency due to fabrication tolerances. The VSWR at that point denotes how close to 50-ohms the antenna gets. Linx specifies the recommended bandwidth as the range where the typical antenna VSWR is less than 2:1. 159 Ort Lane, Merlin, OR, US 97532 Phone: +1 541 471 6256 Fax: +1 541 471 6251 www.linxtechnologies.com –2– Data Sheet ANT-418-CW-HW by
ANT-418-CW-HW 价格&库存
很抱歉,暂时无法提供与“ANT-418-CW-HW”相匹配的价格&库存,您可以联系我们找货
