SPECIFICATION
Part No.
TG.22.0111W
Product Name
TG22 2G/3G Cellular Connector Mount Monopole Antenna
GPRS-GSM-DCS-PCS-UMTS-CDMA- EDGE-HSPA
824MHz ~2170 MHz
Features
Ground dependent (Needs mounting to ground-plane)
White Version
3dBi Gain
30%+ Efficiency
Dimensions - 49mm * 8mm
50 Ohms
Straight SMA Male
Connector customizable
CE Certified
ROHS & REACH Compliant
SPE-11-8-113/G
Page 1 of 34
1. Introduction
The TG.22.0111W 2G/3G monopole helical antenna operates from 824MHz to
2170MHz on GSM-DCS-PCS-UMTS-CDMA-GPRS-EDGE-HSPA. Once mounted to an
adequate ground-plane it is a compact robust terminal antenna with high gain and
stable efficiency in a small form factor. Connection is made via straight SMA(M)
connector.
Typical applications
- Remote monitoring
At only 49mm in height, with a hardened TPEE casing, this antenna is the ideal
GPRS/UMTS antenna for telematics devices where larger antennas cannot be used.
Like all small monopole antennas, it must be mounted on a ground-plane to
radiate efficiently. The antenna should be mounted at the edge of the groundplane of the mainboard of the device. See below charts for analysis of performance.
A larger ground-plane of more than 100mm is needed for stable performance on
all bands. Also no metal should be used near the antenna, with at least 20mm of
clearance required, the more clearance the better.
For devices with ground-planes smaller than 100mm in length or where metal
clearance is not adequate, alternative larger antennas should be considered such
as the TG.30. If small size is needed, a custom tuned solution or a new design
may also be necessary. Contact your Taoglas regional sales office for support.
SPE-11-8-113/G
Page 2 of 34
2. Electrical Specification
Parameter
Specification
Bands
GSM850
GSM900
DCS
PCS
WCDMA I
1850~1990MHz
1920~2170MHz
Frequency
Range
824~896MHz
880~960MHz
1710~1880MHz
Return Loss
≦-5dB
VSWR
≦3.5
Peak Gain
1.42dBi
1.91dBi
2.51dBi
3.23dBi
2.89dBi
Efficiency
64.40%
68.29%
70.67%
72.61%
68.48%
Average Gain
-1.92dBi
-1.66dBi
-1.51dBi
-1.39dBi
-1.67dBi
Polarization
Linear
Power handling
20 W
Impedance
50 Ohms
Connector
Straight SMA(M)
*All the antenna characteristics were measured with 150mm*90mm ground plane
Environmental & Mechanical Characteristics
Parameter
Specification
Temperature
-40˚C to +85˚C
Radome color
White
Radome material
TPEE
Weight
6g
SPE-11-8-113/G
Page 3 of 34
3.
TEST SET UP
Figure 1. Impedance and VSWR measurements
SPE-11-8-113/G
Page 4 of 34
4. ANTENNA PARAMETERS
4.1. Return Loss
Figure 2. Return Loss of TG.22.0111W
SPE-11-8-113/G
Page 5 of 34
4.2. VSWR
Figure 3. VSWR of TG.22.0111W
SPE-11-8-113/G
Page 6 of 34
4.3
Efficiency (%)
Figure 4. Efficiency of TG.22.0111W
4.4
Peak Gain(dBi)
Figure 5. Peak Gain of TG.22.0111W
SPE-11-8-113/G
Page 7 of 34
4.5
Average Gain(dBi)
Figure 6. Average Gain of TG.22.0111W
SPE-11-8-113/G
Page 8 of 34
4.6
Radiation Pattern Data
Y
X
Z
SPE-11-8-113/G
Page 9 of 34
4.6.1
Radiation Pattern
XY-Plane
X
Y
X
Y
SPE-11-8-113/G
Page 10 of 34
X
Y
XZ-Plane
Z
330
300
270
10
-20
-30
-40
60
90
240
210
824MH
z
120
880MH
z
(dB)
960MH
z
150
180
X
SPE-11-8-113/G
Page 11 of 34
Z
330
300
270
10
-20
-30
-40
60
90
240
X
1575.42
MHz
120
210
150
(dB)
180
Z
330
300
270
10
-20
-30
-40
60
90
240
120
210
150
180
(dB)
X
1710M
Hz
1880M
Hz
1990M
Hz
2170M
Hz
SPE-11-8-113/G
Page 12 of 34
YZ-Plane
Z
Y
Z
Y
SPE-11-8-113/G
Page 13 of 34
Z
Y
SPE-11-8-113/G
Page 14 of 34
5.
Drawing and Dimensions (unit: mm)
SPE-11-8-113/G
Page 15 of 34
6. Packaging
1pcs antennas per small PE bag.
100 small PE bags per big PE bag.
100pcs antennas per big sealed PE bag.
SPE-11-8-113/G
Page 16 of 34
7. Installation
SPE-11-8-113/G
Page 17 of 34
8. Application Note
This section, Taoglas provides the ground variation effects to TG.22.0111W antenna. Detail
setup is setup as below.
8.1 Ground Plane Dimensions:
30cm*30cm
20cm*20cm
10cm*4cm
8.2 Return Loss:
SPE-11-8-113/G
Page 18 of 34
8.3 Efficiency:
8.4 Peak Gain:
SPE-11-8-113/G
Page 19 of 34
8.5 Radiation Pattern Measurement Setup:
8.5.1 30cm*30cm Ground Plane
Setup
Y
X
Z
XY-Plane
X
Y
SPE-11-8-113/G
Page 20 of 34
X
Y
X
Y
SPE-11-8-113/G
Page 21 of 34
XZ-Plane
Z
X
Z
X
SPE-11-8-113/G
Page 22 of 34
Z
X
YZ-Plane
Z
Y
SPE-11-8-113/G
Page 23 of 34
Z
Y
Z
Y
SPE-11-8-113/G
Page 24 of 34
8.5.2 20cm*20cm Ground Plane
Setup
Y
Z
XY-Plane
X
X
Y
SPE-11-8-113/G
Page 25 of 34
X
Y
X
Y
SPE-11-8-113/G
Page 26 of 34
XZ-Plane
Z
X
Z
X
SPE-11-8-113/G
Page 27 of 34
Z
X
YZ-Plane
Z
Y
SPE-11-8-113/G
Page 28 of 34
Z
Y
Z
Y
SPE-11-8-113/G
Page 29 of 34
8.5.3 10cm*4cm Ground Plane
Setup
Y
Z
XY-Plane
X
X
Y
SPE-11-8-113/G
Page 30 of 34
X
Y
X
Y
SPE-11-8-113/G
Page 31 of 34
XZ-Plane
Z
X
Z
X
SPE-11-8-113/G
Page 32 of 34
Z
X
YZ-Plane
Z
Y
SPE-11-8-113/G
Page 33 of 34
Z
Y
Z
Y
© Taoglas
SPE-11-8-113/G
Page 34 of 34
很抱歉,暂时无法提供与“TG.22.0111W”相匹配的价格&库存,您可以联系我们找货
