FXP14.09.0100A
FXP14.09.0100A
    TAOGLASLIMITED
    FXP14.09.0100A
FXP14.09.0100A 数据手册
SPECIFICATION FXP14 Hexa Band Cellular Antenna Part No. : FXP14.09.0100A Product Name : FXP14 Hexa-Band Cellular Antenna 850/900/1700/1800/1900/2100MHz Feature : MMCX(M)RA Connector 100mm Cable 70*20*0.1 mm RoHS Compliant SPE-12-8-049/B/ZL Page 1 of 7 1. OVERVIEW The Taoglas FXP14 Hexa Band Cellular Antenna covers all world-wide bands (850 / 900 / 1700 / 1800 / 1900 / 2100 MHz). These cellular bands are used for different technologies in different countries such as GSM / CDMA / DCS / PCS / WCDMA / UMTS/ HSPA / GPRS / EDGE / 3G. The antenna has been designed in a flexible material with a rectangular form-factor and cable connection for an easy installation. The antenna works on different plastic materials and thickness. We have selected a piece of ABS with 2 mm of thickness as a baseline for testing. 2. . ANTENNA CHARACTERISTICS Parameter Cellular Band (MHz) Hexa Band Cellular Antenna 850 900 1700 1800 1900 2100 Return Loss (dB) -7 -12 -8 -9 -9 -8 Efficiency (%) 52 55 60 60 62 65 2 1.5 3 2.5 2 2.5 Gain (dBi) Impedance 50 Ohms VSWR ≤2.5:1 Polarization Linear Power Handled 5W Operation Temperature -40 ºC ~ +85 ºC Storage Temperature -40 ºC ~ +85 ºC Dimensions Weight Connector Cable Standard Cable Length and color RoHS Compliant Adhesive 70 X 20 X 0.1 mm 1.5 g MMCX(M)RA Mini-Coax 1.13 mm 105mm, Black Yes 3M 467 SPE-12-8-049/B/ZL Page 2 of 7 3. TEST SET UP A Satimo SG24 3D Scan System with Anechoic Chamber. Y X Z Figure 1. Satimo System. Agilent 5071C Vector Network Analyzer. Figure 2. Network Analyzer. SPE-12-8-049/B/ZL Page 3 of 7 4. ANTENNA PARAMETERS The next antenna parameter graphs like Return Loss were measured in the Agilent 5071C Vector Network Analyzer. The Gain, Efficiency and Radiation Patterns were measured in the reliable Satimo 3D Scan System. 4.1 Return Loss Data Figure 3. Return Loss for the FXP14 Antenna. 4.2 Gain Data Figure 4. Gain for the FXP14 Antenna. SPE-12-8-049/B/ZL Page 4 of 7 4.3 Efficiency Data Figure 5. Efficiency for the FXP14 Antenna. 4.4 Radiation Pattern Data. Figure 6. Radiation pattern XZ Plane, Figure 1 as reference (dB). SPE-12-8-049/B/ZL Page 5 of 7 Figure 7. Radiation pattern YZ Plane, Figure 1 as reference (dB). Figure 8. Radiation pattern XY plane, Figure 1 as reference (dB). SPE-12-8-049/B/ZL Page 6 of 7 5. MECHANICAL DRAWING Unit : mm Figure 9. Mechanical Drawing for the FXP14 Antenna. SPE-12-8-049/B/ZL Page 7 of 7
FXP14.09.0100A 价格&库存
很抱歉,暂时无法提供与“FXP14.09.0100A”相匹配的价格&库存,您可以联系我们找货
FXP14.09.0100A
  • 25+40.22677
  • 60+39.42876
  • 100+37.20402
库存:164
