TI.15.3113
TI.15.3113
    TAOGLASLIMITED
    TI.15.3113
TI.15.3113 数据手册
SPECIFICATION Part No. : TI.15.3113 Product Name : 433MHz ISM Band Dipole Antenna Feature : SMA(M) Connector Hinge design for optimal reception RoHS Compliant SPE-12-8-021/A/ZL Page 1 of 1 I. Introduction TI.15 series is high performance 433MHz Omni-directional dipole antenna. This SMA plug mount antenna is ideal for general purpose use. The hinge design enables the antenna to be positioned at the optimal reception angle. II. Specification ELECTRICAL Centre Frequency 433.05434.79MHz Average Gain -9.0dBi Peak Gain -4.7dBi Efficiency 12% VSWR 1.5 : 1 max Polarization Linear Impedance 50  MECHANICAL Dimensions 198 x ψ13 mm Housing Material ABS + PC Connector SMA(M) Weight 21g ENVIRONMENTAL Operation Temperature -40°C to 85°C Storage Temperature -40°C to 105°C Relative Humidity 40% to 95% * Electrical properties are measured with the antenna in bend position in free space. SPE-12-8-021/A/ZL Page 2 of 2 III. Antenna S11 Property III.1. Bend Position Return Loss 0 -2 -4 -6 -8 -10 (dB) -12 -14 -16 -18 -20 -22 -24 -26 -28 -30 380 SPE-12-8-021/A/ZL 390 400 410 420 430 440 450 460 (MHz) Page 3 of 3 III.2. 180 Degree Straight Position Return Loss 0 -2 -4 -6 -8 -10 -12 -14 -16 (dB) -18 -20 -22 -24 -26 -28 -30 -32 -34 -36 -38 -40 (MHz) 380 III.3. 390 400 410 420 430 440 450 460 Bend Position VSWR 8 7 6 5 4 3 2 380 390 SPE-12-8-021/A/ZL 400 410 420 430 440 450 460 (MHz) Page 4 of 4 . 1 III.4. Straight Position VSWR 8 7 6 5 4 3 2 1 380 390 SPE-12-8-021/A/ZL 400 410 420 430 440 450 460 (MHz) Page 5 of 5 IV. Antenna Radiation Property IV.1. Bend Position Radiation Efficiency 30 25 (%) 20 15 10 5 0 400 SPE-12-8-021/A/ZL 410 420 430 440 450 460 470 480 (MHz) Page 6 of 6 IV.2. Straight Position Radiation Efficiency 20 (%) 15 10 5 0 400 IV.3. 410 420 430 440 450 460 470 480 (MHz) Bend Position Peak Gain 0 -2 -4 -6 (dBi) -8 -10 -12 -14 -16 -18 -20 400 410 SPE-12-8-021/A/ZL 420 430 440 450 460 470 480 (MHz) Page 7 of 7 IV.4. Straight Position Peak Gain 0 -1 -2 -3 -4 -5 -6 (dBi) -7 -8 -9 -10 -11 -12 -13 -14 -15 -16 400 SPE-12-8-021/A/ZL 410 420 430 440 450 460 470 480 (MHz) Page 8 of 8 IV.5. Bend Position Average Gain -6 -8 -10 (dBi) -12 -14 -16 -18 -20 400 410 SPE-12-8-021/A/ZL 420 430 440 450 460 470 480 (MHz) Page 9 of 9 IV.6. Straight Position Average Gain 0 -2 -4 (dBi) -6 -8 -10 -12 -14 -16 400 IV.7. 410 420 430 440 450 460 470 480 (MHz) 433MHz Bend Position Radiation Pattern H-plane Radiation 0 0 330 30 -5 -10 -15 -20 300 60 -25 -30 -35 -40 270 -45 90 240 120 210 150 180 SPE-12-8-021/A/ZL (dBi) Page 10 of 10 E-plane Radiation 0 0 330 -5 30 -10 -15 -20 300 60 -25 -30 -35 -40 270 -45 90 240 120 210 150 180 SPE-12-8-021/A/ZL (dBi) Page 11 of 11 IV.8. 433MHz Straight Position Radiation Pattern H-plane Radiation 0 0 330 30 -5 -10 -15 300 60 -20 -25 -30 -35 270 -40 90 240 120 210 150 180 SPE-12-8-021/A/ZL (dBi) Page 12 of 12 E-plane Radiation 0 0 330 -5 30 -10 -15 -20 300 60 -25 -30 -35 -40 270 -45 90 240 120 210 150 180 (dBi) V. Ground Plane Effect TI.15 may be mounted near a piece of ground plane. The ground plane changes the antenna radiation property. We have placed TI.15 in different near-ground scenarios and observe its radiation behaviors. Four different antenna placements were tested -1. Free Space 2. Small Ground (15 x 9cm) – common size of CPE devices. TI.15 is mounted at the longer edge for testing. 3. Big Ground Edge (45 x 30cm) – simulate the effect of mounting antenna on a base station device. TI.15 is mounted at the centre of the longer edge. 4. Big Ground Centre (45 x 30cm) – simulate the effect of mounting antenna in a centre of a big ground plane, such as vehicle top. SPE-12-8-021/A/ZL Page 13 of 13 Free space Small ground edge Big ground edge Big ground center SPE-12-8-021/A/ZL Page 14 of 14 VI. S11 Performance of TI.15 with Different Ground Bend Position Return Loss 0 -2 -4 -6 -8 -10 (dB) -12 -14 -16 -18 -22 stand alone small gnd big gnd edge -24 big gnd centre -20 -26 -28 -30 380 390 SPE-12-8-021/A/ZL 400 410 420 430 440 450 460 (MHz) Page 15 of 15 (dB) Straight Position Return Loss 0 -2 -4 -6 -8 -10 -12 -14 -16 -18 -20 -22 -24 -26 -28 -30 -32 -34 -36 -38 -40 stand alone small gnd big gnd edge big gnd centre 380 390 400 410 420 430 440 450 460 (MHz) Bend Position VSWR 8 7 6 5 4 stand alone small gnd 3 big gnd edge big gnd centre 2 380 390 SPE-12-8-021/A/ZL 400 410 420 430 440 450 460 (MHz) . 1 Page 16 of 16 Straight Position VSWR 8 7 6 5 4 3 stand alone small gnd big gnd edge big gnd centre 1 380 390 SPE-12-8-021/A/ZL 400 410 420 430 440 450 460 (MHz) . 2 Page 17 of 17 VII. Antenna Radiation Property VII.1. Bend Position Radiation Efficiency 60 50 (%) 40 30 20 stand alone small gnd big gnd edge big gnd center 10 0 400 410 SPE-12-8-021/A/ZL 420 430 440 450 460 470 480 (MHz) Page 18 of 18 VII.2. Straight Position Radiation Efficiency 60 50 (%) 40 30 stand alone small gnd 20 big gnd edge big gnd center 10 0 400 VII.3. 410 420 430 440 450 460 470 480 (MHz) Bend Position Peak Gain 4 2 0 -2 -4 (dBi) -6 -8 -10 -12 stand alone -14 small gnd big gnd edge -16 big gnd center -18 -20 400 410 SPE-12-8-021/A/ZL 420 430 440 450 460 470 480 (MHz) Page 19 of 19 VII.4. Straight Position Peak Gain 0 -2 -4 -6 (dBi) -8 -10 -12 -14 stand alone small gnd -16 big gnd edge big gnd center -18 -20 400 VII.5. 410 420 430 440 450 460 470 480 (MHz) Bend Position Average Gain 0 -2 -4 -6 (dBi) -8 -10 -12 stand alone small gnd -14 big gnd edge -16 big gnd center -18 -20 400 410 SPE-12-8-021/A/ZL 420 430 440 450 460 470 480 (MHz) Page 20 of 20 VII.6. Straight Position Average Gain 0 -2 -4 -6 (dBi) -8 -10 -12 stand alone -14 small gnd big gnd edge -16 big gnd center -18 -20 400 410 SPE-12-8-021/A/ZL 420 430 440 450 460 470 480 (MHz) Page 21 of 21 VII.7. 433MHz Bend Position Radiation Pattern H-plane Radiation 0 0 330 30 -5 -10 -15 300 60 -20 -25 -30 -35 270 -40 90 240 120 210 150 180 SPE-12-8-021/A/ZL s ta nd a lo ne s ma ll g nd b i g g nd e d g e b i g g nd c e nte r (dBi) Page 22 of 22 E-plane Radiation 0 0 330 30 -5 -10 -15 300 60 -20 -25 -30 -35 270 -40 90 240 120 210 150 180 SPE-12-8-021/A/ZL stand alone small gnd big gnd edge big gnd center (dBi) Page 23 of 23 VII.8. 433MHz Straight Position Radiation Pattern H-plane Radiation 0 0 330 30 -5 -10 -15 300 60 -20 -25 -30 -35 270 -40 90 240 120 stand alone small gnd big gnd edge big gnd center 210 150 180 SPE-12-8-021/A/ZL (dBi) Page 24 of 24 E-plane Radiation 0 0 330 30 -5 -10 -15 300 60 -20 -25 -30 -35 270 -40 90 240 120 210 150 180 SPE-12-8-021/A/ZL s ta nd a lo ne s ma ll g nd b i g g nd e d g e b i g g nd c e nte r (dBi) Page 25 of 25 VIII. Mechanical Drawing Unit : mm SPE-12-8-021/A/ZL Page 26 of 26
TI.15.3113 价格&库存
很抱歉,暂时无法提供与“TI.15.3113”相匹配的价格&库存,您可以联系我们找货
TI.15.3113
    • 1+139.39560
    • 200+55.62000
    • 500+53.76240
    • 1000+52.84440
