MA602.A.ABJ.002
MA602.A.ABJ.002
    TAOGLASLIMITED
    MA602.A.ABJ.002
MA602.A.ABJ.002 数据手册
SPECIFICATION Part No. : MA602.A.ABJ.002 Product Name : Spartan Screwmount 3in1 Combination Antenna GPS/GLONASS/GALILEO-SMA(M)1M RG174 Cellular-SMA(M)1M CFD-200 IRIDIUM-SMA(M) 1M CFD-200 Feature : IP67 Waterproof High performance outdoor antenna Custom cables and connectors available RoHS Compliant SPE-14-8-092/C/WY Page 1 of 16 1. Introduction The Spartan MA602 antenna is a heavy-duty, fully IP67 waterproof external M2M antenna for use in telematics, transportation and remote monitoring applications. The Spartan is unique in the market because it combines a 3in1 GPS/GLONASS/GALILEO, Cellular (3G and 2G) and IRIDIUM, heavy-duty antenna with high efficiency in a compact format. The antenna screws down permanently onto a roof or metal panel and can be pole or wall-mounted with a metal bracket. For industries such as commercial vehicle telematics, remote monitoring, smart meter systems and construction equipment, the Spartan provides a robust, rugged antenna that is durable, even in extreme environments. Customized cables and connectors version available. SPE-14-8-092/C/WY Page 2 of 16 2. Specification Table Cellular Antenna Frequency 824~960MHz 1710~1990MHz 1990~2170MHz Average Gain ≧-5 dBi ≧-4 dBi ≧-4 dBi Average Efficiency 60.18% 53.97% 79.27% VSWR ≦4.5 ≦5.2 ≦3.0 Polarization Linear Impedance 50Ω Nominal Cable 1M CFD200 Coaxial Cable, fully customizable Connector SMA(M) standard, fully customizable GPS/GLONASS/GALILEO Antenna Center Frequency fc 1575.42MHz 1602MHz Gain @Zenith 3 dBic Min. 2.5 dBic Min. Efficiency 76% 70% VSWR 1.92 Max 1.92 Max Polarization Linear Linear Impedance 50Ω Nominal 50Ω Nominal Cable 1M RG-174 Coaxial Cable, fully customizable Connector SMA(M) standard, fully customizable IRIDIUM Antenna Frequency Range 1616~1626.5MHz Gain @Zenith 3.5 dBic Min. Efficiency 90 % VSWR 1.92 Max. Axial Ratio 4 dB Max. Polarization RHCP Impedance 50Ω Nominal Cable 1M CFD200 Coaxial Cable, fully customizable Connector SMA(M) standard, fully customizable SPE-14-8-092/C/WY Page 3 of 16 GPS/GLONASS/GALILEO LNA Electrical Properties Frequency GPS/GALILEO:1575.42±3MHz GLONASS:1598~1610MHz Impedance 50Ω Nominal VSWR 1.92:1 Max. Return Loss 10 dB Min. Gain@3.3V 29~30dB DC Power Input 3~5V Noise Figure @3.3V 3 dB Typ. Power Consumption 7~9 mA Typ. MECHANICAL Dimensions Profile 39.5mm x Diameter 145.6mm Casing UV resistant PVC Base and thread Nickel Plated Zinc Thread diameter 30mm Waterproof IP67 Weight 1.03Kg Recommended Torque for 49N·m Mounting Maximum Torque for 58.8N·m Mounting ENVIRONMENTAL Operation Temperature -40°C to 85°C Storage Temperature -40°C to 85°C Humidity Non-condensing 65°C 95% RH SPE-14-8-092/C/WY Page 4 of 16 3. Cellular Antenna Characteristics 3.1. VSWR 3.2. 3D Efficiency Frequency (MHz) Average Gain(dBi) Efficiency (%) 824 -3.68 42.78 894 -1.19 76.00 960 -2.09 61.75 1710 -5.11 30.79 1990 -1.12 77.15 2110 -0.68 85.44 2170 -1.23 75.21 SPE-14-8-092/C/WY Page 5 of 16 3.3. 2D Radiation Pattern SPE-14-8-092/C/WY Page 6 of 16 3.3.1. XZ Plane SPE-14-8-092/C/WY Page 7 of 16 3.3.2. YZ Plane SPE-14-8-092/C/WY Page 8 of 16 4. GPS/GLONASS/GALILEO Antenna Characteristics 4.1. Block Diagram 4.2. S-Parameter Measurement 4.3. 3D Efficiency Frequency (MHz) Gain @Zenith ( dBic) Efficiency (%) 1575.42 3.6 76 1602 3.0 70 SPE-14-8-092/C/WY Page 9 of 16 4.4. Radiation Pattern 4.4.1. GPS/GALILEO/GALILEO Antenna(@1575.42MHz) 4.4.2. GLONASS Antenna(@1602MHz) SPE-14-8-092/C/WY Page 10 of 16 4.5. GPS/GLONASS/GALILEO LNA Test Item 1575.42 MHz (GPS/GALILEO Band) 1602 MHz (GLONASS Band) Gain @3.3V 29.5 dB 29.6 dB Return Loss @3.3V -16 dB -16 dB Noise Figure @3.3V 3 dB 3 dB Current consumption @3.3V 7-9 mA SPE-14-8-092/C/WY Page 11 of 16 5. IRIDIUM Antenna Characteristics 5.1. S-Parameter Measurement 5.2. 3D Efficiency Frequency (MHz) Gain @Zenith (dBic) Efficiency (%) 1616 4.9 88 1621.25 5.7 93 1626.5 5.0 89 SPE-14-8-092/C/WY Page 12 of 16 5.3. Radiation Pattern SPE-14-8-092/C/WY Page 13 of 16 6. Mechanical Drawing SPE-14-8-092/C/WY Page 14 of 16 7. Installation Maximum torque: 600kgf-cm SPE-14-8-092/C/WY Page 15 of 16 8. Packaging Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. Copyright © Taoglas Ltd. SPE-14-8-092/C/WY Page 16 of 16
MA602.A.ABJ.002 价格&库存
很抱歉,暂时无法提供与“MA602.A.ABJ.002”相匹配的价格&库存,您可以联系我们找货
MA602.A.ABJ.002
  • 1+1481.40311
  • 3+1269.72789
  • 11+1212.01789
  • 27+1159.38655
库存:48
MA602.A.ABJ.002
    • 1+1115.83024
    • 3+1062.69028
    • 11+1014.36255
    • 27+970.23039
    库存:56
    MA602.A.ABJ.002
      • 1+1269.719291+164.20923
      库存:7
      MA602.A.ABJ.002
        • 1+1594.336811+206.19110
        • 3+1366.462073+176.72070
        • 11+1304.4256211+168.69770
        • 27+1247.7190627+161.36400
        库存:48
