ANT-ELE-S01-008
Data Sheet
by
Product Description
These low-cost, high-performance elements are
designed for use with MAG Series magnetic bases.
Together with the base, these elements form a
reliable and cost effective solution to a diverse
range of applications requiring a semi-permanent
antenna. The antennas are designed for durability
to resist the effects of outdoor environments since
they will commonly be used on vehicles or in other
exposed applications.
16.00 mm
(0.63")
Ø5.59 mm
(0.22")
172.21 mm
(6.78")
Features
Ideal for both stationary and mobile applications
Excellent performance
Low cost
Omnidirectional performance
Outstanding VSWR
Securely attaches to all MAG Series bases
Fully weatherized construction
Attractive and durable black finish
64.01 mm
(2.52")
Ø11.94 mm
(0.47")
323.85 mm
(12.75")
Electrical Specifications
Freq. Range (Band 1):
Freq. Range (Band 2):
VSWR:
Impedance:
Oper. Temp. Range:
Connection:
824–960MHz
1.71–1.99GHz
≤2.0 typ. at center
50-ohms
–40°C to +80°C
M5 x 0.8 threaded base
Ø2.54 mm
(0.10")
61.98 mm
(2.44")
Electrical specifications and plots measured on ANT-MAG-B85
Ordering Information
ANT-ELE-S01-008
25.65 mm
(1.01")
This element requires a MAG1 Series base (sold separately)
Ø9.00 mm
(0.35")
M5 x 0.8
–1–
Revised 11/22/13
VSWR Graph
VSWR
1.463
1.227
Reflected Power
3:1
25%
2:1
11%
1:1
0%
CENTER 895.000MHz
CENTER 1850.000MHz
SPAN 200.000MHz
What is VSWR?
The Voltage Standing Wave Ratio (VSWR) is a measurement of how well
an antenna is matched to a source impedance, typically 50-ohms. It is
calculated by measuring the voltage wave that is headed toward the load
versus the voltage wave that is reflected back from the load. A perfect
match will have a VSWR of 1:1. The higher the first number, the worse the
match, and the more inefficient the system. Since a perfect match cannot
ever be obtained, some benchmark for performance needs to be set. In
the case of antenna VSWR, this is usually 2:1. At this point, 88.9% of the
energy sent to the antenna by the transmitter is radiated into free space
and 11.1% is either reflected back into the source or lost as heat on
the structure of the antenna. In the other direction, 88.9% of the energy
recovered by the antenna is transferred into the receiver. As a side note,
since the “:1” is always implied, many data sheets will remove it and just
display the first number.
How to Read a VSWR Graph
VSWR is usually displayed graphically versus frequency. The lowest point
on the graph is the antenna’s operational center frequency. In most cases,
this will be different than the designed center frequency due to fabrication
tolerances. The VSWR at that point denotes how close to 50-ohms the
antenna gets. Linx specifies the recommended bandwidth as the range
where the typical antenna VSWR is less than 2:1.
159 Ort Lane, Merlin, OR, US 97532
Phone: +1 541 471 6256
Fax: +1 541 471 6251
www.linxtechnologies.com
–2–
Data Sheet ANT-ELE-S01-008
by
很抱歉,暂时无法提供与“ANT-ELE-S01-008”相匹配的价格&库存,您可以联系我们找货
