4G LTE Roadmarker
Part No:
RG.02.02.3000W
Description:
Roadmarker Low Profile 4G LTE Cellular Antenna
with CAB.820 cable assembly
Features:
Low Profile
UV and Vandal Resistant PP Enclosure
IP67 Rated Enclosure
Diameter: 101.4mm
Height: 17.6mm
RoHS & Reach Compliant
SPE-14-8-038-F
1.
Introduction
3
2.
Specifications
4
3.
Antenna Characteristics
7
4.
Radiation Patterns
10
5.
Mechanical Drawing – Roadmarker
29
6.
Mechanical Drawing – Cable Assembly
30
7.
Packaging
31
Changelog
32
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to
make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and
the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
SPE-14-8-038-F
www.taoglas.com
2
1.
Introduction
1.
Introduction
1.
Introduction
1.
Introduction
1.
The Roadmarker RG.02 has been designed to be used inside standard raised non-reflective roadmarkers.
These are designed for, and installed inside, the low profile “Bott’s dots” that can to be mounted directly on
the pavement and therefore the roads.
1.
The Roadmarker uses a high efficiency 4G LTE antenna that can also operate at 3G/2G and NB-IoT/Cat-M
bands, if fallback is required.
1.
Introduction
Introduction
These antennas exhibit relatively high efficiencies in such small packages and reside in a very low-profile
enclosure. They are designed to be mounted directly on the road and pavement just like a standard
roadmarker.
Introduction
Typical Applications Include:
1.
Introduction
• Smart Metering
Remote Monitoring
Security
These antennas have been potted with the epoxy that is traditionally used to secure the roadmarker itself to
the ground. There are no air gaps whatsoever inside the new type approved roadmarker with antenna, in
order to maintain the mechanical integrity. It is presumed that the standard black epoxy will also be used to
install the roadmarker in its final resting place on the ground.
The cable and connector are fully customizable, for further information please contact your regional Taoglas
customer support team.
SPE-14-8-038-F
www.taoglas.com
3
2.
Specifications
Electrical
3.
Antenna
Characteristics2.
Specifications
Band
Frequency
(MHz)
Efficiency(%) Average
Gain(dB) Peak Gain (dBi) Impedance
With
Cable
Assembly
4G/3G
Band 12,13,14,17,28,29
3.
Max Input
Power
Radiation Pattern
10W
Omnidirectional
28
-5.7
2.1
-4.4
3.2
-4.8
1.2
698~806
Without
37
Cable
Assembly
With
Cable
Assembly
4G/3G/NB-IoT/Cat M
Band 5,8,18,19,20,26,27
4.
33
824~960
Without
Antenna Radiation
Patterns3.
Antenna
Cable
42
-3.8
2.4
Assembly
Characteristics2.
4G/3G
Band
1,2,3,4,9,23,25,35,39,66
3.
Cable
Assembly
-7.0
-0.9
27
-5.8
0.8
1710~2200
Without
Cable
Assembly
Cable
Assembly
Specifications
27
-5.7
0.0
39
-4.1
1.7
2300~2690
Without
Cable
Assembly
Mechanical
Dimensions (mm)
4.
50Ω
21
Antenna Characteristics2.
With
4G/3G
Band 7,30,38,40,41
3.
Specifications
With
Height = 17.6 mm and Diameter = 101.4 mm
Cable
WY-100 Coaxial Cable
Antenna
Radiation Patterns3.Antenna
Connector
Characteristics
SMA(M)ST
Casing
UV Resistant PP
Sealant
Potting
4.
Antenna Radiation Patterns
4.
Antenna Radiation Patterns3.Antenna
Characteristics
4.
Characteristics2.
SPE-14-8-038-F
Specifications
www.taoglas.com
4
Environmental
Protection
IP67
Corrosion
5% NaCI for 96hrs
Temperature Range
-40°C to +85°C
Thermal Shock
100 cycles -40°C to +85°C
Humidity
Non-condensing 65°C 95% RH
Shock (Drop Test)
1m drop on concrete 6 axes
Cable Pull
8 Kgf
Tested with 1.5m of cable and with the additional 1.5m cable assembly.
SPE-14-8-038-F
www.taoglas.com
5
5G/4G Bands
Band Number
5GNR / FR1 / LTE / LTE-Advanced / WCDMA / HSPA / HSPA+ / TD-SCDMA
Uplink
Downlink
1
UL: 1920 to 1980
DL: 2110 to 2170
2
UL: 1850 to 1910
DL: 1930 to 1990
3
UL: 1710 to 1785
DL: 1805 to 1880
4
UL: 1710 to 1755
DL: 2110 to 2155
5
UL: 824 to 849
DL: 869 to 894
7
UL: 2500 to 2570
DL:2620 to 2690
8
UL: 880 to 915
DL: 925 to 960
9
UL: 1749.9 to 1784.9
DL: 1844.9 to 1879.9
11
UL: 1427.9 to 1447.9
DL: 1475.9 to 1495.9
12
UL: 699 to 716
DL: 729 to 746
13
UL: 777 to 787
DL: 746 to 756
14
UL: 788 to 798
DL: 758 to 768
17
UL: 704 to 716
DL: 734 to 746
18
UL: 815 to 830
DL: 860 to 875
19
UL: 830 to 845
DL: 875 to 890
UL: 832 to 862
DL: 791 to 821
21
UL: 1447.9 to 1462.9
DL: 1495.9 to 1510.9
22
UL: 3410 to 3490
DL: 3510 to 3590
23
UL:2000 to 2020
DL: 2180 to 2200
24
UL:1625.5 to 1660.5
DL: 1525 to 1559
25
UL: 1850 to 1915
DL: 1930 to 1995
26
UL: 814 to 849
DL: 859 to 894
27
UL: 807 to 824
DL: 852 to 869
28
UL: 703 to 748
DL: 758 to 803
29
UL: -
DL: 717 to 728
30
UL: 2305 to 2315
DL: 2350 to 2360
31
UL: 452.5 to 457.5
DL: 462.5 to 467.5
32
UL: -
DL: 1452 – 1496
35
1850 to 1910
38
2570 to 2620
39
1880 to 1920
40
2300 to 2400
41
2496 to 2690
42
3400 to 3600
43
3600 to 3800
3550 to 3700
48
66
UL: 1710-1780
DL: 2110-2200
71
617 to 698
74/75/76
1427 to 1518
77
3300 to 4200
78
3300 to 3800
79
4400 to 5000
SPE-14-8-038-F
Covered
www.taoglas.com
6
3.
3.1
4.
Return Loss
Characteristics
-10
4.
Return Loss [dB]
4.
-20
-30
-40
Characteristics
WITHOUT CABLE ASSEMBLY
WITH CABLE ASSEMBLY
-50
4.
600
800
1000
1200
1400
1600
1800
2000
[MHz]
Antenna Radiation Patterns3.Frequency
Antenna
2200
2400
2600
2800
3000
Characteristics
3.2
VSWR
10.0
4.
WITH CABLE ASSEMBLY
8.0
6.0
Antenna
Radiation Patterns
VSWR
4.
4.0
4.
2.0
4.
0.0
Antenna
Radiation
Patterns3.
Antenna
600
800
1000
1200
1400
1600
1800
2000
Characteristics
4.
SPE-14-8-038-F
2200
2400
2600
2800
3000
Frequency [MHz]
www.taoglas.com
7
3.3
Efficiency
100
90
WITH CABLE ASSEMBLY
80
Efficiency [%]
70
60
50
40
30
800
1000
1200
1400
1600
1800
2000
2200
2400
2600
2800
3000
Frequency [MHz]
3.4
Peak Gain
4
2
Gain [dBi]
-4
-6
WITH CABLE ASSEMBLY
-8
600
800
1000
1200
1400
1600
1800
2000
2200
2400
2600
2800
3000
Frequency [MHz]
SPE-14-8-038-F
www.taoglas.com
8
3.5
Average Gain
Aver Gain [dB]
-4
-6
-8
-10
WITH CABLE ASSEMBLY
-12
600
800
1000
1200
1400
1600
1800
2000
2200
2400
2600
2800
3000
Frequency [MHz]
SPE-14-8-038-F
www.taoglas.com
9
4.
4.
Radiation Patterns
4.1
4.
Test Setup
4.
4.
4.
4.
4.
4.
AntennaChamber
Radiation
Set up Patterns
SPE-14-8-038-F
VNA Set up
www.taoglas.com
10
4.2
700MHz 3D and 2D Radiation Patterns (Without Cable Assembly)
XY Plane
SPE-14-8-038-F
XZ Plane
YZ Plane
www.taoglas.com
11
850MHz
XY Plane
SPE-14-8-038-F
XZ Plane
YZ Plane
www.taoglas.com
12
900MHz
XY Plane
SPE-14-8-038-F
XZ Plane
YZ Plane
www.taoglas.com
13
1710MHz
XY Plane
SPE-14-8-038-F
XZ Plane
YZ Plane
www.taoglas.com
14
1800MHz
XY Plane
SPE-14-8-038-F
XZ Plane
YZ Plane
www.taoglas.com
15
1910MHz
XY Plane
SPE-14-8-038-F
XZ Plane
YZ Plane
www.taoglas.com
16
2450MHz
XY Plane
SPE-14-8-038-F
XZ Plane
YZ Plane
www.taoglas.com
17
2500MHz
XY Plane
SPE-14-8-038-F
XZ Plane
YZ Plane
www.taoglas.com
18
2600MHz
XY Plane
SPE-14-8-038-F
XZ Plane
YZ Plane
www.taoglas.com
19
4.3
700MHz 3D and 2D Radiation Patterns (With Cable Assembly)
XY Plane
SPE-14-8-038-F
XZ Plane
YZ Plane
www.taoglas.com
850MHz
XY Plane
SPE-14-8-038-F
XZ Plane
YZ Plane
www.taoglas.com
21
900MHz
XY Plane
SPE-14-8-038-F
XZ Plane
YZ Plane
www.taoglas.com
22
1710MHz
XY Plane
SPE-14-8-038-F
XZ Plane
YZ Plane
www.taoglas.com
23
1800MHz
XY Plane
SPE-14-8-038-F
XZ Plane
YZ Plane
www.taoglas.com
24
1910MHz
XY Plane
SPE-14-8-038-F
XZ Plane
YZ Plane
www.taoglas.com
25
2450MHz
XY Plane
SPE-14-8-038-F
XZ Plane
YZ Plane
www.taoglas.com
26
2500MHz
XY Plane
SPE-14-8-038-F
XZ Plane
YZ Plane
www.taoglas.com
27
2600MHz
XY Plane
SPE-14-8-038-F
XZ Plane
YZ Plane
www.taoglas.com
28
5.
6.
Packaging5.
6.
Packaging
7.
Application Note6. Packaging5.
Mechanical Drawing
Mechanical
Drawing
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
7.
Application Note
7.
7.
Mechanical
Drawing
6.
Packaging5.
SPE-14-8-038-F
Mechanical Drawing
www.taoglas.com
29
6.
4.
Characteristics
4.
4.
Characteristics
4.
Characteristics
4.
4.
4.
4.
Characteristics
4.
SPE-14-8-038-F
www.taoglas.com
30
7.
Packaging
6. 1pcs RG.02.02.3000W
Packaging5.
per carton Mechanical Drawing
Dimensions - 350*340*47mm
Weight - 92g
6.
Packaging
7.
Mechanical
Drawing
6.
24pcs RG.02.02.3000W per carton
Dimensions - 589*296*135mm
Weight – 2.4Kg
Packaging5.
Mechanical Drawing
6.
Packaging
7.
7.
Application Note
7.
7.
135mm
589mm
296mm
Mechanical
Drawing
6.
Packaging5.
SPE-14-8-038-F
Mechanical Drawing
www.taoglas.com
31
Changelog for the datasheet
SPE-14-8-038 – RG.02.02.3000W
Revision: F (Current Version)
Date:
Changes:
Changes Made by:
2022-01-24
Updated data.
Gary West
Previous Revisions
Revision: E
Date:
Changes:
Changes Made by:
2020-01-23
Updated data to show 4G
Jack Conroy
Revision: D
Date:
Changes:
Changes Made by:
2017-01-08
Updated to remove reference to manhole covers
as per request by KB. Also added disclaimer
Andy Mahoney
Revision: C
Date:
Changes:
Changes Made by:
2014-05-16
Aine Doyle
Revision: B
Date:
Changes:
Changes Made by:
2014-04-23
Aine Doyle
Revision: A (Original First Release)
Date:
2014-08-17
Notes:
Author:
SPE-14-8-038-F
Aine Doyle
www.taoglas.com
32
www.taoglas.com
SPE-14-8-038-F
© Taoglas 33
www.taoglas.com
很抱歉,暂时无法提供与“RG.02.02.3000W”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 50+812.3036650+105.47359
