MA700.W.A.ABC.001
MA700.W.A.ABC.001
    TAOGLASLIMITED
    MA700.W.A.ABC.001
MA700.W.A.ABC.001 数据手册
Pantheon MA700.W 3-in-1 Permanent Mount Antenna Part No: MA700.W.A.ABC.001 Description: Pantheon MA700.W 3-in-1 Permanent Mount Antenna 5G/4G, GNSS, 2.4/5.8Hz Features: 2 x 5G/4G 600-6000MHz Antennas (MIMO) 1 x GPS/GLONASS/Galileo 1575.42/1602MHz Active Antenna 2 x Wi-Fi 2.4GHz/5.8GHz Antennas (MIMO) IP67 Waterproof Front End SAW Filter High Efficiency / Peak Gain Outdoor Antenna Dimensions: Ø143.2 x 82.4mm Fully Customizable Cable and Connectors RoHs & Reach Compliant SPE-12-8-089-E 1. Introduction 3 2. Specifications 4 3. Antenna Characteristics 8 4. Radiation Patterns 16 5. Mechanical Drawing 38 6. Installation 39 7. Packaging 40 Changelog 41 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-12-8-089-E SPE-12-8-146-K www.taoglas.com 2 1. Introduction 1. Introduction 1. Introduction 1. Introduction 1. 1. Introduction The Taoglas MA05.W0 Pantheon 3-in-1 antenna is an omnidirectional heavy-duty, fully IP67 waterproof external M2M antenna for use in telematics, transportation, and remote monitoring applications. This unique antenna delivers powerful antenna technology for 5G/4G Cellular and Wi-Fi, plus GNSS for nextgeneration multiple wireless technology systems. The GNSS antenna covers the GPS/GLONASS/Galileo bands and includes a Front End SAW Filter for improved performance. Introduction The Pantheon MA700.W covers all 5G bands from 600-6000MHz, exhibiting excellent performance at key 5G bands such as band 71(617MHz) and the repurposed CBRS and C-band frequencies from 34004200MHz. This ensures the Pantheon is prepared for mission critical applications. 1. Typical Applications Include: Introduction 1. - Public Safety Passenger Bus and Rail Services Digital Signage Commerical Transportation and Fleet Management Introduction All five high-performance antennas are integrated into an extremely robust IP67 permanent mount compact antenna package measuring just 82.4mm in height and 143.2mm in diameter. The antenna has its own ground-plane and can radiate on any mounting environment like metal or plastic without affecting performance. The cables are low loss allowing for lengths of up to 10 meters (32' and 9.70"), critical for buses, trains, and other commercial transport applications. Customized cables and connector version available, contact your regional Taoglas customer support team for further information. SPE-12-8-089-E SPE-12-8-146-K www.taoglas.com 3 2. Specifications GNSS Frequency Bands Covered L1 L2 L5 L6 3. Specifications GPS/QZSSAntenna Characteristics2. 1575.42MHz 1227.6MHz 1176.45MHz 1278.75MHz GLONASS 3. ■ □ □ □ L5R 1176.45MHz L3PT 1201.5MHz L2PT 1246MHz L1CR 1575.42MHz L1PT 1602MHz □ □ □ □ ■ E5a 1176.45MHz E5b 1201.5MHz E4 1215MHz E3 1256MHz E6 1278.75MHz E2 1561MHz E1 1575.42MHz □ □ ■ Antenna Characteristics Galileo 4. □ □ □ □ Antenna Radiation Patterns3. Antenna B1 B2 1207.14MHz B3 □ □ □ E5B(B2)/ E6(B3) 1268.56MHz E2(B1) 1561MHz BeiDou 1561MHz Characteristics2. Compass 3. SBAS 3. 4. 1268.52MHz Specifications Antenna Characteristics2. □ □ Omnistar 1542.5MHz WAAS/EGN OS 1575.42MHz □ □ Specifications Antenna CharacteristicsGNSS Electrical Centre Frequency 1575.42MHz / 1602MHz Bandwidth 10MHz Antenna Radiation Patterns3.Antenna Radiation Efficiency 50(without cable) VSWR 2 Characteristics Impedance 50Ω DC Power Input Range DC Input 4. 4. 3.3V 4.0V Antenna Radiation Frequency 1575.42 Patterns 1602 5.5V 1575.42 1602 1575.42 1602 VSWR 2 2 2 2 2 2 LNA Gain 29.2 29 31 31 32.3 32 3.2 3.4 3.4 9.4 15 15 3.1 3.1 3.2 Antenna Radiation Patterns3. Antenna Noise Figure Power Consumption Characteristics Band Attenuation 4. 3 - 5V 7.5 7.5 1520MHz: -20dB 1642MHz: -20dB 9.4 1520MHz: -20dB 1642MHz: -20dB 1520MHz: -20dB 1642MHz: -20dB Antenna Radiation Patterns3.Antenna Characteristics2. SPE-12-8-089-E SPE-12-8-146-K Specifications www.taoglas.com 4 5G/4G MIMO Band 5GNR/4G Band 5,8,12,13,14,17,18,20, 26,27,28, 29,71 617~960 5GNR/4G Band 21,32,74,75,76 1427~1518 4G/3G Band 1,2,3,4,9,23,25,35,39,66 1710~2200 Wi-Fi 2400 4G/3G Band 7,38,41 2490~2690 5GNR/4G Band 22,42,43,48,77,78,79 3300~5000 LTE5200/ Wi-Fi 5800 5150~5925 Peak Gain Efficiency Average Gain (%) (dB) Free Space 61 -2.2 3.3 30X30cm GroundPlane 35 -1.7 3.5 Free Space 36 -4.4 2.8 30X30cm GroundPlane 21 -4.8 2.8 Free Space 58 -2.4 3.1 30X30cm GroundPlane 48 -2.4 5.4 Free Space 44 -3.6 2.1 30X30cm GroundPlane 64 -3.2 4.0 Free Space 51 -3.0 4.6 30X30cm GroundPlane 65 -2.6 4.7 Free Space 34 -5.2 5.8 30X30cm GroundPlane 41 -5.1 8.1 Free Space 16 -8.1 1.2 30X30cm GroundPlane 23 -8.2 2.4 Frequency (MHz) VSWR Impedance Polarization 3 Max 50Ω Linear (dBi) Wi-Fi MIMO 2.4GHz / 5GHz Frequency (MHz) Efficiency (%) Average Gain (dB) Peak Gain (dBi) 2400~2500 36 -4.5 3.7 5150~5850 51 -2.9 VSWR Polarization Impedance 2 Max Linear 50 Ω 5.4 All measurements were conducted with 0.5m low loss CFD200 cable. SPE-12-8-089-E SPE-12-8-146-K www.taoglas.com 5 Mechanical Antenna Dimensions Height 85.7mm x Diameter 145.6mm Casing Wonderloy PC-540 PC/ABS Alloy Waterproof IP67 Cables 5G/4G & Wi-Fi - 3M CFD-200 GNSS - 3M RG-174 Connectors GNSS & 5G/4G – SMA(M) Wi-Fi – RP-SMA(M) Base and thread CAN10 Zinc Alloy Thread diameter M30 x 2 (30mm) Nut Nickel Plated Steel Foam 3M 9448HK Weight(kg) 1.29(Antenna) Recommended Torque for Mounting 5-7Nm Envioronmental Operation Temperature -40°C to 85°C Storage Temperature -40°C to 90°C Humidity Non-condensing 65°C 95% RH SPE-12-8-089-E SPE-12-8-146-K www.taoglas.com 6 5G/4G Bands Band Number 5GNR / FR1 / LTE / LTE-Advanced / WCDMA / HSPA / HSPA+ / TD-SCDMA Uplink Downlink 1 UL: 1920 to 1980 DL: 2110 to 2170 2 UL: 1850 to 1910 DL: 1930 to 1990 3 UL: 1710 to 1785 DL: 1805 to 1880 4 UL: 1710 to 1755 DL: 2110 to 2155 5 UL: 824 to 849 DL: 869 to 894 7 UL: 2500 to 2570 DL:2620 to 2690 8 UL: 880 to 915 DL: 925 to 960 9 UL: 1749.9 to 1784.9 DL: 1844.9 to 1879.9 11 UL: 1427.9 to 1447.9 DL: 1475.9 to 1495.9 12 UL: 699 to 716 DL: 729 to 746 13 UL: 777 to 787 DL: 746 to 756 14 UL: 788 to 798 DL: 758 to 768 17 UL: 704 to 716 DL: 734 to 746 18 UL: 815 to 830 DL: 860 to 875 19 UL: 830 to 845 DL: 875 to 890 20 UL: 832 to 862 DL: 791 to 821 21 UL: 1447.9 to 1462.9 DL: 1495.9 to 1510.9 22 UL: 3410 to 3490 DL: 3510 to 3590 23 UL:2000 to 2020 DL: 2180 to 2200 24 UL:1625.5 to 1660.5 DL: 1525 to 1559 25 UL: 1850 to 1915 DL: 1930 to 1995 26 UL: 814 to 849 DL: 859 to 894 27 UL: 807 to 824 DL: 852 to 869 28 UL: 703 to 748 DL: 758 to 803 29 UL: - DL: 717 to 728 30 UL: 2305 to 2315 DL: 2350 to 2360 31 UL: 452.5 to 457.5 DL: 462.5 to 467.5 32 UL: - DL: 1452 - 1496 35 1850 to 1910 38 2570 to 2620 39 1880 to 1920 40 2300 to 2400 41 2496 to 2690 42 3400 to 3600 43 3600 to 3800 48 3550 to 3700 66 UL: 1710-1780 DL: 2110-2200 71 617 to 698 74/75/76 1427 to 1518 78 3300 to 3800 79 4400 to 5000 85 SPE-12-8-089-E SPE-12-8-146-K 698-716 728-746 Covered ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓  ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ www.taoglas.com 7 3. 4. Antenna Characteristics 3.1 Return Loss Antenna Radiation Patterns3.Antenna 0 Characteristics -5 4. Antenna Radiation Patterns Return Loss [dB] 4. -10 -15 Antenna Radiation Patterns3.Antenna Characteristics -20 Free Space - MIMO1 30cm X 30cm Groundplane - MIMO1 -25 4. 600 1100 1600 2100 2600 3100 3600 Antenna Radiation Patterns3. Antenna Frequency [MHz] 4100 4600 5100 5600 Characteristics 3.2 Efficiency 100 4. Antenna Radiation Patterns 90 Free Space -MIMO1 30cm X 30cm Groundplane -MIMO1 80 70 4. Antenna Radiation Patterns 60 Efficiency [%] 4. 50 40 Antenna Radiation Patterns 30 20 10 4. 0 Antenna Radiation Patterns3.Antenna 600 1100 Characteristics 4. 1600 2100 2600 3100 3600 4600 5100 5600 Frequency [MHz] Antenna Radiation Patterns3.Antenna SPE-12-8-089-E SPE-12-8-146-K 4100 www.taoglas.com 8 3.3 Peak Gain 8 7 6 5 4 Gain [dBi] 3 2 1 0 -1 -2 -3 -4 Free Space -MIMO1 -5 30cm X 30cm Groundplane -MIMO1 -6 600 1100 1600 2100 2600 3100 3600 4100 4600 5100 5600 5100 5600 Frequency [MHz] 3.4 Average Gain 0 -1 -2 Aver Gain [dB] -3 -4 -5 -6 -7 -8 -9 Free Space -MIMO1 30cm X 30cm Groundplane -MIMO1 -10 600 1100 1600 2100 2600 3100 3600 4100 4600 Frequency [MHz] SPE-12-8-089-E SPE-12-8-146-K www.taoglas.com 9 3.5 Return Loss – WiFi (2.4/5 GHz) 0 Return Loss [dB] -5 -10 -15 -20 -25 -30 2000 2500 3000 3500 4000 4500 5000 5500 6000 4500 5000 5500 6000 Frequency [MHz] 3.6 VSWR - WiFi (2.4/5 GHz) 5.0 VSWR 4.0 3.0 2.0 1.0 2000 2500 3000 3500 4000 Frequency [MHz] SPE-12-8-089-E SPE-12-8-146-K www.taoglas.com 10 3.7 Efficiency - WiFi (2.4/5 GHz) 100 90 80 Efficiency [%] 70 60 50 40 30 20 10 0 2000 2500 3000 3500 4000 4500 5000 5500 4500 5000 5500 6000 Frequency [MHz] 3.8 Peak Gain - WiFi (2.4/5 GHz) 8 Gain [dBi] 6 4 2 0 -2 2000 2500 3000 3500 4000 6000 Frequency [MHz] SPE-12-8-089-E SPE-12-8-146-K www.taoglas.com 11 3.10 Average Gain - WiFi (2.4/5 GHz) 0 -1 -2 Aver Gain [dB] -3 -4 -5 -6 -7 -8 -9 -10 2000 2500 3000 3500 4000 4500 5000 5500 6000 Frequency [MHz] 3.11 Block Diagram - GPS/GLONASS/GALILEO SPE-12-8-089-E SPE-12-8-146-K www.taoglas.com 12 3.12 Return Loss - GNSS 0 -5 Return Loss [dB] -10 -15 -20 -25 -30 1400 1450 1500 1550 1600 1650 1700 Frequency [MHz] SPE-12-8-089-E SPE-12-8-146-K www.taoglas.com 13 3.13 GNSS – Efficency 100 Efficiency [%] 75 50 25 0 1400 1450 1500 1550 1600 1650 1700 Frequency [MHz] 3.14 GNSS – Peak Gain 10 5 Gain [dBi] 0 -5 -10 -15 -20 1400 1450 1500 1550 1600 1650 1700 Frequency [MHz] SPE-12-8-089-E SPE-12-8-146-K www.taoglas.com 14 3.15 GNSS – Average Gain 0 -1 -2 Aver Gain [dB] -3 -4 -5 -6 -7 -8 -9 -10 1400 1450 1500 1550 1600 1650 1700 Frequency [MHz] 3.16 GNSS - Axial Ratio 22 20 18 16 Axial Ratio 14 L1/E1/B1/G1 12 10 8 6 4 2 0 1500 1520 1540 1560 1580 1600 1620 1640 1660 Frequency [MHz] SPE-12-8-089-E SPE-12-8-146-K www.taoglas.com 15 4. Radiation Patterns 4. 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4.1 Test Setup VNA Test Set-up 4. Chamber Test Set-up Antenna Radiation Patterns SPE-12-8-089-E SPE-12-8-146-K www.taoglas.com 16 4.2 705MHz 3D and 2D Cellular Radiation Patterns XY Plane SPE-12-8-089-E SPE-12-8-146-K XZ Plane YZ Plane www.taoglas.com 17 750MHz XY Plane SPE-12-8-089-E SPE-12-8-146-K XZ Plane YZ Plane www.taoglas.com 18 825MHz XY Plane SPE-12-8-089-E SPE-12-8-146-K XZ Plane YZ Plane www.taoglas.com 19 880MHz XY Plane SPE-12-8-089-E SPE-12-8-146-K XZ Plane YZ Plane www.taoglas.com 20 960MHz XY Plane SPE-12-8-089-E SPE-12-8-146-K XZ Plane YZ Plane www.taoglas.com 21 1710MHz XY Plane SPE-12-8-089-E SPE-12-8-146-K XZ Plane YZ Plane www.taoglas.com 22 1880MHz XY Plane SPE-12-8-089-E SPE-12-8-146-K XZ Plane YZ Plane www.taoglas.com 23 1990MHz XY Plane SPE-12-8-089-E SPE-12-8-146-K XZ Plane YZ Plane www.taoglas.com 24 2170MHz XY Plane SPE-12-8-089-E SPE-12-8-146-K XZ Plane YZ Plane www.taoglas.com 25 2300MHz XY Plane SPE-12-8-089-E SPE-12-8-146-K XZ Plane YZ Plane www.taoglas.com 26 2500MHz XY Plane SPE-12-8-089-E SPE-12-8-146-K XZ Plane YZ Plane www.taoglas.com 27 2570MHz XY Plane SPE-12-8-089-E SPE-12-8-146-K XZ Plane YZ Plane www.taoglas.com 28 2700MHz XY Plane SPE-12-8-089-E SPE-12-8-146-K XZ Plane YZ Plane www.taoglas.com 29 3200MHz XY Plane SPE-12-8-089-E SPE-12-8-146-K XZ Plane YZ Plane www.taoglas.com 30 4200MHz XY Plane SPE-12-8-089-E SPE-12-8-146-K XZ Plane YZ Plane www.taoglas.com 31 5150MHz XY Plane SPE-12-8-089-E SPE-12-8-146-K XZ Plane YZ Plane www.taoglas.com 32 5550MHz XY Plane SPE-12-8-089-E SPE-12-8-146-K XZ Plane YZ Plane www.taoglas.com 33 4.3 Wi-Fi 3D and 2D Radiation Patterns XZ Plane SPE-12-8-089-E SPE-12-8-146-K YZ Plane XY Plane www.taoglas.com 34 5.5GHz XZ Plane SPE-12-8-089-E SPE-12-8-146-K YZ Plane XY Plane www.taoglas.com 35 5.8GHz XZ Plane SPE-12-8-089-E SPE-12-8-146-K YZ Plane XY Plane www.taoglas.com 36 4.4 GNSS 3D and 2D Radiation Patterns XZ Plane SPE-12-8-089-E SPE-12-8-146-K YZ Plane XY Plane www.taoglas.com 37 5. Mechanical Drawing rawing (Units: mm) 6. Packaging5. 6. Packaging 7. SPE-12-8-089-E SPE-12-8-146-K Mechanical Drawing Application Note6. Packaging5. Mechanical www.taoglas.com 38 6. 8. Installation Packaging 6. 6. Packaging5. Packaging5. 6. 6. Packaging Packaging Mechanical Drawing Mechanical Drawing 7. Application Note6. Packaging5. 7. Application Note6. Packaging5. Drawing Drawing 6. 6. Packaging5. Packaging5. 6. 6. Packaging Packaging 7. 7. Application Note6. Packaging Application Note6. Packaging 7. 7. Application Note Application Note 7. 7. Application Note6. Packaging Application Note6. Packaging Mechanical Drawing Mechanical Drawing 7. Application Note6. Packaging5. 7. Application Note6. Packaging5. Drawing Drawing 6. SPE-12-8-089-E Packaging5. 6. SPE-12-8-146-K Packaging5. Mechanical Mechanical Mechanical Mechanical Mechanical Drawing Mechanical Drawing www.taoglas.com 39 7. 8. Packaging 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-12-8-089-E SPE-12-8-146-K Mechanical Drawing www.taoglas.com 40 Changelog for the datasheet SPE-12-8-089 – MA700.W.A.ABC.001 Revision: E (Current Version) Date: Changes: Changes Made by: 2021-11-16 Rebranded as 5G, updated datasheet template to new template & updated installation guide torque values. Gary West Previous Revisions Revision: D Date: Changes: 2017-04-04 LTE Band Table Changes Made by: Peter Monahan Revision: C Date: Changes: Changes Made by: 2013-11-07 Added GPS/GLONASS Aine Doyle Revision: B Date: Changes: 2012-09-13 Changes Made by: Revision: A (Original First Release) Date: Notes: 2012-07-17 Author: SPE-12-8-089-E SPE-12-8-146-K www.taoglas.com 41 www.taoglas.com SPE-12-8-089-E SPE-12-8-146-K © Taoglas www.taoglas.com 42
MA700.W.A.ABC.001
物料型号:MA700.W.A.ABC.001 器件简介:Pantheon MA700.W 3-in-1 Permanent Mount Antenna,支持5G/4G、GNSS、2.4/5.8GHz频段。
引脚分配:集成了5个高性能天线,包括2个5G/4G 600-6000MHz天线(MIMO)、1个GPS/GLONASS/Galileo 1575.42/1602MHz有源天线、2个Wi-Fi 2.4GHz/5.8GHz天线(MIMO)。
参数特性:IP67防水,前端SAW滤波器,高效率/峰值增益户外天线,尺寸为Ø143.2 x 82.4mm,可完全定制电缆和连接器。
功能详解:覆盖所有5G频段,包括关键频段如71(617MHz)和重新利用的CBRS及C频段(3400-4200MHz),适用于关键任务应用。
应用信息:公共安全、客运公交和铁路服务、数字标牌、商业运输和车队管理。
封装信息:天线尺寸为高度85.7mm x 直径145.6mm,外壳材料为Wonderloy PC-540 PC/ABS合金,连接器为GNSS & 5G/4G - SMA(M),Wi-Fi - RP-SMA(M),基座和螺纹为CAN10锌合金,螺纹直径为M30x2(30mm),螺母为镀镍钢,重量为1.29kg,推荐安装扭矩为5-7Nm,工作温度范围为-40°C至85°C,存储温度范围为-40°C至90°C,湿度为65°C下95% RH非凝结。
