ANT-2.4-PW-LP
ANT-2.4-PW-LP
    LINXTECHNOLOGIES(灵思)
    ANT-2.4-PW-LP
ANT-2.4-PW-LP 数据手册
ANT-2.4-PW-LP Data Sheet by Product Description The LP Series antennas utilize a helical element which greatly reduces the antenna’s size while allowing favorable performance characteristics. These compact antennas are cosmetically attractive and inexpensive, making them ideal for volume applications. The LP Series mounts directly to a PCB with a single screw, eliminating the expense of a connector while meeting FCC Part 15 requirements. 8.0 mm (0.31") 33.5 mm (1.32") 17.0 mm (0.67") Features • • • • • • • 10.4 mm (0.41") 50.5 mm (1.99") Very low cost Compact housing Excellent performance Omni-directional pattern Weather-resistant Screw-mount Use with plastic* or metal enclosures 9.5 mm (0.37") 1.7 mm (0.07") 3.7 mm 2.3 mm 1.5 mm (0.15") (0.09") (0.06") 8.0 mm (0.31") * Requires proximity ground plane 7.4 mm (0.29") 5.3 mm (0.21") 6.0 mm (0.24") 3.2 mm (0.13") 3.1 mm (0.12") 6/32 UNC Electrical Specifications Center frequency: Bandwidth: Wavelength: VSWR: Peak Gain: Impedance: Connection: Oper. Temp. Range: 2.45GHz 200MHz ¼-wave ≤ 1.9 typical –1.9dBi 50-ohms Screw-mount –20°C to +85°C ANT-xxx-PW-LP Recommended Footprint Recommended Footprint 6.60 mm (0.260”) 5.33 mm (0.210”) 8.89 mm (0.350”) Electrical specifications and plots measured with a 3.81 cm x 8.38 cm (1.5" x 3.3") reference ground plane Ordering Information ANT-2.4-PW-LP Ø3.88 mm 3.30 mm (0.150”) (0.130”) –1– Revised 12/4/13 Counterpoise Quarter-wave or monopole antennas require an associated ground plane counterpoise for proper operation. The size and location of the ground plane relative to the antenna will affect the overall performance of the antenna in the final design. When used in conjunction with a ground plane smaller than that used to tune the antenna, the center frequency typically will shift higher in frequency and the bandwidth will decrease. The proximity of other circuit elements and packaging near the antenna will also affect the final performance. For further discussion and guidance on the importance of the ground plane counterpoise, please refer to Linx Application Note AN-00501: Understanding Antenna Specifications and Operation. VSWR Graph VSWR Reflected Power 1.291 3:1 25% 2:1 11% 1:1 2.250GHz 0% 2.650GHz 2.450GHz What is VSWR? The Voltage Standing Wave Ratio (VSWR) is a measurement of how well an antenna is matched to a source impedance, typically 50-ohms. It is calculated by measuring the voltage wave that is headed toward the load versus the voltage wave that is reflected back from the load. A perfect match will have a VSWR of 1:1. The higher the first number, the worse the match, and the more inefficient the system. Since a perfect match cannot ever be obtained, some benchmark for performance needs to be set. In the case of antenna VSWR, this is usually 2:1. At this point, 88.9% of the energy sent to the antenna by the transmitter is radiated into free space and 11.1% is either reflected back into the source or lost as heat on the structure of the antenna. In the other direction, 88.9% of the energy recovered by the antenna is transferred into the receiver. As a side note, since the “:1” is always implied, many data sheets will remove it and just display the first number. How to Read a VSWR Graph VSWR is usually displayed graphically versus frequency. The lowest point on the graph is the antenna’s operational center frequency. In most cases, this will be different than the designed center frequency due to fabrication tolerances. The VSWR at that point denotes how close to 50-ohms the antenna gets. Linx specifies the recommended bandwidth as the range where the typical antenna VSWR is less than 2:1. –2– Data Sheet ANT-2.4-PW-LP by
ANT-2.4-PW-LP 价格&库存
很抱歉,暂时无法提供与“ANT-2.4-PW-LP”相匹配的价格&库存,您可以联系我们找货
