RFMTA250800NNLB001
RFMTA250800NNLB001
    WALSIN(华新科)
    RFMTA250800NNLB001
RFMTA250800NNLB001 数据手册
Approval sheet Metal Stamping Antenna 2.4/5.x GHz Dual Band Working Frequency P/N: RFMTA250800NNLB001 Customer: Customer ‘s Part No.: Approval No.: Issue Date: Page 1 of 15 RFMTA250800NNLB001_V02 Jun. 2015 Approval sheet Version V01 V02 Page 2 of 15 Date 2015 Jun. 2015 Sep. Description New Release 變更鐵件尺寸 RFMTA250800NNLB001_V02 Author HWCHAN PIPI Jun. 2015 Approval sheet Antenna Specification ELECTRICAL CHARACTERISTICS Item Specification Working Frequency Range 2.4 ~ 2.5 / 5.15 ~5.85 GHz Return Loss -10dB(Max) 2.64 dBi(@2.4 ~ 2.5 GHz) Peak Gain 4.48 dBi(@5.15 ~5.85 GHz) VSWR 2 max. Polarization Linear Vertical Radiation Pattern Directional Impedance 50 *Note 1. Central Frequency should be defined after customers’ application approval. MATERIAL TABLE Items Description SUS430 T=0.4 mm(鍍鎳) Antenna Material ORDERING RULE RF MTA Product Code Type Code 2508 00 N Metal Cable Connector Dimension Length (unit: Brand (Unit: mm) cm) N L B 0 01 Type of Connector Application Project status Wire Diameter Project 0: 0GHz 3: 3GHz 5: 5 GHz 6: 6GHz A: N Per 2 digits of Device MTA: Metal Antenna A: 2.4GHz D:IPEX III ISM band E: IPEX IV U:MURATA N: None Page 3 of 15 A: Reverse Female F: IPEX A13 B: cable length Reverse H: Hirose e.g.: 2508 Male I: IPEX Length e.g.: 00 F: Female M: MMCX 25.70mm, None Length M: Male S: SMA Width8.08mm N: None T: TNC length, width 2 digits for Walsin RF C:MCX B: GSM 900/1800 B: MP dual band T:During G: GPS band Test L: 2.4/5.2/5.8 X: Pile Run GHz 0:None 1:∅0.81 3:∅1.13 01~99 series 6:RG316 7:∅1.37 number 8:RG178 tri-band N: NFC T:LTE band W: WCDMA band RFMTA250800NNLB001_V02 Jun. 2015 Approval sheet DIMENSIONS Page 4 of 15 RFMTA250800NNLB001_V02 Jun. 2015 Approval sheet Test Report ■PCB Layout Page 5 of 15 RFMTA250800NNLB001_V02 Jun. 2015 Approval sheet ■ELECTRICAL CHARACTERISTICS Return Loss Page 6 of 15 RFMTA250800NNLB001_V02 Jun. 2015 Approval sheet ■Antenna Efficiency and Peak Gain Page 7 of 15 RFMTA250800NNLB001_V02 Jun. 2015 Approval sheet Page 8 of 15 RFMTA250800NNLB001_V02 Jun. 2015 Approval sheet ■RADIATION PATTERN 2400~2500 MHz Phi=0.00deg Gain . dB Page 9 of 15 RFMTA250800NNLB001_V02 Jun. 2015 Approval sheet Phi=90.00deg Gain . dB Page 10 of 15 RFMTA250800NNLB001_V02 Jun. 2015 Approval sheet Theta=90.00deg Gain . dB Page 11 of 15 RFMTA250800NNLB001_V02 Jun. 2015 Approval sheet 5150~5850 MHz Phi=0.00deg Gain . dB Page 12 of 15 RFMTA250800NNLB001_V02 Jun. 2015 Approval sheet Phi=90.00deg Gain . dB Page 13 of 15 RFMTA250800NNLB001_V02 Jun. 2015 Approval sheet Theta=90.00deg Gain . dB Page 14 of 15 RFMTA250800NNLB001_V02 Jun. 2015 Approval sheet Packaging Page 15 of 15 RFMTA250800NNLB001_V02 Jun. 2015
RFMTA250800NNLB001 价格&库存
很抱歉,暂时无法提供与“RFMTA250800NNLB001”相匹配的价格&库存,您可以联系我们找货
