RFMTA280715IMAB301
RFMTA280715IMAB301
    WALSIN(华新科)
    RFMTA280715IMAB301
RFMTA280715IMAB301 数据手册
Approval sheet   Metal Stamping Antenna 2.4 GHz Working Frequency P/N: RFMTA280715IMAB301 Customer: Customer ‘s Part No.: Approval No.: Issue Date: Page 1 of 13 RFMTA280715IMAB301_V03 Aug. 2014 Approval sheet ELECTRICAL CHARACTERISTICS Item Specification Working Frequency Range 2.4 GHz (Note-1) Gain(Peak) 2.4 GHz: 2.82 dBi Return Loss -10dB(Max) VSWR 2 max. Polarization Linear Vertical Radiation Pattern Directional Impedance 50 *Note 1. Central Frequency should be defined after customers’ application approval. MATERIAL TABLE Antenna Material Items Description SUS430 鍍鎳 T=0.3mm Coaxial Cable Ø1.13(Black) Connector IPEX ORDERING RULE RF MTA Product Code Type Code 2807 15 I Metal Cable Connector Dimension Length (unit: Brand (Unit: mm) cm) M A B 3 01 Type of Connector Application Project status Wire Diameter Project 0: 0GHz 3: 3GHz 5: 5 GHz 6: 6GHz A: N Per 2 digits of length, width Walsin RF Device MTA: Metal Antenna e.g.: 2611 Length 26.55mm, Width 11.30mm C:MCX A: 2.4GHz D:IPEX III ISM band E: IPEX IV U:MURATA N: None Page 2 of 13 A: Reverse Female F: IPEX A13 B: cable length Reverse H: Hirose Male I: IPEX e.g.: 00 F: Female M: MMCX None Cable M: Male S: SMA N: None T: TNC 2 digits for B: GSM 900/1800 B: MP dual band T:During G: GPS band Test L: 2.4/5.2/5.8 X: Pile Run GHz 0:None 1:∅0.81 3:∅1.13 01~99 series 6:RG316 7:∅1.37 number 8:RG178 tri-band N: NFC T:LTE band W: WCDMA band RFMTA280715IMAB301_V03 Aug. 2014 Approval sheet DIMENSIONS Page 3 of 13 RFMTA280715IMAB301_V03 Aug. 2014 Approval sheet Test Report ■PCB Layout Page 4 of 13 RFMTA280715IMAB301_V03 Aug. 2014 Approval sheet ■Electrical Characteristics Return Loss & VSWR & Smith Chart Page 5 of 13 RFMTA280715IMAB301_V03 Aug. 2014 Approval sheet ■Antenna Peak Gain 2400~2500 MHz Page 6 of 13 RFMTA280715IMAB301_V03 Aug. 2014 Approval sheet ■RADIATION PATTERN 2400~2500 MHz Phi=0.00deg Page 7 of 13 RFMTA280715IMAB301_V03 Aug. 2014 Approval sheet Phi=90.00deg Page 8 of 13 RFMTA280715IMAB301_V03 Aug. 2014 Approval sheet Theta=90.00deg Page 9 of 13 RFMTA280715IMAB301_V03 Aug. 2014 Approval sheet RELIABILITY TEST Page 10 of 13 RFMTA280715IMAB301_V03 Aug. 2014 Approval sheet Page 11 of 13 RFMTA280715IMAB301_V03 Aug. 2014 Approval sheet Page 12 of 13 RFMTA280715IMAB301_V03 Aug. 2014 Approval sheet PACKAGE Page 13 of 13 RFMTA280715IMAB301_V03 Aug. 2014
RFMTA280715IMAB301 价格&库存
很抱歉,暂时无法提供与“RFMTA280715IMAB301”相匹配的价格&库存,您可以联系我们找货
