RFPCA460611IMAB301_
RFPCA460611IMAB301_
    WALSIN(华新科)
    RF ANTENNA PCB TRACE 2.4GHZ
RFPCA460611IMAB301_ 数据手册
Approval sheet PCB ANTENNA 2.4 GHz Band Working Frequency Halogens Free Product P/N: RFPCA460611IMAB301 Customer: Customer ‘s Part No.: Approval No.: Issue Date: *Contents in this sheet are subject to change without prior notice. Page 1 of 10 RFPCA460611IMAB301_V01 Mar. 2015 Approval sheet Version V01 Page 2 of 10 Date 2015 Mar. Description New Release RFPCA460611IMAB301_V01 Author HWCHAN Mar. 2015 Approval sheet ELECTRICAL CHARACTERISTICS Item Specification Frequency Range 2.4 ~ 2.5 GHz Impedance 50 Ohm Nominal Return Loss -10 dB (Max) Peak Gain 3.85 dBi VSWR 2.0 (Max) Radiation Omni-directional Polarization Admitted Power Linear Vertical 1W *note-1: Electrical characteristics will depend on customer’s final application. MATERIAL TABLE Items Description Cable ∮1.13(Black) Connector IPEX FPC Antenna FR4(綠漆板) T=0.8mm Sponge+Doubel Tape EVA+G9000 ORDERING RULE RF PCA Type Code Product Code Walsin RF Device PCA: PCB Antenna Page 3 of 10 4606 PCB Dimension (Unit: mm) 11 I Cable Connector Length (unit: Brand cm) A: N C:MCX D:IPEX III Per 2 digits of 2 digits for E: IPEX IV length, width cable length F: IPEX A13 H: Hirose e.g.: 4606 e.g.: 11 I: IPEX Length Cable M: MMCX 46.5mm, Width Length:11cm S: SMA 6.0mm T: TNC U:MURATA N: None M A B Type of Connector Application Project status 0: 0GHz 3: 3GHz 5: 5GHz 6: 6GHz A: 2.4GHz ISM band A: Reverse Female B: GSM 900/1800 B: Reverse Male dual band F: Female G: GPS band M: Male L: 2.4/5.2/5.8 GHz N: None tri-band N: NFC T: LTE band W: WCDMA band RFPCA460611IMAB301_V01 3 01 Wire Project Diameter 0:None 1:∅ 0.81 B: MP 01~99 3:∅ 1.13 T:Durin series g Test 6:RG316 X: Pile Run 7:∅ 1.37 number 8:RG178 Mar. 2015 Approval sheet Appendix A: Dimensions Page 4 of 10 RFPCA460611IMAB301_V01 Mar. 2015 Approval sheet Test Report ■ELECTRICAL CHARACTERISTICS Return Loss Page 5 of 10 RFPCA460611IMAB301_V01 Mar. 2015 Approval sheet ■Antenna Efficiency & Peak Gain 2400~2500 MHz Page 6 of 10 RFPCA460611IMAB301_V01 Mar. 2015 Approval sheet ■RADIATION PATTERN 2400~2500 MHz Phi=0.00deg Gain . dB Page 7 of 10 RFPCA460611IMAB301_V01 Mar. 2015 Approval sheet 2400~2500 MHz Phi=90.00deg Gain . dB Page 8 of 10 RFPCA460611IMAB301_V01 Mar. 2015 Approval sheet 2400~2500 MHz Theta=90.00deg Gain . dB Page 9 of 10 RFPCA460611IMAB301_V01 Mar. 2015 Approval sheet Packaging Page 10 of 10 RFPCA460611IMAB301_V01 Mar. 2015
RFPCA460611IMAB301_ 价格&库存
很抱歉,暂时无法提供与“RFPCA460611IMAB301_”相匹配的价格&库存,您可以联系我们找货
