RFPCA500609IMAB301
RFPCA500609IMAB301
    WALSIN(华新科)
    RFPCA500609IMAB301
RFPCA500609IMAB301 数据手册
Approval sheet PCB ANTENNA 2.4 GHz Band Working Frequency Halogens Free Product P/N: RFPCA500609IMAB301 Customer: Customer ‘s Part No.: Approval No.: Issue Date: *Contents in this sheet are subject to change without prior notice. Page 1 of 11 RFPCA500609IMAB301_V01 Dec. 2014 Approval sheet Version V01 Page 2 of 11 Date 2014 Dec. Description New Release RFPCA500609IMAB301_V01 Author HWCHAN Dec. 2014 Approval sheet ELECTRICAL CHARACTERISTICS Item Specification Frequency Range 2.4 ~ 2.5 GHz Impedance 50 Ohm Nominal Return Loss -10 dB (Max) Peak Gain 4.53dBi VSWR 2.0 (Max) Radiation Omni-directional Polarization Admitted Power Linear Vertical 1W *note-1: Electrical characteristics will depend on customer’s final application. MATERIAL TABLE Items Description Cable ψ1.13(Gray) Connector IPEX FPC Antenna FR4(綠漆噴錫板) T=0.8mm Sponge+Doubel Tape EPDM+G9000 ORDERING RULE RF PCA Type Code Product Code Walsin RF Device PCA: PCB Antenna Page 3 of 11 5006 PCB Dimension (Unit: mm) 09 I Cable Connector Length (unit: Brand cm) A: N C:MCX D:IPEX III Per 2 digits of 2 digits for E: IPEX IV length, width cable length F: IPEX A13 H: Hirose e.g.: 5006 e.g.: 09 I: IPEX Length 50mm, Cable M: MMCX Width 6.2mm Length:9cm S: SMA T: TNC U:MURATA N: None M A B Type of Connector Application Project status 0: 0GHz 3: 3GHz 5: 5GHz 6: 6GHz A: 2.4GHz ISM band A: Reverse Female B: GSM 900/1800 B: Reverse Male dual band F: Female G: GPS band M: Male L: 2.4/5.2/5.8 GHz N: None tri-band N: NFC T: LTE band W: WCDMA band RFPCA500609IMAB301_V01 3 01 Wire Project Diameter 0:None 1:∅ 0.81 B: MP 01~99 3:∅ 1.13 T:Durin series g Test 6:RG316 X: Pile Run 7:∅ 1.37 number 8:RG178 Dec. 2014 Approval sheet Appendix A: Dimensions Page 4 of 11 RFPCA500609IMAB301_V01 Dec. 2014 Approval sheet Test Report ■ELECTRICAL CHARACTERISTICS Return Loss Page 5 of 11 RFPCA500609IMAB301_V01 Dec. 2014 Approval sheet Isolation Page 6 of 11 RFPCA500609IMAB301_V01 Dec. 2014 Approval sheet Antenna Efficiency & Peak Gain 2400~2500 MHz Page 7 of 11 RFPCA500609IMAB301_V01 Dec. 2014 Approval sheet ■RADIATION PATTERN 2400~2500 MHz Phi=0.00deg Gain . dB Page 8 of 11 RFPCA500609IMAB301_V01 Dec. 2014 Approval sheet 2400~2500 MHz Phi=90.00deg Gain . dB Page 9 of 11 RFPCA500609IMAB301_V01 Dec. 2014 Approval sheet 2400~2500 MHz Theta=90.00deg Gain . dB Page 10 of 11 RFPCA500609IMAB301_V01 Dec. 2014 Approval sheet Package Page 11 of 11 RFPCA500609IMAB301_V01 Dec. 2014
RFPCA500609IMAB301 价格&库存
很抱歉,暂时无法提供与“RFPCA500609IMAB301”相匹配的价格&库存,您可以联系我们找货
