SRFC015-100
SRFC015-100
    ANTENOVA(安诺亚)
    SRFC015-100
SRFC015-100 数据手册
Zhengi Antenna for Cellular applications Part No. SRFC015 1. flexiiANT ® Product Specification Features       2. Antenna for 3G and 4G LTE applications including MIMO systems. GSM850, GSM900, DCS1800, PCS1900, WCDMA2100, LTE B7 (2500-2690 MHz), LTE B30, B40 (2300-2400 MHz) 1.13mm diameter RF cable with IPEX MHF connector Self-adhesive mounted Quick and simple integration minimizes design cycle Available in 3 standard cable lengths Description Zhengi is intended for use with 3G + 4G LTE applications. Covers all 3G bands along with additional LTE bands (B7, B30, B38, B40, B41). This product specification shows the performance of this antenna in all workable bands. 3. Applications       Smart meters Femto / Pico base stations Telematics Remote monitoring Machine to Machine POS (Point of Sale) terminals Antennas for Wireless M2M Applications Product Specification Zhengi-SERF015-PS-1.1 Page 1 Zhengi Part No. SRFC015 4. Part Number Zhengi: SRFC015 5. General Data Product name Zhengi Part Number Polarization SRFC015 824-960MHz 1710-1990MHz 2110-2170MHz 2300-2400MHz 2500-2690MHz Linear Operating temperature -40°C to 85°C Environmental condition test ISO 16750-4 5.1.1 / 5.1.2\ Impedance with matching 50 Ω Weight < 0.5 g Antenna type FPC Self-adhesive 3M 468P Dimensions (Antenna) 80.0 x 20.0 x 0.15 (mm) Connection IPEX Frequency Antennas for Wireless M2M Applications Product Specification Zhengi-SRFC015-PS-1.1 Page 2 Zhengi Part No. SRFC015 6. RF Characteristics 824 – 960 MHz 1710 – 1990 MHz 2110 – 2170 MHz Peak gain 0.50dBi 4.00dBi 3.50dBi Average gain -2.50dBi -1.50dBi -2.50dBi Average efficiency >50% >65% >50% Maximum return loss -5.4dB -6.0dB -8.0dB Maximum VSWR 3.30:1 2.90:1 2.10:1 2300 – 2400 MHz 2500 – 2690 MHz Peak gain 3.80dBi 5.00dBi Average gain -2.50dBi -1.50dBi Average efficiency >50% >65% Maximum return loss -5.5dB -6.0dB Maximum VSWR 3.20:1 2.90:1 All data measured in a loaded condition adhered to a 1.6mm thick plastic carrier free space. An RF choke was used to prevent cable radiation. Antennas for Wireless M2M Applications Product Specification Zhengi-SRFC015-PS-1.1 Page 3 Zhengi Part No. SRFC015 7. RF Performance 7.1 Return Loss 5 [dB] Atyune 0 1 -5 2 7 9 3 6 5 -10 8 10 4 -15 -20 -25 300 [MHz] 600 900 MARKERS: MHz dB SRFC015.S1P - S11 1: 824 2: 960 1200 MHz -5.41 -5.40 dB 3: 1710 -6.31 4: 1990 -15.39 1500 MHz 1800 dB 2100 MHz 5: 2110 -10.41 6: 2170 -8.92 2400 dB 2700 MHz 7: 2300 -5.62 8: 2400 -11.71 3000 dB 9: 2500 -6.11 10: 2690 -12.69 7.2 VSWR 10 [] Atyune 9 8 7 6 5 4 1 2 7 9 3 3 6 5 2 8 10 4 1 300 [MHz] 600 900 MARKERS: MHz SRFC015.S1P - S11 1: 824 2: 960 1200 MHz 3.32 3.32 3: 1710 4: 1990 1500 1800 MHz 2.87 1.41 5: 2110 6: 2170 2100 MHz 1.86 2.11 7: 2300 8: 2400 2400 2700 3000 MHz 3.20 1.70 9: 2500 10: 2690 2.96 1.60 Antennas for Wireless M2M Applications Product Specification Zhengi-SRFC015-PS-1.1 Page 4 Zhengi Part No. SRFC015 7.3 Antenna patterns 7.3.1 824 MHz – 960 MHz dBi 3D pattern at 890 MHz Drag to rotate pattern and PCB by using Adobe Reader (Click to Activate) Antennas for Wireless M2M Applications Product Specification Zhengi-SRFC015-PS-1.1 Page 5 Zhengi Part No. SRFC015 7.3.2 1710 MHz – 2170 MHz dBi 3D pattern at 1990 MHz Drag to rotate pattern and PCB by using Adobe Reader (Click to Activate) Antennas for Wireless M2M Applications Product Specification Zhengi-SRFC015-PS-1.1 Page 6 Zhengi Part No. SRFC015 7.3.3 2300 MHz – 2400 MHz dBi 3D pattern at 2350 MHz Drag to rotate pattern and PCB by using Adobe Reader (Click to Activate) Antennas for Wireless M2M Applications Product Specification Zhengi-SRFC015-PS-1.1 Page 7 Zhengi Part No. SRFC015 7.3.4 2500 MHz – 2690 MHz dBi 3D pattern at 2600 MHz Drag to rotate pattern and PCB by using Adobe Reader (Click to Activate) Antennas for Wireless M2M Applications Product Specification Zhengi-SRFC015-PS-1.1 Page 8 Zhengi Part No. SRFC015 8. Antenna Dimensions 8.1 Dimensions FPC section L W T Length Width Thickness 80.0 ±0.2 (mm) 20.0 ±0.2 (mm) 0.15 (mm) nominal All dimensions in mm 8.2 Dimensions assembled SRFC015-100 SRFC015-150 SRFC015-200 L L L 113 ±2.0 (mm) 163 ±2.0 (mm) 213 ±2.0 (mm) Antennas for Wireless M2M Applications Product Specification Zhengi-SRFC015-PS-1.1 Page 9 Zhengi Part No. SRFC015 8.3 IPEX Connector I-PEX Material Copper Alloy Plating Ag Front Back Side 5.0 3.0 All dimensions in mm 8.4 Assembly I-PEX Connector 1.13mm ø Cable FPC Antennas for Wireless M2M Applications Product Specification Zhengi-SRFC015-PS-1.1 Page 10 Zhengi Part No. SRFC015 9. Electrical Interface 9.1 Host Interface The host PCB requires the mating connector which is IPEX MHF (UFL) receptacle. The location should be close to the chip/modules pin for the RF. Any feed from this receptacle should be maintained at 50Ω impedance. 9.2 Transmission Line All transmission lines should be designed to have a characteristic impedance of 50Ω. • The length of the transmission lines should be kept to a minimum • Any other parts of the RF system like transceivers, power amplifiers, etc, should also be designed to have an impedance of 50 Ω Once the material for the PCB has been chosen (PCB thickness and dielectric constant), a coplanar transmission line can easily be designed using any of the commercial software packages for transmission line design. For the chosen PCB thickness, copper thickness and substrate dielectric constant, the program will calculate the appropriate transmission line width and gaps on either side of the feed. A DC blocking capacitor should be placed in line to protect the RF front end. 10. Mechanical Fixing The antenna uses 3M 468MP adhesive on the reverse side of the FPC. The antenna has an easy access split line to peel off to reveal the adhesive side. It is designed for a one time fix to a clean smooth surface. FPC back side Split line for easy peel Antennas for Wireless M2M Applications Product Specification Zhengi-SRFC015-PS-1.1 Page 11 Zhengi Part No. SRFC015 10.0 Antenna Integration Guide 10.1 Placement For placing the FPC antenna within a device, the host PCB size is not a factor like with PCB mounted antennas. However placement still needs to follow some basic rules, as any antenna is sensitive to its environment. Using six spatial directions shown below as a guide. The antenna FPC section should try to maintain a minimum of three directions free from obstructions to be able to operate effectively. The other directions will have obstacles in their paths, these directions still require a minimum clearance. These minimum clearances are further defined in this section. The plastic case is not included in this, only metal objects/components that will obstruct or come in close proximity to the antenna. Six spatial directions relative to FPC Antennas for Wireless M2M Applications Product Specification Zhengi-SRFC015-PS-1.1 Page 12 Zhengi Part No. SRFC015 10.2 Orientation of FPC The orientation of the FPC with respect to the host PCB should be defined depending on the unit. The proximity of the GND will have an influence on the antenna so the PCB location relative to the antenna should be considered. The FPC will normally be placed in one of the three following options for orientation. In each option a distance (d) is the critical dimension to consider. Below shows the minimum value of (d) for each. Other obstructions may increase this dimension. 1) Vertical mounted FPC Cable +Connector d ≥ 3mm PCB 1) Co-planar to PCB d ≥ 15mm 2) Planar to PCB (Same plane) d ≥ 3mm Antennas for Wireless M2M Applications Product Specification Zhengi-SRFC015-PS-1.1 Page 13 Zhengi Part No. SRFC015 11. Hazardous Material Regulation Conformance The antenna has been tested to conform to RoHS requirements. A certificate of conformance is available from Antenova M2M’s website. 12. Packaging The antennas are stored in individual plastic (PE) bags. Then stored within a second bag of 10pcs. Single antenna per bag 10 units per second bag (Labelled) 12.1 Optimal Storage Conditions Temperature -10ºC to 40ºC Humidity Less than 75% RH Shelf life 18 Months Storage place Away from corrosive gas and direct sunlight Antennas should be stored in unopened sealed manufacturer’s plastic packaging. Packaging The shelf life of the antenna is 18m, provided the bag of 10 pieces remains factory sealed. Antennas for Wireless M2M Applications Product Specification Zhengi-SRFC015-PS-1.1 Page 14 Zhengi Part No. SRFC015 , 12.2 Label Information Antenova Limited Antenova Asia Ltd 4F, No 324, Sec 1, Nei-Hu Road Nei-Hu District, Taipei 11493, Taiwan, ROC 60.00mm info@antenova-m2m.com / www.antenova-m2m.com Description: Zhengi Part number: SRFC015 Quantity: 10 Date Code: YYWW Manufacturer’s code number: flexiiANT ® 90.00m m Antennas for Wireless M2M Applications Product Specification Zhengi-SRFC015-PS-1.1 Page 15 Zhengi Part No. SRFC015 www.antenova-m2m.com Corporate Headquarters North America Headquarters Asia Headquarters Antenova Limited nd 2 Floor Titan Court 3 Bishop Square Hatfield AL10 9NA UK Antenova Limited 100 Brush Creek Road, Suite 103 Santa Rosa California 95404 USA Antenova Asia Limited 4F, No. 324, Sec. 1, Nei-Hu Road Nei-Hu District Taipei 11493 Taiwan, ROC Tel: +1 707 890 5202 Email: sales@antenova-m2m.com Tel: +886 (0) 2 8797 8630 Fax: +886 (0) 2 8797 6890 Email: sales@antenova-m2m.com Tel: +44 1223 810600 Email: sales@antenova-m2m.com Copyright® Antenova Ltd. All Rights Reserved. Antenova ®, Antenova M2M ®, gigaNOVA ®, the Antenova product family names, and the Antenova and Antenova M2M logos are trademarks and/or registered trademarks of Antenova Ltd. Any other names and/or trademarks belong to their respective companies. The materials provided herein are believed to be reliable and correct at the time of printing. Antenova does not warrant the accuracy or completeness of the information, text, graphics or other items contained within this information. Antenova further assumes no responsibility for the use of this information, and all such information shall be entirely at the user’s risk. Antennas for Wireless M2M Applications Product Specification Zhengi-SRFC015-PS-1.1 Release date May 2016 Page 16
SRFC015-100 价格&库存
很抱歉,暂时无法提供与“SRFC015-100”相匹配的价格&库存,您可以联系我们找货
