Approval sheet
PCB ANTENNA
2.4 GHz Band Working Frequency
Halogens Free Product
P/N: RFPCA331630IMAB301
Customer:
Customer ‘s Part No.:
Approval No.:
Issue Date:
*Contents in this sheet are subject to change without prior notice.
Page 1 of 9
RFPCA331630IMAB301_V01
Oct. 2015
Approval sheet
Version
V01
Page 2 of 9
Date
2015
Oct.
Description
New Release
Author
HWCHAN
Oct. 2015
Approval sheet
ELECTRICAL CHARACTERISTICS
Item
Specification
Frequency Range
2.4 ~ 2.5 GHz
Impedance
50 Ohm Nominal
Return Loss
-10 dB (Max)
Peak Gain
3.96 dBi
VSWR
2.0 (Max)
Radiation
Omni-directional
Polarization
Admitted Power
Linear Vertical
1W
*note-1: Electrical characteristics will depend on customer’s final application.
MATERIAL TABLE
Items
Description
Cable
∮1.13(Gray)
FPC Antenna
FR4(綠漆板) T=0.6mm
Connector
IPEX
ORDERING RULE
RF
PCA
Type Code
Product
Code
Walsin RF
Device
PCA:
PCB
Antenna
Page 3 of 9
3316
PCB
Dimension
(Unit: mm)
30
I
Cable
Connector
Length (unit:
Brand
cm)
A: N
C:MCX
D:IPEX III
Per 2 digits of
2 digits for
E: IPEX IV
length, width
cable length F: IPEX A13
H: Hirose
e.g.:3316
e.g.:30
I: IPEX
Length
Cable
M: MMCX
33.5mm, Width
Length:30cm S: SMA
16.6mm
T: TNC
U:MURATA
N: None
M
A
B
Type of Connector
Application
Project
status
0: 0GHz
3: 3GHz
5: 5GHz
6: 6GHz
A: 2.4GHz ISM band
A: Reverse Female B: GSM 900/1800
B: Reverse Male
dual band
F: Female
G: GPS band
M: Male
L: 2.4/5.2/5.8 GHz
N: None
tri-band
N: NFC
T: LTE band
W:
WCDMA
band
3
01
Wire
Project
Diameter
0:None
1:∅ 0.81
B: MP
01~99
3:∅ 1.13
T:Durin
series
g Test
6:RG316
X: Pile Run 7:∅ 1.37 number
8:RG178
Oct. 2015
Approval sheet
Appendix A: Dimensions
Page 4 of 9
Oct. 2015
Approval sheet
Test Report
■ELECTRICAL CHARACTERISTICS
Return Loss
Page 5 of 9
Oct. 2015
Approval sheet
■Antenna Efficiency & Peak Gain
Page 6 of 9
Oct. 2015
Approval sheet
■RADIATION PATTERN
2400~2500 MHz
Phi=0.00deg
Gain . dB
Page 7 of 9
Oct. 2015
Approval sheet
Phi=90.00deg
Gain . dB
Page 8 of 9
Oct. 2015
Approval sheet
Theta=90.00deg
Gain . dB
Page 9 of 9
Oct. 2015
很抱歉,暂时无法提供与“RFPCA331630IMAB301”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 3000+20.188923000+2.61198
