1001932PT-AA10L0100
1001932PT-AA10L0100
    ETHERTRONICS
    PRESTTA WLAN BT ZIGBEE TUNABLE E
1001932PT-AA10L0100 数据手册
PRODUCT: 802.11 PRODUCT: 2.4GHz/5GHz WLAN Part No. 1001932PT PresttaTM WLAN BT Zigbee Tunable Embedded PCB Antenna 802.11 2.4GHz/5GHz KEY BENEFITS DESIGN ADVANTAGES Quicker Time-to-Market  By optimizing antenna size, performance and emissions, customer and regulatory specifications are more easily met. Ethertronics’ Prestta series of Isolated Magnetic Dipole™ (IMD) trace antennas address the challenges facing today’s product designers. IMD’s high performance and isolation characteristics offer better connectivity and minimal interference. IMD antennas can be used in a variety of devices:  Computing Devices  Networking Devices  M2M, IoT wireless devices TECHNOLOGY ADVANTAGES Stays in Tune IMD antenna technology provides superior RF field containment, resulting in less interaction with surrounding components. Ethertronics IMD antennas resist de-tuning; providing a robust radio link regardless of the usage position. Prestta WLAN antennas use patented IMD technology in a trace configuration to provide high performance. IMD antennas requires a smaller design keep-out area, carry lower program development risk which yields a quicker time-to-market, without sacrificing RF performance. This antenna enables limited range RF tuning by solder bridges or cuts to be more adaptive for the antenna install environment. Greater Flexibility  Ethertronics’ first-in-class IMD technology enables you to develop concept designs that are more advanced and that deliver superior performance in receptioncritical applications.  Multiple cable lengths to fit a variety of devices. RoHS Compliant  Ethertronics’ antennas are fully compliant with the European RoHS Directive 2011/65/EU. END USER ADVANTAGES Unique Form Factors Support Advanced Industrial Designs  Smaller, more efficient IMD embedded antennas break through restrictive design rules and provide new freedom in component placement. Superior Range & Signal Strength  Better antenna function means longer range and greater sensitivity to critically precise signals—delivering greater customer satisfaction while building brand loyalty. SERVICE AND SUPPORT Extensive RF Experience  Ethertronics antennas are supported by documentation, and when needed, by the expertise of RF engineers who have integrated hundreds of antenna designs into wireless devices. Global Operations & Design Support  Ethertronics’ global operations supports an integrated network of design centers that can take projects from concept to production. ETHERTRONICS 5501 Oberlin Drive, Suite 100, San Diego, CA. 92121, USA www.ethertronics.com Tel +(1) 858.550.3820 | fax +(1) 858.550.3821 | contact: info@ethertronics.com PRODUCT: 802.11 2.4GHz/5GHz Internal (Embedded) Antenna Specifications Typical specs for a WLAN, BT, Zigbee applications Electrical Specifications Typical Characteristics (In reference device housing made of PC/ABS plastic with 100mm long cable) WLAN a/b/g/n/ac Antenna (GHz) Peak Gain Efficiency Mechanical Specifications VSWR Match Feed Point Impedance Dimensions Weight Cable / Connector Cable Length Packaging 2.390-2.490 4.900-5.100 5.150-5.350 5.70-5.900 2.5 dBi 63% 3.7 dBi 78% 3.4 dBi 75% 4.4 dBi 70%
1001932PT-AA10L0100 价格&库存
很抱歉,暂时无法提供与“1001932PT-AA10L0100”相匹配的价格&库存,您可以联系我们找货
