Approval sheet
Metal ANTENNA
2.4 GHz Working Frequency
Halogens Free Product
P/N: RFMTA340745IMAB701
Customer:
Customer ‘s Part No.:
Approval No.:
Issue Date:
*Contents in this sheet are subject to change without prior notice.
Page 1 of 10
RFMTA340745IMAB701_V01
Sep. 2015
Approval sheet
Version
V01
Page 2 of 10
Date
2015
SEP.
Description
New Release
Author
SHLee
Sep. 2015
Approval sheet
ELECTRICAL CHARACTERISTICS
Item
Specification
Frequency Range
2.4 ~ 2.5GHz
Impedance
50 Ohm Nominal
Return Loss
-10 dB (Max)
Peak Gain
3.39 dBi
VSWR
2.0 (Max)
Radiation
Omni-directional
Polarization
Admitted Power
Linear Vertical
1W
*note-1: Electrical characteristics will depend on customer’s final application.
MATERIAL TABLE
Items
Description
Metal
SUS 430 T=0.3mm(鍍鎳)
Cable
∮1.37 (Gray)
Connector
IPEX Compatible
Sponge+Doubel Tape(3M 9448)
L34*W7.5*T1.3mm(含雙面背膠不含離型紙)
ORDERING RULE
RF
MTA
Type Code
Product
Code
3407
45
I
Metal
Cable
Connector
Dimension Length (unit:
Brand
(Unit: mm)
cm)
M
Type of Connector
A: N
C:MCX
D:IPEX III
Per 2 digits of
Walsin RF
Device
MTA:
Metal
Antenna
E: IPEX IV
cable length F: IPEX A13 A: Reverse Female
B: Reverse Male
H: Hirose
F: Female
e.g.: 4308
I: IPEX
e.g.: 10
M: Male
Length 43mm, Cable
M: MMCX
N: None
Width 8.3mm Length:10cm S: SMA
2 digits for
length, width
T: TNC
U:MURATA
N: None
Page 3 of 10
A
B
Application
Project
status
0: 0GHz
3: 3GHz
5: 5GHz
6: 6GHz
dual band
G: GPS band
L: 2.4/5.2/5.8 GHz
tri-band
N: NFC
T: LTE band
W: WCDMA band
01
0:None
A: 2.4GHz ISM band
B: GSM 900/1800
7
Wire
Project
Diameter
B: MP
T:Durin
g Test
1:∅ 0.81
3:∅ 1.13
6:RG316
X: Pile Run 7:∅ 1.37
01~99
series
number
8:RG178
Sep. 2015
Approval sheet
Appendix A: Dimensions
Page 4 of 10
Sep. 2015
Approval sheet
Test Report
■PCB Layout
Page 5 of 10
Sep. 2015
Approval sheet
■ELECTRICAL CHARACTERISTICS
Return Loss
Page 6 of 10
Sep. 2015
Approval sheet
■Antenna Efficiency & Peak Gain
Page 7 of 10
Sep. 2015
Approval sheet
■RADIATION PATTERN
2400~2500 MHz
Phi=0.00deg
Gain . dB
Page 8 of 10
Sep. 2015
Approval sheet
2400~2500 MHz
Phi=90.00deg
Gain . dB
Page 9 of 10
Sep. 2015
Approval sheet
2400~2500 MHz
Theta=90.00deg
Gain . dB
Page 10 of 10
Sep. 2015
很抱歉,暂时无法提供与“RFMTA340745IMAB701”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+43.952481+5.68643
- 10+33.4169110+4.32337
- 25+30.7940625+3.98404
- 100+27.90502100+3.61026
- 250+26.52719250+3.43200
- 500+25.69715500+3.32462
- 2400+24.320652400+3.14653
