ANT-315-CW-HW
Data Sheet
by
Product Description
8.1 mm
(0.32")
HW Series antennas deliver outstanding
performance in a rugged and cosmetically attractive
package. The 315, 418 and 433MHz monopole
versions have a straight whip ¼-wave element.
The straight whip element delivers wide bandwidth
and consistent performance. The antennas attach
via a standard SMA or Part 15 compliant RP-SMA
connector. Custom colors and connectors are
available for volume OEM customers.
Features
Low cost
Excellent performance
Omni-directional pattern
Outstanding VSWR
Rugged & damage-resistant
Standard SMA or Part 15 compliant RP-SMA
connector
• Custom colors and terminators for volume
OEMs
• Use with plastic* or metal enclosures
• Internal O-ring seal on connector
120 mm
(4.72")
10.7 mm
(0.42")
End View
* Requires proximity ground plane
5.6 mm
(0.22")
Electrical Specifications
Center Frequency:
Recmd. Freq. Range:
Wavelength:
VSWR:
Peak Gain:
Impedance:
Connection:
Oper. Temp. Range:
15.5 mm
(0.61")
315MHz
304–325MHz
¼-wave
≤ 2.0 typical at center
0dBi
50-ohms
SMA or RP-SMA
–20°C to +80°C
Electrical specifications and plots measured with a 10.16 cm x
10.16 cm (4.00" x 4.00") reference ground plane.
Ordering Information
ANT-315-CW-HW (with RP-SMA connector)
ANT-315-CW-HW-SMA (with SMA connector)
–1–
Revised 11/18/13
Counterpoise
Quarter-wave or monopole antennas require an associated ground plane
counterpoise for proper operation. The size and location of the ground
plane relative to the antenna will affect the overall performance of the
antenna in the final design. When used in conjunction with a ground
plane smaller than that used to tune the antenna, the center frequency
typically will shift higher in frequency and the bandwidth will decrease.
The proximity of other circuit elements and packaging near the antenna
will also affect the final performance. For further discussion and guidance
on the importance of the ground plane counterpoise, please refer to Linx
Application Note AN-00501: Understanding Antenna Specifications and
Operation.
VSWR Graph
VSWR
3:1
Reflected Power
25%
1.341
2:1
1:1
215MHz
11%
0%
415MHz
315MHz
What is VSWR?
The Voltage Standing Wave Ratio (VSWR) is a measurement of how well
an antenna is matched to a source impedance, typically 50-ohms. It is
calculated by measuring the voltage wave that is headed toward the load
versus the voltage wave that is reflected back from the load. A perfect
match will have a VSWR of 1:1. The higher the first number, the worse the
match, and the more inefficient the system. Since a perfect match cannot
ever be obtained, some benchmark for performance needs to be set. In
the case of antenna VSWR, this is usually 2:1. At this point, 88.9% of the
energy sent to the antenna by the transmitter is radiated into free space
and 11.1% is either reflected back into the source or lost as heat on
the structure of the antenna. In the other direction, 88.9% of the energy
recovered by the antenna is transferred into the receiver. As a side note,
since the “:1” is always implied, many data sheets will remove it and just
display the first number.
How to Read a VSWR Graph
VSWR is usually displayed graphically versus frequency. The lowest point
on the graph is the antenna’s operational center frequency. In most cases,
this will be different than the designed center frequency due to fabrication
tolerances. The VSWR at that point denotes how close to 50-ohms the
antenna gets. Linx specifies the recommended bandwidth as the range
where the typical antenna VSWR is less than 2:1.
159 Ort Lane, Merlin, OR, US 97532
Phone: +1 541 471 6256
Fax: +1 541 471 6251
www.linxtechnologies.com
–2–
Data Sheet ANT-315-CW-HW
by
很抱歉,暂时无法提供与“ANT-315-CW-HW-SMA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+180.43560
- 200+71.99280
- 500+69.59520
- 1000+68.40720
