ANT-916-PML-ccc
Data Sheet
by
Product Description
8.2 mm
(0.32")
Designed for permanent attachment, the PML
½-wave whip tilts 180 degrees and delivers
outstanding performance in a cost-effective
package. An internal counterpoise eliminates
external ground plane dependence and maximizes
performance. The antenna is attached by placing
its base through a ¼” (6.35 mm) hole in the product
and securing it with a nut or by threading it into
a PEM-style insert. This method of attachment is
highly secure and saves the cost of an antenna
connector. The PML attaches to a PCB or
connector via 12” (30.48 cm) of RG-178 coax
cable. It is also available with 1.32 mm coax cable
terminated with a U.FL/MHF compatible connector.
This saves the labor of adding a connector while
using one that is small enough to fit through the
antenna’s mounting hole. Custom lengths and
terminations are available by special order.
12.1 mm
(0.48")
Available with
Straight Cut Cable
or U.FL Connector
123.0 mm
(4.84")
150.3 mm
(5.92")
7.9 mm
(0.31")
Features
35.2 mm
(1.39")
Cost-effective
Internal counterpoise
Tilts 180 degrees
Outstanding performance
Omni-directional pattern
Low VSWR
Integral 12” (30.48 cm) RG-178 coax cable or
1.32 mm coax (U.FL)
6.0 mm
(0.24")
Electrical Specifications
Center Frequency:
Recom. Freq. Range:
Bandwidth:
Wavelength:
VSWR:
Peak Gain:
Impedance:
Cable:
Connection:
Oper. Temp. Range:
I-PEX silhouette
shown in shadow
Ordering Information
916MHz
881-951MHz
70MHz
½-wave
≤ 1.9 typical
–0.4dBi max
50-ohms
or 1.32 mm coax (U.FL)
Straight-cut or U.FL/MHF
–40°C to +90°C
ANT-916-PML (with straight cut RG-178 coax)
ANT-916-PML-UFL (with U.FL/MHF compatible
connector and 1.32mm coax)
Electrical specifications and plots measured on 10.16 cm x
10.16 cm (4.00” x 4.00”) reference ground plane
–1–
Revised 8/1/2017
VSWR Graph
VSWR
1.131
3:1
Reflected Power
25%
11%
2:1
1:1
816MHz
916MHz
0%
1016MHz
What is VSWR?
The Voltage Standing Wave Ratio (VSWR) is a measurement of how well an antenna is matched to a source
impedance, typically 50-ohms. It is calculated by measuring the voltage wave that is headed toward the load
versus the voltage wave that is reflected back from the load. A perfect match has a VSWR of 1:1. The higher
the first number, the worse the match, and the more inefficient the system. Since a perfect match cannot
ever be obtained, some benchmark for performance needs to be set. In the case of antenna VSWR, this
is usually 2:1. At this point, 88.9% of the energy sent to the antenna by the transmitter is radiated into free
space and 11.1% is either reflected back into the source or lost as heat on the structure of the antenna. In
the other direction, 88.9% of the energy recovered by the antenna is transferred into the receiver. As a side
note, since the “:1” is always implied, many data sheets will remove it and just display the first number.
How to Read a VSWR Graph
VSWR is usually displayed graphically versus frequency. The lowest point on the graph is the antenna’s
operational center frequency. In most cases, this is different than the designed center frequency due to
fabrication tolerances. The VSWR at that point denotes how close to 50-ohms the antenna gets. Linx
specifies the recommended bandwidth as the range where the typical antenna VSWR is less than 2:1.
Copyright © 2017 Linx Technologies
159 Ort Lane, Merlin, OR 97532
Phone: +1 541 471 6256
Fax: +1 541 471 6251
www.linxtechnologies.com
–2–
ANT-916-PML-ccc Data Sheet
by
很抱歉,暂时无法提供与“ANT-916-PML-UFL”相匹配的价格&库存,您可以联系我们找货
