DELTA7B/X/SMAM/S/S/11
    SIRETTA
DELTA7B/X/SMAM/S/S/11 数据手册
Delta 7B GSM/GPRS Hinged Antenna Key Features • Hinged mount • Quad band GSM/GPRS frequencies • Omni-directional General Description Additional Considerations The Delta 7B is a quad band GSM/ GPRS ¼ wave, omni-directional antenna with a peak gain of 2dBi. The hinged joint allows flexibility with positioning through 0, 45 & 90 degrees along with rotational alignment. • Flexible positioning allows for signal optimisation • Meets all EU compliance criteria for electronic goods Common IoT applications include: car park / utilities metering, wireless key entry, security systems, remote monitoring and many other GSM / GPRS based applications. The Delta 7B is supplied, as standard, with an SMA male connector. Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales fax email web +44(0)118 976 9014 +44(0)118 976 9020 sales@siretta.com www.siretta.com Rev 1.4 Delta 7B GSM/GPRS Hinged Antenna Electrical Specifications Mechanical Specifications Operating Temperature range: -20 - 65 °C Storage Temperature range: -20 - 75 °C Impedance: Radiating Element: VSWR: Operating Frequencies: Polarization: Radiating Element: Dimensions: 110 x 10.2mm Ø Connector: 50 Ohm ¼ wave omni-directional dipole SMA Male Cable: RG178 Mounting Method: Direct Connect
DELTA7B/X/SMAM/S/S/11 价格&库存
很抱歉,暂时无法提供与“DELTA7B/X/SMAM/S/S/11”相匹配的价格&库存,您可以联系我们找货
  • 1+68.80423
  • 10+65.36766
  • 50+62.75379
库存:17
