Datasheet
ANT-433-WRT-ccc
433 MHz External Panel-Mount Antenna
The ANT-433-WRT is a low-profile, panel-mount
dipole antenna designed for remote control and
other applications in the 430 MHz to 435 MHz
range.
The ANT-433-WRT antenna’s compact size allows
it to be mounted in applications requiring a low
profile and external antenna performance, such as
wireless vending and traffic control equipment.
The ANT-433-WRT antenna is designed with an
integrated counterpoise that eliminates the need
for additional ground plane in the product, making
it ideal for applications with non-conductive or RF
transparent enclosures.
Connector options for the ANT-433-WRT antenna
are: SMA plug (male pin), RP-SMA plug (female
socket) or MHF1/U.FL-type plug (female socket).
ANT-433-WRT-SMA Shown
Features
Applications
• Performance at 430 MHz to 435 MHz
― VSWR: ≤ 1.4
― Peak Gain: -1.8 dBi
― Efficiency: 25%
• Low-profile
― Height: 27.0 mm (1.10 in)
― Diameter: 19.0 mm (0.75 in)
• Mounts permanently with pressure sensitive
adhesive ring and provided nut
• Remote control, sensing and monitoring
― Security systems
― Industrial machinery
― Automated equipment
― AMR (automated meter reading)
• Internet of Things (IoT) devices
• Smart Home networking
Ordering Information
Part Number
Description
ANT-433-WRT-UFL-150
Antenna, 150 mm (5.91 in) of 1.32 mm coaxial cable, MHF1/U.FL-type plug (female socket)
ANT-433-WRT-UFL
Antenna, 216 mm (8.50 in) of 1.32 mm coaxial cable, MHF1/U.FL-type plug (female socket)
ANT-433-WRT-UFL-300
Antenna, 300 mm (11.81in) of 1.32 mm coaxial cable, MHF1/U.FL-type plug (female socket)
ANT-433-WRT-RPS
Antenna, 216 mm (8.50 in) of RG-174 coaxial cable, RP-SMA plug (female socket)
ANT-433-WRT-SMA
Antenna, 216 mm (8.50 in) of RG-174 coaxial cable, SMA plug (male pin)
ANT-433-WRT-SMA-300
Antenna, 300 mm (11.81 in) of RG-174 coaxial cable, SMA plug (male pin)
Available from Linx Technologies and select distributors and representatives.
WRT Series
ANT-433-WRT-ccc
Datasheet
Table 1. Electrical Specifications
ANT-433-WRT
433 MHz
430 MHz to 435 MHz
Frequency Range
VSWR (max)
1.4
Peak Gain (dBi)
-1.8
Average Gain (dBi)
-6.2
25
Efficiency (%)
Polarization
Linear
Radiation
Impedance
50 Ω
Max Power
Wavelength
1/2-wave
Omnidirectional
5W
Dipole
Electrical Type
Electrical specifications and plots measured with a 102 mm x 102 mm (4.0 in x 4.0 in) reference ground plane.
Table 2. Mechanical Specifications
Connection
Coaxial Cable, minimum
inside bend radius
Weight
ANT-433-WRT-UFL
MHF1/U.FL-type plug
1.32 mm: 6.0 mm (0.24 in)
150 mm = 9.1 g (0.32 oz)
216 mm = 9.4 g (0.33 oz)
300 mm = 9.8 g (0.35 oz)
ANT-433-WRT-RPS
RP-SMA plug
RG-174: 10.2 mm (0.40 in)
216 mm = 14.3 g (0.50 oz)
ANT-433-WRT-SMA
SMA plug
300 mm = 15.4 g (0.54 oz)
Part Number
-40 °C to +90 °C
Operating Temp. Range
Height: 27.0 mm (1.10 in) Diameter: 19.0 mm (0.75 in)
Dimensions
Packaging Information
The ANT-433-WRT antenna is placed in a clear plastic sleeve and sealed in clear plastic bags in quantities of
50 pcs. Bags are packaged in cartons of 250 (5 bags). Distribution channels may offer alternative packaging
options.
Product Dimensions
Figure 1 provides dimensions for the ANT-433-WRT series antenna.
Ø19.0 mm
(0.75 in)
Adhesive Ring
8-sided plastic nut and mounting shaft
M11 x 1.0 mm
Ø5.3 mm (0.21 in)
Counterpoise
-SMA
-RPS
-UFL
85.0 mm (3.35 in)
8.0 mm
(0.32 in)
See Ordering Information for
cable length and termination options
Figure 1. ANT-433-WRT Antenna Dimensions
-MHF4
Recommended Mounting
2
Ø10.8 mm
(0.43 in)
27.0 mm
(1.10 in)
WRT Series
ANT-433-WRT-ccc
Datasheet
8-s
The recommended enclosure mounting dimensions are shown in Figure 2. The ANT-433-WRT series antenna
is supplied with an integrated closed-cell pressure sensitive adhesive ring which helps seal-SMA,
enclosures
-RPS
against external elements. The adhesive ring has a protective plastic backing that must be removed prior
to installation. A pull tab has been provided for easy removal of the protective backing. The antenna can be
-MHF1/-U.FL
permanently mounted using the provided nut which should be tightened to 4.0 kgf/cm (5 in/lbs) max. The
recommended maximum enclosure wall thickness is 4.70 mm (0.188 in).
-MHF4
Ø10.8 mm
(0.43 in)
See O
cable leng
Figure 2. ANT-433-WRT Series Antenna Recommended Enclosure Mounting Dimensions
Antenna Orientation
The ANT-433-WRT antenna is characterized in two antenna orientations as shown in Figure 3. The antenna
in free space characterizes use of an antenna attached to an enclosure-mounted connector which is
connected by cable to a printed circuit board. Although the antenna is a dipole not requiring a ground
plane for function, characterization with an adjacent ground plane (102 mm x 102 mm) provides insight
into antenna performance when attached directly to a printed circuit board mounted connector. The two
orientations represent the most common end-product use cases.
Free Space
Ø5.
C
Center of Ground Plane
Figure 3. ANT-433-WRT Test Orientations
3
WRT Series
ANT-433-WRT-ccc
Datasheet
Free Space, No Ground Plane
The charts on the following pages represent data taken with the antenna oriented in free space without a
ground plane, as shown in Figure 4.
Figure 4. ANT-433-WRT in Free Space, No Ground Plane
VSWR
5
435
430
Figure 5 provides the voltage standing wave ratio (VSWR) across the antenna bandwidth. VSWR describes
the power reflected from the antenna back to the radio. A lower VSWR value indicates better antenna
performance at a given frequency. Reflected power is also shown on the right-side vertical axis as a gauge of
the percentage of transmitter power reflected back from the antenna.
VSWR
4
30
3
1
10
425
426
427
428
429
430
431 432 433 434
Frequency (MHz)
435
436
Figure 5. ANT-433-WRT VSWR, Free Space
4
437
438
439
440
Reflected Power (%)
40
WRT Series
ANT-433-WRT-ccc
Datasheet
Return Loss
430
Return loss (Figure 6), represents the loss in power at the antenna due to reflected signals. Like VSWR, a
lower return loss value indicates better antenna performance at a given frequency.
-2
Return Loss (dB)
-4
-6
-8
-10
-12
-14
-16
-18
-20
425
426
427
428
429
430
431 432 433 434
Frequency (MHz)
435
436
437
438
439
440
Figure 6. ANT-433-WRT Return Loss, Free Space
Peak Gain
5
435
430
The peak gain across the antenna bandwidth is shown in Figure 7. Peak gain represents the maximum
antenna input power concentration across 3-dimensional space, and therefore peak performance at a given
frequency, but does not consider any directionality in the gain pattern.
Peak Gain (dBi)
-10
-15
-20
425
426
427
428
429
430
431 432 433 434
Frequency (MHz)
435
436
437
438
439
440
Figure 7. ANT-433-WRT Peak Gain, Free Space
5
WRT Series
ANT-433-WRT-ccc
Datasheet
Average Gain
5
435
430
Average gain (Figure 8), is the average of all antenna gain in 3-dimensional space at each frequency,
providing an indication of overall performance without expressing antenna directionality.
Average Gain (dBi)
-10
-15
-20
425
426
427
428
429
430
431 432 433 434
Frequency (MHz)
435
436
437
438
439
440
Figure 8. ANT-433-WRT Antenna Average Gain, Free Space
Radiation Efficiency
100
435
430
Radiation efficiency (Figure 9), shows the ratio of power delivered to the antenna relative to the power
radiated at the antenna, expressed as a percentage, where a higher percentage indicates better performance
90
80
Efficiency (%)
70
60
50
40
30
426
427
428
429
430
431 432 433 434
Frequency (MHz)
435
436
437
Figure 9. ANT-433-WRT Antenna Radiation Efficiency, Free Space
6
438
439
440
WRT Series
ANT-433-WRT-ccc
Datasheet
Radiation Patterns
Radiation patterns provide information about the directionality and 3-dimensional gain performance of the
antenna by plotting gain at specific frequencies in three orthogonal planes. Antenna radiation patterns are
shown in Figure 10 using polar plots covering 360 degrees. The antenna graphic at the top of the page
provides reference to the plane of the column of plots below it. Note: when viewed with typical PDF viewing
software, zooming into radiation patterns is possible to reveal fine detail.
Radiation Patterns - Free Space
XZ-Plane Gain
YZ-Plane Gain
XY-Plane Gain
862 MHz to 876 MHz (868 MHz)
34
35
33
32
31
30
29
28
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
1
2
3
4
34
5
33
6
32
7
31
8
27
26
30
9
29
10
28
11
27
12
25
13
24
14
23
15
22
21
18
XZ-Plane Gain
17
16
35
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
1
2
3
4
34
5
33
6
32
7
31
8
26
30
9
29
10
28
11
27
12
25
13
24
14
23
15
22
21
18
17
16
35
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
1
2
3
4
5
6
7
8
9
10
11
26
12
25
13
24
14
23
15
22
21
YZ-Plane Gain
18
17
16
433 MHz
434 MHz
435 MHz
XY-Plane Gain
Figure 10. ANT-433-WRT Radiation Patterns, Free Space
7
WRT Series
ANT-433-WRT-ccc
Datasheet
The charts on the following pages represent data taken with the antenna oriented at the center of the ground
plane, as shown in Figure 11.
Figure 11. ANT-433-WRT at Center of Ground Plane
VSWR
5
435
430
Figure 12 provides the voltage standing wave ratio (VSWR) across the antenna bandwidth. VSWR describes
VSWR
4
30
3
1
10
425
426
427
428
429
430
431 432 433 434
Frequency (MHz)
435
436
437
438
Figure 12. ANT-433-WRT VSWR, at Center of Ground Plane
8
439
440
Reflected Power (%)
40
WRT Series
ANT-433-WRT-ccc
Datasheet
Return Loss
430
Return loss (Figure 13), represents the loss in power at the antenna due to reflected signals. Like VSWR, a
-2
Return Loss (dB)
-4
-6
-8
-10
-12
-14
-16
-18
-20
425
426
427
428
429
430
431 432 433 434
Frequency (MHz)
435
436
437
438
439
440
Figure 13. ANT-433-WRT Return Loss, at Center of Ground Plane
Peak Gain
5
435
430
The peak gain across the antenna bandwidth is shown in Figure 14. Peak gain represents the maximum
Peak Gain (dBi)
-10
-15
-20
425
426
427
428
429
430
431 432 433 434
Frequency (MHz)
435
436
437
438
439
440
Figure 14. ANT-433-WRT Peak Gain, at Center of Ground Plane
9
WRT Series
ANT-433-WRT-ccc
Datasheet
Average Gain
5
435
430
Average gain (Figure 15), is the average of all antenna gain in 3-dimensional space at each frequency,
Average Gain (dBi)
-10
-15
-20
425
426
427
428
429
430
431 432 433 434
Frequency (MHz)
435
436
437
438
439
440
Figure 15. ANT-433-WRT Antenna Average Gain, at Center of Ground Plane
100
435
430
Radiation efficiency (Figure 16), shows the ratio of power delivered to the antenna relative to the power
90
80
Efficiency (%)
70
60
50
40
30
426
427
428
429
430
431 432 433 434
Frequency (MHz)
435
436
437
438
439
Figure 16. ANT-433-WRT Antenna Radiation Efficiency, at Center of Ground Plane
10
440
WRT Series
ANT-433-WRT-ccc
Datasheet
Radiation Patterns
shown in Figure 17 using polar plots covering 360 degrees. The antenna graphic at the top of the page
Radiation Patterns - Center of Ground Plane
XZ-Plane Gain
YZ-Plane Gain
XY-Plane Gain
34
35
33
32
31
30
29
28
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
1
2
3
4
34
5
33
6
32
7
31
8
27
26
30
9
29
10
28
11
27
12
25
13
24
14
23
15
22
21
18
XZ-Plane Gain
17
16
35
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
1
2
3
4
34
5
33
6
32
7
31
8
26
30
9
29
10
28
11
27
12
25
13
24
14
23
15
22
21
18
17
YZ-Plane Gain
16
35
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
1
2
3
4
5
6
7
8
9
10
11
26
12
25
13
24
14
23
15
22
21
18
17
16
433 MHz
434 MHz
435 MHz
XY-Plane Gain
Figure 17. ANT-433-WRT Radiation Patterns, Center of Ground Plane
11
WRT Series
ANT-433-WRT-ccc
Datasheet
Website: http://linxtechnologies.com
Linx Offices: 159 Ort Lane, Merlin, OR, US 97532
Phone:
+1 (541) 471-6256
E-MAIL: info@linxtechnologies.com
Linx Technologies reserves the right to make changes to the product(s) or information contained herein without notice. No liability is assumed as a result of their use
or application. No rights under any patent accompany the sale of any such product(s) or information.
Wireless Made Simple is a registered trademark of Linx Acquisitions LLC. Other product and brand names may be trademarks or registered trademarks of their
respective owners.
Copyright © 2022 Linx Technologies
All Rights Reserved
Doc# DS22070-203ANT (Replaces DS21347-203ANT)
